Re: [petsc-dev] Fwd: [petsc-maint #119133] petsc-dev configure crash
6 Jun
6 Jun
'12
3:05 p.m.
If the only issue is being able to get the BuildSystem revision associated with a pets-dev revision, How about adding a hook to BuildSystem that at each commit, writes the number of the revision into a file in the pets-dev repository and does a commit in the pets-dev repository? Then all that would be done is
cd $PETSC_DIR hg up -r <petsc revision> cd config/BuildSystem hg up -r `cat $PETSC_DIR/BuildSystemVersion.txt` Which I am sure can be done automatically with a hook.
It's not high tech, but it would work, right? Plus this could be done a posteriori for all past revisions of BuildSystem.
Actually, mercurial already implements this. They just call it 'subrepos'.
5181
Age (days ago)
5181
Last active (days ago)
0 comments
1 participants
participants (1)
Sean Farley
