Re: [petsc-dev] no petsc on Edison
2 Feb
2 Feb
'17
2:43 p.m.
On Thu, Feb 2, 2017 at 12:02 PM, Stefano Zampini <[email protected]> wrote:
Mark,
I saw your configuration has hypre. If you could run with master, you may try -matptap_via hypre.
This is worth trying. Does this even work with GAMG? Treb: try hypre anyway. It has its own RAP code.
It uses BoomerAMGBuildCoarseOperator directly with the AIJ matrices.
Stefano
On Feb 2, 2017, at 7:28 PM, Mark Adams <[email protected]> wrote:
On Thu, Feb 2, 2017 at 11:13 AM, Hong <[email protected]> wrote:
Mark: Try '-matmatmult_via scalable' first. If this works, should we set it as default?
If it is robust I would say yes unless it is noticeably slower (say >20%) small scale problems.
3477
Age (days ago)
3477
Last active (days ago)
0 comments
1 participants
participants (1)
Mark Adams
