Re: [petsc-dev] install petsc on windows 10 with mpi
Off course. Which directory shoul i look for it? Get Outlook for Android<https://aka.ms/ghei36> From: Satish Balay Sent: Monday, February 6, 11:08 PM Subject: Re: [petsc-dev] install petsc on windows 10 with mpi To: Mohammad S Dodaran Cc: petsc-dev can you also send make.log? Satish On Mon, 6 Feb 2017, Mohammad S Dodaran wrote: > i was trying to repair my parallel_studio_xe_2017. then i configure it once again and then i tried to make with and without intel-mpi ENV . in both cases the error had been changed. i have attached the configure.log > > ________________________________ > From: Satish Balay > Sent: Monday, February 6, 2017 10:10:43 PM > To: Mohammad S Dodaran > Cc: petsc-dev > Subject: Re: [petsc-dev] install petsc on windows 10 with mpi > > Them Intel-MPI was not removed. You can resend configure.log to confirm.. > > Satish > > On Mon, 6 Feb 2017, Mohammad S Dodaran wrote: > > > I removed the INTEL-MPI from the environmental variables and I still have the same problem. When I configure it looks like it accepts the mpi_include and mpi_lib but when I want to build , it says the configure was with mpi but in build it appears to compile is using a non-mpich. > > > > Mohammad > > > > ________________________________ > > From: Satish Balay > > Sent: Monday, February 6, 2017 6:13:04 PM > > To: Mohammad S Dodaran > > Cc: petsc-dev > > Subject: Re: [petsc-dev] install petsc on windows 10 with mpi > > > > 1. configure.log is a cygwin simlink - so native mail app is unable to > > attach correctly. The actual file is in > > PETSC_DIR/PETSC_ARCH/lib/petsc/conf > > > > 2. Suggest doing the build without fftw and hdf5 packages [once the > > basic build succeeds - you can look at adding these pacakges.] > > > > 3. remove INTEL-MPI from your env - before running configure. [you > > might be able to use intel-mpi instead of ms-mpi - but we don't have > > any experience with it] > > > > Satish > > > > On Mon, 6 Feb 2017, Mohammad S Dodaran wrote: > > > > > now I'm trying to configure petsc 3.7 > > > i used the format you showd in your previous email for the directories of fftw and hdf5 as below > > > > > > --with-fftw-dir=/cygdrive/c/cygwin64/home/fftw --with-hdf5-dir=/cygdrive/c/cygwin64/home/hdf5 > > > > > > the result is the following > > > > > > TESTING: alternateConfigureLibrary from config.packages.glut(config/BuildSystem/config/package.py:742) TESTING: alternateConfigureLibrary from config.packages.giflib(config/BuildSystem/config/package.py:742) TESTING: alternateConfigureLibrary from config.packages.scientificpython(config/BuildSystem/config/package.py:742) TESTING: alternateConfigureLibrary from config.packages.fiat(config/BuildSystem/config/package.py:742) TESTING: configureLibrary from config.packages.fftw(config/BuildSystem/config/package.py:679) ******************************************************************************* > > > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details): > > > ------------------------------------------------------------------------------- > > > --with-fftw-dir=/cygdrive/c/cygwin64/home/fftw did not work > > > ******************************************************************************* > > > > > > i also attached the configure.log > > > > > > > > > ________________________________ > > > From: Satish Balay > > > Sent: Monday, February 6, 2017 4:28:09 PM > > > To: Mohammad S Dodaran > > > Cc: Matthew Knepley; petsc-dev > > > Subject: Re: [petsc-dev] install petsc on windows 10 with mpi > > > > > > >>>> > > > > > > Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-cc="win32fe cl" --with-fc="win32fe ifort" --with-cxx="win32fe cl" --with-mpi-include="[/cygdrive/c/PROGRA~2/MICROS~4/MPI/Include,/cygdrive/c/PROGRA~2/MICROS~4/MPI/Include/x64]" --with-mpi-lib="[/cygdrive/c/PROGRA~2/MICROS~4/MPI/Lib/x64/msmpi.lib,/cygdrive/c/PROGRA~2/MICROS~4/MPI/Lib/x64/msmpifec.lib]" --with-fftw-dir="[/cygdrive/c/cygwin64/home/fftw]" --with-hdf5-dir="[/cygdrive/c/cygwin64/home/hdf5]" --download-fblaslapack=1 --with-c2html=0 --with-debugging=0 --with-ssl=0 --with-x=0 PETSC_ARCH= PETSC_DIR=/home/petsc-3.6.4 > > > <<<< > > > > > > > 'PETSC_ARCH=' > > > > > > Can you rerun with a non-empty PETSC_ARCH string - or let configure choost default.. > > > > > > > --with-fftw-dir="[/cygdrive/c/cygwin64/home/fftw]" --with-hdf5-dir="[/cygdrive/c/cygwin64/home/hdf5]" > > > > > > I don't think I've built these packages with MS compilers > > > before. Somehow they are not picked up anyway. For one - the format > > > here should be the following [but I don't know if that will make > > > configure check for them]: > > > > > > --with-fftw-dir=/cygdrive/c/cygwin64/home/fftw --with-hdf5-dir=/cygdrive/c/cygwin64/home/hdf5 > > > > > > > PETSC_DIR=/home/petsc-3.6.4 > > > > > > Also - please use latest petsc-3.7 release. > > > > > > > C:\cygwin64\home\PETSC-~1.4\include\petscsys.h(122) : fatal error C1189: #error : "PETSc was configured with MPICH but > > > > now appears to be compiling using a non-MPICH mpi.h" > > > > > > Hm - configure is picking up Intel-MPI from your 'INCLUDE' env > > > variable - but not 'make' - not sure whats hapenning - but I think its > > > best to start a clean build with petsc-3.7 [unless you need 3.6 for a > > > specific need] > > > > > > Satish > > > > > > On Mon, 6 Feb 2017, Mohammad S Dodaran wrote: > > > > > > > hello > > > > > > > > > > > > i configured petsc and i was trying to make then this error appeared > > > > > > > > > > > > Using mpiexec: mpiexec > > > > ========================================== > > > > Building PETSc using GNU Make with 4 build threads > > > > ========================================== > > > > make[2]: Entering directory '/home/petsc-3.6.4' > > > > /usr/bin/python ./config/gmakegen.py --petsc-arch=../petsc-3.6.4 > > > > Use "/usr/bin/make V=1" to see the verbose compile lines. > > > > CC ../petsc-3.6.4/obj/src/sys/info/verboseinfo.o > > > > CC ../petsc-3.6.4/obj/src/sys/info/ftn-auto/verboseinfof.o > > > > CC ../petsc-3.6.4/obj/src/sys/info/ftn-custom/zverboseinfof.o > > > > CC ../petsc-3.6.4/obj/src/sys/ftn-custom/zsys.o > > > > verboseinfo.c > > > > C:\cygwin64\home\PETSC-~1.4\include\petscsys.h(122) : fatal error C1189: #error : "PETSc was configured with MPICH but > > > > now appears to be compiling using a non-MPICH mpi.h" > > > > make[2]: *** [gmakefile:161: ../petsc-3.6.4/obj/src/sys/info/verboseinfo.o] Error 2 > > > > make[2]: *** Waiting for unfinished jobs.... > > > > verboseinfof.c > > > > C:\cygwin64\home\PETSC-~1.4\include\petscsys.h(122) : fatal error C1189: #error : "PETSc was configured with MPICH but > > > > now appears to be compiling using a non-MPICH mpi.h" > > > > make[2]: *** [gmakefile:161: ../petsc-3.6.4/obj/src/sys/info/ftn-auto/verboseinfof.o] Error 2 > > > > zverboseinfof.c > > > > C:\cygwin64\home\PETSC-~1.4\include\petscsys.h(122) : fatal error C1189: #error : "PETSc was configured with MPICH but > > > > now appears to be compiling using a non-MPICH mpi.h" > > > > make[2]: *** [gmakefile:161: ../petsc-3.6.4/obj/src/sys/info/ftn-custom/zverboseinfof.o] Error 2 > > > > zsys.c > > > > C:\cygwin64\home\PETSC-~1.4\include\petscsys.h(122) : fatal error C1189: #error : "PETSc was configured with MPICH but > > > > now appears to be compiling using a non-MPICH mpi.h" > > > > make[2]: *** [gmakefile:161: ../petsc-3.6.4/obj/src/sys/ftn-custom/zsys.o] Error 2 > > > > make[2]: Leaving directory '/home/petsc-3.6.4' > > > > make[1]: *** [/home/petsc-3.6.4/lib/petsc/conf/rules:107: gnumake] Error 2 > > > > make[1]: Leaving directory '/home/petsc-3.6.4' > > > > **************************ERROR************************************* > > > > Error during compile, check ../petsc-3.6.4/lib/petsc/conf/make.log > > > > Send it and ../petsc-3.6.4/lib/petsc/conf/configure.log to [email protected] > > > > ******************************************************************** > > > > make: *** [makefile:30: all] Error 1 > > > > > > > > i have also attached the configure.log and make.log > > > > > > > > regards > > > > Mohammad > > > > > > > > > > > > > > > > ________________________________ > > > > From: Matthew Knepley > > > > Sent: Monday, February 6, 2017 8:07:41 AM > > > > To: Mohammad S Dodaran > > > > Cc: petsc-dev > > > > Subject: Re: [petsc-dev] install petsc on windows 10 with mpi > > > > > > > > On Sun, Feb 5, 2017 at 11:26 PM, Mohammad S Dodaran > wrote: > > > > > > > > Satish, > > > > > > > > Thanks for your quick response. as you see I can ls to the directory: > > > > > > > > ls /cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Include/ > > > > > > > > Yes, but as Satish said, there are spaces in the path above. We do not allow spaces in the path. > > > > You cannot give a path to configure with spaces. > > > > > > > > You can remove the spaces using the cygpath command that Satish showed. Please use that command. > > > > Remove the spaces from this path and give the spaceless path to configure. > > > > > > > > Thanks, > > > > > > > > Matt > > > > > > > > mpi.f90 mpi.h mpif.h mpio.h mspms.h pmidbg.h x64/ x86/ > > > > > > > > > > > > > > > > but I do not know why still it has the same problem. and my configure file looks strange. > > > > > > > > Best, > > > > > > > > Mohammad > > > > > > > > ________________________________ > > > > From: Satish Balay > > > > > Sent: Sunday, February 5, 2017 10:58:35 PM > > > > To: Mohammad S Dodaran > > > > Cc: [email protected] > > > > Subject: Re: [petsc-dev] install petsc on windows 10 with mpi > > > > > > > > Try to figureout path without spaces. > > > > > > > > cygpath -u `cygpath -s -m PATH` > > > > > > > > Make sure you can do "ls" on this path. > > > > > > > > And use it with petsc configure. > > > > > > > > balay@ps4 ~ > > > > $ cygpath -u `cygpath -s -m /cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Include` > > > > /cygdrive/c/PROGRA~2/MICROS~2/MPI/Include > > > > > > > > balay@ps4 ~ > > > > $ ls /cygdrive/c/PROGRA~2/MICROS~2/MPI/Include > > > > mpi.f90 mpi.h mpif.h mpio.h mspms.h pmidbg.h x64 x86 > > > > > > > > balay@ps4 ~ > > > > $ > > > > > > > > For ex: - I use: > > > > > > > > >>>>>>>> > > > > $ cat config/examples/arch-mswin-intel.py > > > > #!/usr/bin/python > > > > if __name__ == '__main__': > > > > import sys > > > > import os > > > > sys.path.insert(0, os.path.abspath('config')) > > > > import configure > > > > configure_options = [ > > > > '--download-fblaslapack=1', > > > > '--with-cc=win32fe icl', > > > > '--with-cxx=win32fe icl', > > > > '--with-fc=win32fe ifort', > > > > '--with-mpi-include=[/cygdrive/c/PROGRA~2/MICROS~2/MPI/Include/,/cygdrive/c/PROGRA~2/MICROS~2/MPI/Include/x64]', > > > > '--with-mpi-lib=[/cygdrive/c/PROGRA~2/MICROS~2/MPI/lib/x64/msmpifec.lib,/cygdrive/c/PROGRA~2/MICROS~2/MPI/lib/x64/msmpi.lib]', > > > > '--with-mpiexec=/cygdrive/c/PROGRA~1/MICROS~2/Bin/mpiexec', > > > > '--with-shared-libraries=0', > > > > 'DATAFILESPATH=c:/cygwin64/home/petsc/datafiles', > > > > ] > > > > configure.petsc_configure(configure_options) > > > > > > > > <<<<<<<<<<< > > > > > > > > if you still have issues - send us configure.log for the failure. > > > > > > > > Satish > > > > > > > > On Sun, 5 Feb 2017, Mohammad S Dodaran wrote: > > > > > > > > > Dear Petsc developers, > > > > > > > > > > I am trying to install Petsc on windows 10 but I have a problem. I installed MS-MPI v8 separately and in the configure options I use > > > > > > > > > > --with-mpi-include="/cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Include" --with-mpi-lib="/cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Lib/x64/msmpi.lib" > > > > > > > > > > > > > > > But it gives error which says: > > > > > > > > > > *************************************************************** > > > > > ERROR in COMMAND LINE ARGUMENT to ./configure > > > > > ------------------------------------------------------------------------------- > > > > > Invalid directory: [/cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Include for key with-mpi-include > > > > > > > > > > > > > > > How should I solve it? > > > > > > > > > > Mohammad > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. > > > > -- Norbert Wiener > > > > > > > > > > > > > > > >
participants (1)
Mohammad S Dodaran
