petsc-dev installation error on Edison
Hi, I'm getting an error while trying to install petsc-dev on Edison with GUN compilers. Attached below is configure.log and additional command line outputs.
module list -t Currently Loaded Modulefiles: modules/3.2.6.7 nsg/1.2.0 eswrap/1.1.0-1.020200.1130.0 switch/1.0-1.0502.51632.2.84.ari craype-network-aries craype/2.1.2 craype-ivybridge cray-shmem/7.0.0 cray-mpich/7.0.0 torque/4.2.7 moab/7.2.7-e7c070d1-b3-SUSE11 altd/1.0 darshan/2.3.0 usg-default-modules/1.1 gcc/4.9.0 cray-libsci/13.0.0 udreg/2.3.2-1.0502.8763.1.11.ari ugni/5.0-1.0502.9037.7.26.ari pmi/5.0.4-1.0000.10161.132.4.ari dmapp/7.0.1-1.0502.9080.9.32.ari gni-headers/3.0-1.0502.9038.7.4.ari xpmem/0.1-2.0502.51169.1.11.ari job/1.5.5-0.1_2.0502.52111.3.39.ari csa/3.0.0-1_2.0502.51200.1.108.ari alps/5.2.1-2.0502.8712.10.32.ari rca/1.0.0-2.0502.51491.3.92.ari atp/1.7.3 PrgEnv-gnu/5.2.25 cmake/2.8.11.2 cray-hdf5-parallel/1.8.13 mercurial/2.7.1
git clone https://bitbucket.org/petsc/petsc petsc.0c8c14c5 cd petsc.0c8c14c5 git checkout 0c8c14c5
cat config/configure-edison-gnu-4.9.0-debug.py #!/usr/bin/env python if __name__ == '__main__': import sys import os sys.path.insert(0, os.path.abspath('config')) import configure configure_options = [ '--with-cc=cc', '--with-cxx=CC', '--with-fc=ftn', '--with-ld=cc', '--with-cpp=cpp', '--with-shared-libraries=0', '--with-gnu-compilers=0', '--with-debugging=0', '--with-clanguage=c', '--with-x=0', '--with-clib-autodetect=0', '--with-fortranlib-autodetect=0', '--with-cxxlib-autodetect=0', '--COPTFLAGS="-O3 -msse3 -fPIC"', '--FOPTFLAGS="-O3 -msse3 -fPIC"', '--download-parmetis=1', '--download-metis=1', '--with-hdf5=1', '--with-hdf5-dir=/opt/cray/hdf5-parallel/1.8.13/GNU/49', '--with-mpi-dir=/opt/cray/mpt/7.0.0/gni/mpich2-gnu/49', '--with-c2html=0', '--PETSC_ARCH=edison-gnu-4.9.0-debug', ] configure.petsc_configure(configure_options)
Any ideas what is wrong? Thanks -Gautam.
participants (1)
Gautam Bisht
