Re: [petsc-dev] p4est configure error
It sounds like I have not merged your fix. Should I pull from master? I have nuked this many times. On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac <[email protected]> wrote:
On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams wrote:
p4est on Edison configures in w/o debugging, although I have to run configure twice. But with debugging it fails. I can not see any difference between the two configures other than debugging. Mark
The log shows that you are configuring a p4est commit (3d3e1) that is before the one I pushed specifically to avoid the fortran configuration error (f54bb3). Please clear the git.p4est directory, and confirm that you are configuring with the current 'petsc' branch of p4est (`grep 'checking Point version' configure.log` should show X.XXX-a9f22).
Cheers, Toby
participants (1)
Mark Adams
