Re: [petsc-dev] Testing seems broken in master
hm - indices are integers and its not ignored (i.e %d) - only the %f and %e diff is ignored (by default) Satish On Mon, 4 Jan 2021, Scott Kruger wrote:
Is this just the 3rd problem?
Regarding how you can end up with changes not being caught: The default (going all the way back to the old harness) is to not check numbers to avoid round-off errors giving false negatives (failures). Of course, sometimes you *want* to check the numbers; e.g., for indices.� The solution for this is to add:
���� diff_args: -j
Scott
On 12/31/20 4:40 PM, Barry Smith wrote:
� I think I have it "fixed" now in the branch, once it passes the pipeline I will shepard it through the MR quickly. Sorry about this, even all our CI testing can miss a great deal.
� Barry
On Dec 31, 2020, at 2:44 PM, Barry Smith <[email protected] <mailto:[email protected]>> wrote:
� This is a different (3rd) problem. Funny it didn't bother anyone for two months.
� Fix is in barry/2020-12-29/fix-petscdiff-bracket but the pipeline keeps failing ts_tutorials_advection-diffusion-reaction-ex3_2 fails on different machines with slightly different counts. I don't see how this change could cause that! But gets old results on my machine. Very frustrating. Barry
On Dec 31, 2020, at 1:02 PM, Matthew Knepley <[email protected] <mailto:[email protected]>> wrote:
On Thu, Dec 31, 2020 at 1:48 PM Barry Smith <[email protected] <mailto:[email protected]>> wrote:
� So the programs output changes and should no longer match that in the output/* file yet the test harness does not error with a statement that the two outputs do not match?
� �I noticed the gmakegentest.py is not being run before it runs the test? Does this mean it is just running all the old stuff which does match fine?
� �Then either how petscdiff is called by the test harness has changed or petscdiff has changed and does not detect changes anymore
� �BTW: I always use -f ./gmakefile.test test not just the gmakefile
� �All the PETSc changes are trivial and can be seen with a simple diff, it is hard to believe they would cause this behavior but I guess they must.
� �You can go to PETSC_ARCH/tests/snes/tests and run the ex13 shell script directly.
It is the sed problem:
master *$:/PETSc3/petsc/petsc-dev$ /PETSc3/petsc/petsc-dev/lib/petsc/bin/petscdiff /PETSc3/petsc/petsc-dev/src/snes/tests/output/ex13_bench.out ex13_bench.tmp
sed: 1: "s/\033[1;31m//g": unbalanced brackets ([]) sed: 1: "s/\033[0;39m\033[0;49m//g": unbalanced brackets ([]) sed: 1: "s/\033[1;31m//g": unbalanced brackets ([]) sed: 1: "s/\033[0;39m\033[0;49m//g": unbalanced brackets ([])
The error was getting eaten.
This is in current master. Is it fixed in a branch?
� �Matt
� Barry
On Dec 31, 2020, at 12:38 PM, Matthew Knepley <[email protected] <mailto:[email protected]>> wrote:
I just�pulled master, and simple alterations to tests do not produce a failure:
master *$:/PETSc3/petsc/petsc-dev$ PETSC_ARCH=arch-master-debug make -f ./gmakefile test search="snes_tests-ex13_bench" TIMEOUT=5000 EXTRA_OPTIONS="-dm_ refine 0" Using MAKEFLAGS: EXTRA_OPTIONS=-dm_refine 0 TIMEOUT=5000 search=snes_tests-ex13_bench � � � � TEST arch-master-debug/tests/counts/snes_tests-ex13_bench.counts �ok snes_tests-ex13_bench �ok diff-snes_tests-ex13_bench
I check that the runs produce different output when done manually.
Scott and Barry, could this be related to changed to testing?
� Thanks,
� � �Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/%7Eknepley/>
participants (1)
Satish Balay
