Re: [petsc-dev] model for parallel ASM
On Sun, Jan 10, 2021 at 2:28 PM Jacob Faibussowitsch <[email protected]> wrote:
I would like as much as possible to pass the cuda and hip streams to Kokkos, since I can directly handle much of the annoyance with wrangling multiple streams and stream objects externally. Last I checked on this Kokkos was moving towards allowing association of streams to functions, but admittedly this was a while back.
OK, good. I want to ask them about LU factorizations also. I will ask about this.
Best regards,
Jacob Faibussowitsch (Jacob Fai - booss - oh - vitch) Cell: (312) 694-3391
On Jan 10, 2021, at 13:10, Mark Adams <[email protected]> wrote:
On Sat, Jan 9, 2021 at 7:37 PM Jacob Faibussowitsch <[email protected]> wrote:
It is a single object that holds a pointer to every stream implementation and toggleable type so it can be universally passed around. Currently has a cudaStream and a hipStream but this is easily extendable to any other stream implementation.
Do you have any thoughts on how this would work with Kokkos?
Would you want to feed Kokkos your Cuda/Hip, etc, stream or add a Kokkos backend to your object?
Junchao might be the person to ask. I would guess Kokkos View (vector) objects carry a stream because they block on a "deep_copy", that moves data to/from the GPU, and it is blocking.
Thanks, Mark
Best regards,
Jacob Faibussowitsch (Jacob Fai - booss - oh - vitch) Cell: +1 (312) 694-3391
On Jan 9, 2021, at 18:19, Mark Adams <[email protected]> wrote:
Is this stream object going to have Cuda, Kokkos, etc., implementations?
On Sat, Jan 9, 2021 at 4:09 PM Jacob Faibussowitsch <[email protected]> wrote:
I’m currently working on an implementation of a general PetscStream object. Currently it only supports Vector ops and has a proof of concept KSPCG, but should be extensible to other objects when finished. Junchao is also indirectly working on pipeline support in his NVSHMEM MR. Take a look at either MR, it would be very useful to get your input, as tailoring either of these approaches for pipelined algorithms is key.
Best regards,
On Jan 9, 2021, at 15:01, Mark Adams <[email protected]> wrote:
I would like to put a non-overlapping ASM solve on the GPU. It's not clear that we have a model for this.
PCApply_ASM currently pipelines the scater with the subdomain solves. I think we would want to change this and do a 1) scatter begin loop, 2) scatter end and non-blocking solve loop, 3) solve-wait and scatter begging loop and 4) scatter end loop.
I'm not sure how to go about doing this. * Should we make a new PCApply_ASM_PARALLEL or dump this pipelining algorithm and rewrite PCApply_ASM? * Add a solver-wait method to KSP?
Thoughts?
participants (1)
Mark Adams
