Re: [petsc-dev] PetscContainerSetPointer
On Aug 10, 2020, at 3:27 PM, Mark Adams <[email protected]> wrote:
I had some problems giving a container an PETSc object so I wrapped it in a struct. I forget what problem I had. Maybe ISColoringDestroy can't take a void*. I'd like to check if I was just missing something. Should something like this work?
ISColoring c; .... ierr = PetscContainerSetPointer(container,(void*)c);CHKERRQ(ierr); ierr = PetscContainerSetUserDestroy(container, ISColoringDestroy);CHKERRQ(ierr);
Mark ISColoring is a plain old C struct: struct _n_ISColoring { PetscInt refct; ... so it seems like this should work. But ISColoringDestroy(), like most PETSc destroy functions, takes the address of the pointer as the argument (as opposed to the pointer itself, this is so XXXDestroy() can set the pointer to null to prevent it getting used again accidentally with a now meaningless value.) So there is a disconnect in how PETSc handles destroying objects (take the address of a pointer) and the pointer for containers (take a pointer). Looking back I just made the container concept as simple as possible and did not think about the API difference. We could fix it now but it might break a tiny bit of user code. This should work static PetscErrorCode MyISColoringDestroy(void *is) { ISColoring tmp = (ISColoring)is; return ISColoringDestroy(&tmp); } ierr = PetscContainerSetUserDestroy(container, MyISColoringDestroy);CHKERRQ(ierr); then you won't need the dummy struct. Barry
participants (1)
Barry Smith
