Re: [petsc-dev] print statements in fortran interface functions
Thanks, I have verified that PetscPrint with an installed libs works as expected on my Mac (on ex73f90t). I'll keep looking on Cori. ThanksMark On Mon, Mar 16, 2020 at 10:37 PM Jacob Faibussowitsch <[email protected]> wrote:
May be an issue printing to STDOUT, HPC sometimes redirect STDOUT to some other log files. Maybe try redirecting your PetscInfo() or PetscPrintf() output to a file. For PetscInfo its just a filename after the info flag: ./yourCode -info somefile . As for the PetscPrintf you will have to change those calls in your src to PetscFPrintf().
Best regards,
Jacob Faibussowitsch (Jacob Fai - booss - oh - vitch) Cell: (312) 694-3391
On Mar 16, 2020, at 9:26 PM, Mark Adams <[email protected]> wrote:
On Mon, Mar 16, 2020 at 9:50 PM Jacob Faibussowitsch <[email protected]> wrote:
Hello Mark,
If you are using PetscInfo to print, PetscInfo requires that you pass “-info” as a command line flag in order to print anything. Sounds simple enough to miss, did you run your code with it? i.e. ./yourCode -info?
Yea, I added -info.
For what its worth, PetscPrintf on PETSC_COMM_WORLD will always print but only from proc 0. PetscSynchronizedPrintf prints from all in order. Might be more useful for debugging than PetscInfo!
Yea, I started with PetscPrintf. Started with WORLD then tried SELF. Still no output but I can step through the code and see the print statements, but nothing.
This is on Cori/Haswell. I have now used printf on my Mac and it works. I did not do an install on my Mac, but I would not think that would matter... I should test that I suppose.
Best regards,
On Mar 16, 2020, at 7:54 PM, Mark Adams <[email protected]> wrote:
I am trying to debug an application code that works with v3.7 but fails with master. The code works for "normal" solvers but for a solver that uses FieldSplit it fails. It looks like vectors are not getting created from MatCreateVecs with a matrix that is a MatNest (I can't run the code).
I have put print statements in the interface files to try to see what is going on but the print statements seem to disappear somehow. (I added the same print statements in my installation of v3.7 to see what is different) I was using PetscPrint and then found and example of a Fortran PetscInfo and switched to that. I stepped through the code with DDT and see the print statements but nothing goes to the output. I did this DDT stuff with ex73f90t, which has a MatCreateNest.
I am completely baffled. Does anyone have any ideas?
Thanks, Mark
participants (1)
Mark Adams
