On Tue, Feb 7, 2012 at 11:50 PM, Jed Brown <[email protected]> wrote:
On Wed, Feb 8, 2012 at 04:19, Peter Brune <[email protected]> wrote:
On Tue, Feb 7, 2012 at 6:40 PM, Jed Brown <[email protected]> wrote:
Suppose I want to solve a finite time step problem using FAS. The time step will be defined something like
static PetscErrorCode SNESTSFormFunction_ARKIMEX(SNES snes,Vec X,Vec F,TS ts) { TS_ARKIMEX *ark = (TS_ARKIMEX*)ts->data; PetscErrorCode ierr;
PetscFunctionBegin; ierr = VecAXPBYPCZ(ark->Ydot,-ark->shift,ark->shift,0,ark->Z,X);CHKERRQ(ierr); /* Ydot = shift*(X-Z) */ ierr = TSComputeIFunction(ts,ark->stage_time,X,ark->Ydot,F,ark->imex);CHKERRQ(ierr); PetscFunctionReturn(0); }
where ark->Z was determined from previous stages and ark->Ydot is a work vector. So FAS creates some hierarchy, but it isn't very forthcoming about showing the hierarchy to the user. But I need a way to
1. Restrict ark->Z to the coarse level and obtain the work vector ark->Ydot somewhere that I can reuse it. The user might also have to restrict "auxiliary" variables to coarse grids. It's conceivable that they would want to do this in a different way from the restriction/prolongation for the solution variables. For example, if you were using upwinded R and P for a hyperbolic problem, but you needed to restrict coefficients (like bathymetry). Or they might want to sample differently out of some file. So I think we need an auxiliary transfer callback that is at least called every top-level SNESSolve() and optionally also called in every transfer (because it could be homogenizing coefficient structure that is a nonlinear function of state).
The restriction (injection, etc) might be one step too hard at this point. We have to define the problem at each level in FAS and grid sequencing so we might as well make it easy. Is it possible to have the callback for the SNES point to things that have to be prolonged or restricted? This could be called both before FAS and before grid sequencing to get the coefficients up to the next level. We could provide some sort of default that goes through a number of user-provided vectors on a level given vectors on another level, and inject them. A user with user-created multilevel coefficients could provide their own similar callbacks.
So coefficients usually won't live on the same DM as the solution. This case with TS is easier in that regard, but it can't be the sole driver of design. There needs to be a general function to perform level setup.
^^^^^^^^^^^^^^^^^^^^^^^^ I just want to point out that Jed envisions that coefficients (and maybe subproblems, etc) cannot be accommodated on the same DM. I agree. However, this silly idea that we can make DMs all over the place with no cost, like DAs, if they contain all the mesh information, is just wrong. I think this is a good argument for having both a topology object and a DM handling layout/solver information. What is the counter-argument? Matt
/* called by SNESSetUp_FAS() before restricting a nonlinear solution to a coarser level (but usually only used the first time unless this is doing solution-dependent homogenization) */ typedef PetscErrorCode (*SNESFASRestrictHook)(SNES fine,Vec Xfine,SNES coarse); PetscErrorCode SNESFASSetRestrictHook(SNES fine,SNESFASRestrictHook hook,void *ctx);
/* called in SNESSolve() each time a new solution is prolongated */ typedef PetscErrorCode (*SNESGridSequenceInterpolateHook)(SNES coarse,Vec Xcoarse,SNES fine); PetscErrorCode SNESGridSequenceSetInterpolateHook(SNES coarse,SNESGridSequenceInterpolateHook hook,void *ctx);
I think we also need to add state to DMCreateInterpolation() so that we can make it nonlinear when appropriate.
2. Put the DM from this SNES into the TS that calls the user's IFunction. The easiest way is to have TSPushDM(TS,DM) that just jams it in there, caching the old DM (so the user's call to TSGetDM() works correctly), and TSPopDM(TS). This is ugly and is scary if the user does something weird like TSGetSolution() (returning the state at the beginning of the step, not the current value at the stage). This is something that doesn't make semantic sense except maybe if they have some weird diagnostics, but TSGetIJacobian() might be used for caching, and I'm scared of the semantics it would involve to support this sort of caching.
This option seems like it would be scary complex. I don't like it.
I think it's likely simpler than the others, at least as a first implementation. I'm not wild about it either, but I'm not sure the alternatives are better.
The alternative is to make different TSs for each level and somehow locate the correct TS (maybe cache it in the SNES hierarchy). I think this could be quite confusing to restrict all the members to the coarse grid. But having a multi-level TS object may eventually be sensible because multilevel time integration schemes exist. Spectral deferred correction is one example where coarse grids (in space and time) can be used to accelerate convergence to a high-order solution. But these somewhat naturally expose additional parallelism in time (usually more communication, but also more concurrency), so it likely needs a more complete solution that includes ways to instantiate entire models on sub-communicators (we'll also want an interface of this type for UQ).
I'm not sure this would be harmonious with FAS given the coarse problem is redefined with a defect from the fine problem (making a FAS cycle on a actual fine solution do nothing) at each stage. As I understand it, we'd need a "real" time derivative rather than a derivative of the defect problem. Therefore, we would be stuck solving at each level and using each level for FAS independently.
Multilevel time integration would involve having a fully functional TS on each level, each of which may or may not use FAS. A conventional time integration scheme solved by FAS need these things with type TS to pass to the user, that implement TSGetDM() and perhaps some similar functionality. They also need the affine vectors to define the residual.
Maybe it would be better to make a little container that was basically just a struct, but masqueraded as a TS.
However, having a multilevel time integration scheme outside of FAS accessible to FAS to accelerate solution might be an interesting project; are there references? Would this look like grid sequencing + FAS with the grid sequence solutions moved forward in time?
Hmm, I haven't seen anything really like that, but note that the stability threshold for explicit methods is larger on coarse levels.
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
