Re: [petsc-dev] 4.2 and PETSc
send build logs to petsc-maint. satish On Fri, 27 Apr 2012, Daniel Lowell wrote:
Even with the new build system I still had to go through and eliminate the -g3 in petscvariables
CC_FLAGS = -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 PCC_LINKER_FLAGS = -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 PCC_FLAGS = -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0
On Mon, Apr 23, 2012 at 4:43 PM, Daniel Lowell <[email protected]> wrote:
Sending the make.log to petsc-maint now.
On Mon, Apr 23, 2012 at 4:38 PM, Satish Balay <[email protected]> wrote:
but you missed copy/pasting the actual compile command. So incomplete info here..
satish
On Mon, 23 Apr 2012, Daniel Lowell wrote:
I added -v in the local folder's makefile to produce verbose output.
On Mon, Apr 23, 2012 at 4:33 PM, Satish Balay <[email protected]> wrote:
Hm - we've seen these errors with -g3 but not with -g. Are you sure there is no '-g3' somewhere on the compile command?
With latest petsc-dev/buildsystem one should not see -g3 [set by configure]
Also - why is there 'cicc' in a petsc build?
Satish
Hi all,
Has anyone run into any problems with NVCC 4.1 or .42 on PETSc with arch=sm_20? I have having real issues with it. I keep getting this:
#$ cicc -arch compute_20 -m64 -ftz=0 -prec_div=1 -prec_sqrt=1 -fmad=1 -g -O0 "/tmp/tmpxft_00000b8b_00000000-10_vecgpu" "/tmp/tmpxft_00000b8b_00000000-7_vecgpu.cpp3.i" -o "/tmp/tmpxft_00000b8b_00000000-2_vecgpu.ptx" <built-in>(2): error: "__STDC_HOSTED__" is predefined; attempted redefinition ignored
<built-in>(8): error: "__WCHAR_TYPE__" is predefined; attempted redefinition ignored
<built-in>(115): error: "__x86_64" is predefined; attempted redefinition ignored
<built-in>(116): error: "__x86_64__" is predefined; attempted redefinition ignored
<built-in>(126): error: "__linux__" is predefined; attempted redefinition ignored
<built-in>(128): error: "__unix__" is predefined; attempted redefinition ignored
6 errors detected in the compilation of "/tmp/tmpxft_00000b8b_00000000-7_vecgpu.cpp3.i". # --error 0x1 --
4.0 works fine, no issues. 4.0 version uses the older nvopencc, in 4.1 and 4.2 they use something called cicc, for target architecture sm_2x. Of course it does no mention cicc in the updated nvcc documentation at all.
Tried 4.2 with GCC 4.3 and 4.4 without any difference in behavior.
PETSc configuration script:
MPI_DIR="--with-mpi-dir=$MPICH2_HOME" LAD="--download-f-blas-lapack=yes" CUD="--with-cuda-dir=/soft/cuda-4.2/cuda" ./config/configure.py $MPI_DIR $LAD $CUD \ --with-debugging=1 \ --with-cudac="nvcc -m64 -g -G" \ --with-precision=double \ --with-clanguage=c \ --with-cuda-arch=sm_20
-- Daniel Lowell
participants (1)
Satish Balay
