It appears that SNESConvergedDefault() sets snes->ttol here https://bitbucket.org/petsc/petsc/src/40bc6eb114e6a8e7f27fd216b5c1226efddf33... That should be harmless, albeit unnecessary, since snes->ttol is also set at the beginning of the solve in SNESSolve_NEWTONLS() (and other SNESSolve_XXX) right before calling the convergence test: https://bitbucket.org/petsc/petsc/src/40bc6eb114e6a8e7f27fd216b5c1226efddf33... However, this might make for some fragile code and may confuse the user modeling a custom convergence test on SNESConvergedDefault(). In particular, a local reading of SNESConvergedDefault() creates the impression that it is the convergence monitor that is responsible for setting snes->ttol on the zeroth iteration -- snes->ttol is used outside of SNES, for example, in one of the variants of the EW code (maybe only there). That would require access to SNES internals by user code. More generally, should this sort of thing be handled everywhere using snes->norm_init for consistency and to prevent potential breakage? At the very least, should snes->ttol = ... be removed from SNESConvergedDefault()? Thanks. Dmitry.
participants (1)
Dmitry Karpeyev
