Re: [petsc-dev] [EXTERNAL] Re: building on Fugaku
Sarat, is there anything special that you do for Kokkos - OpenMP? Just set OMP_NUM_THREADS=48 ? Also, I am confused about the number of cores here. Is 48 or 64 per node/socket? On Fri, Apr 16, 2021 at 2:03 PM Mark Adams <[email protected]> wrote:
Cool, I have it running too. Need to add Sarat's flags and test ex2.
On Fri, Apr 16, 2021 at 1:57 PM Satish Balay via petsc-dev < [email protected]> wrote:
Mark,
The following build works for me:
Satish
pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "elapse=1:00:00" --sparam "wait-time=1200"
. /vol0004/apps/oss/spack/share/spack/setup-env.sh spack load fujitsu-mpi%gcc spack load [email protected] arch=linux-rhel8-a64fx ./configure COPTFLAGS='-Ofast -march=armv8.2-a+sve -msve-vector-bits=512' CXXOPTFLAGS='-Ofast -march=armv8.2-a+sve -msve-vector-bits=512' FOPTFLAGS='-Ofast -march=armv8.2-a+sve -msve-vector-bits=512' --with-openmp=1 --download-p4est --download-zlib --download-kokkos --download-kokkos-kernels --download-kokkos-commit=origin/develop --download-kokkos-kernels-commit=origin/develop '--download-kokkos-cmake-arguments=-DBUILD_TESTING=OFF -DKokkos_ENABLE_LIBDL=OFF -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON' --download-cmake= https://github.com/Kitware/CMake/releases/download/v3.20.1/cmake-3.20.1.tar.... --download-fblaslapack=1 make PETSC_DIR=/vol0004/ra010009/a04201/petsc.z PETSC_ARCH=arch-linux-c-debug all
To test - redo job allocation using max-proc-per-node:
login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "elapse=1:00:00" --sparam "wait-time=1200" --mpi "max-proc-per-node=16"
[a04201@c31-3201c petsc.z]$ . /vol0004/apps/oss/spack/share/spack/setup-env.sh [a04201@c31-3201c petsc.z]$ spack load fujitsu-mpi%gcc [a04201@c31-3201c petsc.z]$ spack load [email protected] arch=linux-rhel8-a64fx [a04201@c31-3201c petsc.z]$ make check Running check examples to verify correct installation Using PETSC_DIR=/vol0004/ra010009/a04201/petsc.z and PETSC_ARCH=arch-linux-c-debug C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes C/C++ example src/snes/tutorials/ex3k run successfully with kokkos-kernels Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI process Completed test examples [a04201@c31-3201c petsc.z]$
participants (1)
Mark Adams
