Re: [petsc-dev] Dealing with off-processor aij-matrices not having preallocation information
On Thu, Mar 21, 2013 at 10:08 AM, Karl Rupp <[email protected]> wrote:
Yes, I want to preserve the behavior Barry described in 2), i.e.
only error if the user specified an allocation pattern explicitly. I'm only questioning the way it is currently implemented:
If the number of nonzeros is specified as PETSC_DECIDE to MatSeqAIJSetPreallocation___**SeqAIJ(), it does not set MAT_NEW_NONZERO_ALLOCATION___**ERR. If the number of
nonzeros is larger than zero, it does. So far, so good.
If nnz is nonnegative, yes.
right, it's actually nz >= 0.
MatMPIAIJSetPreallocation___**MPIAIJ(), however, first checks for the
number of nonzeros. If it is PETSC_DECIDE, it sets defaults and then calls MatSeqAIJSetPreallocation___**SeqAIJ() with the defaults. Because MatSeqAIJSetPreallocation___**SeqAIJ() no longer sees PETSC_DECIDE, it sets MAT_NEW_NONZERO_ALLOCATION___**ERR, which is then reset right after in MatMPIAIJSetPreallocation___**MPIAIJ(). The
CUSP-implementation does not reset the flag and thus leads to errors, even though the implementation of the CUSP-Preallocation routine looks perfectly fine. I rather want to fix the hack in MatMPIAIJSetPreallocation___**MPIAIJ() than to propagate it to the GPU
implementations as well.
I thought perhaps you were going to leave it to the _SeqAIJ parts to store the nonew state. If the _MPIAIJ part resolves PETSC_DECIDE independently from the _SeqAIJ part, then they have to *always* coincide exactly, otherwise we'll have very confusing bugs. You can likely forward PETSC_DECIDE down to the _SeqAIJ parts, then query a->nonew and b->nonew to set the mpiaij->nonew flag. (I'm not sure it's consistent now, but we want it to be consistent.)
There is no mpiaij->nonew flag in Mat_MPIAIJ, this is all handled in the two diagonal/off-processor matrices of type Mat_SeqAIJ. I don't want to change this ;-) I just want to resolve the way way a->nonew and b->nonew is set, so that it does not require a hack in MatMPIAIJSetPreallocation_**MPIAIJ().
A closer look showed three options: a) just forward PETSC_DECIDE to MatSeqAIJSetPreallocation_**SeqAIJ(), don't modify the nonew-flags from _MPIAIJ(). This almost fixes the problem, the only drawback is that the number of nonzeros on the off-processor blocks is then also 5 instead of 2 when using PETSC_DECIDE.
I vote a). No new function, gets rid of a stupid optimization that does no one any good, and is the simplest. Matt
b) Allow to pass default values to MatSeqAIJSetPreallocation_**SeqAIJ(). The cause of the issue is that MatSeqAIJSetPreallocation_**SeqAIJ() does two things: It interprets PETSC_DECIDE and it does the preallocation. If we split these two tasks into two functions, i.e.
- MatSeqAIJSetPreallocation_**SeqAIJ() for interpreting PETSC_DECIDE and dealing with nonew, then calling - MatSeqAIJSetPreallocation_**SeqAIJAlloc() for the actual preallocation
we can directly call MatSeqAIJSetPreallocation_**SeqAIJAlloc() from the _MPIAIJ() part and cleanly set MAT_NEW_NONZERO_ALLOCATION_ERR for the on- and off-processor matrices.
c) Improve the existing hack by querying the state of a->nonew and b->nonew before calling MatSeqAIJSetPreallocation_**SeqAIJ() and after that reset a user-defined state if necessary.
I'll create a pull request for b), as it is consistent with the current behavior and appears to be the cleanest solution to this.
Best regards, Karli
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
