Re: [petsc-dev] testharness failure Exception: Keyword: redirect_file from: redirect_file: ex1_1.tmp is not valid
Hmm, I delete the new_ files and then later they are all there making trouble. Their creation dates seem to match the times of running configure but .... Yeah it is probably my fault, but not sure where. Thanks for reminding me of the origins of those files, that may help me to determine why they exist. Maybe my giting magic is automatically running stuff on an ancient branch and thus scattering this stuff around.
On Dec 14, 2021, at 10:29 AM, kruger Scott <[email protected]> wrote:
I'm really confused. This is all legacy stuff from when we were working on converting the old test harness to the new test harness. I agree that it should all be cleaned out, but this functionality shouldn't be called at the `gmakegentest.py` level.
If you look at the open statements in gmakegentest.py and testparse.py, you'll see I'm not writing any of those files. That conversion was done by a separate script.
Scott
On 2021-12-13 21:36, Barry Smith did write:
If these are temporary work files could you not have them end with .c etc maybe have an extra .tmp at the end or something so they don't mess with everything if they are lying around? It is annoying to have to keep deleting them all.
On Dec 13, 2021, at 9:32 PM, Barry Smith <[email protected]> wrote:
Scott,
There is a problem. Somehow you are generating a ton of new_ex*.c files and then testparse.py is crapping out on them?
I see some weird stuff with these files but cannot tell when they are made and why they exist.
config/gmakegentest.py: #if not exfile.startswith("new_"+"ex"): continue config/testparse.py: new_pos = sl.instream.tell() config/testparse.py: block = striptest[last_pos:new_pos] config/testparse.py: last_pos = new_pos config/testparse.py: bn=re.sub("new_","",basename) config/testparse.py: for test_file in sorted(glob.glob("new_ex*.*")):
On Dec 12, 2021, at 10:32 PM, Barry Smith <[email protected] <mailto:[email protected]>> wrote:
Looks like it is coming from some old .c files that I had lying around that are not in the repository.
I will push a commit that prints the offending file name to make the cause easier to track down in the future
Barry
On Dec 12, 2021, at 6:09 PM, kruger Scott <[email protected] <mailto:[email protected]>> wrote:
I'm baffled and unable to reproduce. Can you give me your configure.log to help reproduce?
Scott
On 2021-12-12 17:40, Barry Smith did write:
Scott,
In the branch barry/2021-11-04/add-dmplex-vecghost which was just rebased on main I get
/usr/local/opt/[email protected]/bin/python3.9 ./config/gmakegen.py --petsc-arch=arch-add-dmplex-vecghost /usr/local/opt/[email protected]/bin/python3.9 /Users/barrysmith/Src/petsc/config/gmakegentest.py --petsc-dir=/Users/barrysmith/Src/petsc --petsc-arch=arch-add-dmplex-vecghost --testdir=./arch-add-dmplex-vecghost/tests Traceback (most recent call last): File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1089, in <module> main(petsc_dir=opts.petsc_dir, petsc_arch=opts.petsc_arch, File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1060, in main dataDict=pEx.walktree(os.path.join(pEx.srcdir)) File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 924, in walktree self.genPetscTests(root,dirs,files,dataDict) File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 897, in genPetscTests dataDict[root].update(testparse.parseTestFile(fullex,0)) File "/Users/barrysmith/Src/petsc/config/testparse.py", line 542, in parseTestFile testDict[basename]=parseTests(testString,srcfile,fileNums,verbosity) File "/Users/barrysmith/Src/petsc/config/testparse.py", line 498, in parseTests testnames,subdicts=parseTest(test,srcfile,verbosity) File "/Users/barrysmith/Src/petsc/config/testparse.py", line 426, in parseTest if not var in acceptedkeys: raise Exception("Keyword: "+var+" from: "+line+" is not valid") Exception: Keyword: redirect_file from: redirect_file: ex1_1.tmp is not valid make: *** [gmakefile.test:97: arch-add-dmplex-vecghost/tests/testfiles] Error 1
How to track down the problem? Is it due to a bad rule from some file (which file, could that be printed?)
-- Scott Kruger Tech-X Corporation [email protected] <mailto:[email protected]> 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196 Boulder, CO 80303 Fax: (303) 448-7756
-- Scott Kruger Tech-X Corporation [email protected] 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196 Boulder, CO 80303 Fax: (303) 448-7756
participants (1)
Barry Smith
