Use KSPSetUpNorms_Private() in KSPSetFromOptions()
These calls compute default values for normtype and pcside based on partial KSP options, which can cause an unwarranted error to be thrown. For example, in code there may be KSPSetPCSide(ksp, PC_RIGHT); /* hardwired default, e.g., in Moose. */ Now, when I'm using command-line arguments -ksp_type preonly an error is thrown, since KSPPREONLY doesn't work with PC_RIGHT. Fine, I try -ksp_type preonly -ksp_pc_side left but still get the same error, since KSPSetUpNorms_Private() is called after KSP type has been set to KSPPREONLY, but BEFORE there was a chance to set the PC side! Is there any reason to keep these calls to KSPSetUpNorms_Private() in KSPSetFromOptions()? KSPSetUpNorms_Private() will be just about the first thing called in KSPSetUp() and will compute the appropriate normtype and pcside, but now based on complete KSP options. Not to mention that calling XXXSetUp_YYY() XXXSetFromOptions() seems generally contrary to PETSc's design philosophy. Dmitry.
participants (1)
Dmitry Karpeev
