Re: [petsc-dev] Fwd: [ideas-xsdk] common configure/cmake arguments for XSDK packages ready for testing
Barry Smith <[email protected]> writes:
Now change the compiler to something else from Cray and run again.
Starting with PrgEnv-gnu: jedbrow@edison01:~> env | grep MODULE > PrgEnv-gnu.txt jedbrow@edison01:~> module swap PrgEnv-{gnu,cray} jedbrow@edison01:~> env | grep MODULE > PrgEnv-cray.txt jedbrow@edison01:~> diff PrgEnv-* 3d2 < FORTRAN_SYSTEM_MODULE_NAMES=ftn_lib_definitions 10c9 < LOADEDMODULES=modules/3.2.6.7:nsg/1.2.0:eswrap/1.1.0-1.020200.1130.0:switch/1.0-1.0502.54233.2.96.ari:craype-network-aries:craype-ivybridge:cray-shmem/7.0.4:cray-mpich/7.0.4:torque/4.2.7:moab/7.2.7-e7c070d1-b3-SUSE11:altd/2.0:darshan/2.3.0:usg-default-modules/1.1:mercurial/3.2:python_base/2.7.5:numpy/1.7.1:scipy/0.12.0:matplotlib/1.3.0:ipython/1.1.0:python/2.7.5:cmake/2.8.11.2:craype/2.2.1:cce/8.3.4:cray-libsci/13.0.1:udreg/2.3.2-1.0502.9275.1.12.ari:ugni/5.0-1.0502.9685.4.24.ari:pmi/5.0.5-1.0000.10300.134.8.ari:dmapp/7.0.1-1.0502.9501.5.219.ari:gni-headers/3.0-1.0502.9684.5.2.ari:xpmem/0.1-2.0502.55507.3.2.ari:dvs/2.5_0.9.0-1.0502.1873.1.145.ari:alps/5.2.1-2.0502.9041.11.6.ari:rca/1.0.0-2.0502.53711.3.127.ari:atp/1.7.5:PrgEnv-cray/5.2.40 ---
LOADEDMODULES=modules/3.2.6.7:nsg/1.2.0:eswrap/1.1.0-1.020200.1130.0:switch/1.0-1.0502.54233.2.96.ari:craype-network-aries:craype/2.2.1:craype-ivybridge:cray-shmem/7.0.4:cray-mpich/7.0.4:torque/4.2.7:moab/7.2.7-e7c070d1-b3-SUSE11:altd/2.0:darshan/2.3.0:usg-default-modules/1.1:mercurial/3.2:python_base/2.7.5:numpy/1.7.1:scipy/0.12.0:matplotlib/1.3.0:ipython/1.1.0:python/2.7.5:cmake/2.8.11.2:gcc/4.9.1:cray-libsci/13.0.1:udreg/2.3.2-1.0502.9275.1.12.ari:ugni/5.0-1.0502.9685.4.24.ari:pmi/5.0.5-1.0000.10300.134.8.ari:dmapp/7.0.1-1.0502.9501.5.219.ari:gni-headers/3.0-1.0502.9684.5.2.ari:xpmem/0.1-2.0502.55507.3.2.ari:dvs/2.5_0.9.0-1.0502.1873.1.145.ari:alps/5.2.1-2.0502.9041.11.6.ari:rca/1.0.0-2.0502.53711.3.127.ari:atp/1.7.5:PrgEnv-gnu/5.2.40
In this case, it might be more reliable to compare "cc --version". Modules was never intended as a robust solution. It was a disgusting hack that probably seemed okay at the time, but ended up as an established methodology and now we have to live with its many points of failure, horrible debugability, and lack of an API.
participants (1)
Jed Brown
