21 Apr
21 Apr
'11
1:07 a.m.
If you've pulled petsc-dev in the past couple of hours - you might have some hg errors like:
not updating, since new heads added (run 'hg heads' to see heads, 'hg merge' to merge) <<<<<<
If so - suggest doing: hg rollback [or alternatively] mv petsc-dev petsc-dev.old hg clone petsc-dev.old petsc-dev -r d3e10315d68b cp petsc-dev.old/.hg/hgrc petsc-dev/.hg/hgrc I've manually removed this bad state from petsc.cs.iit.edu/petsc/petsc-dev - so if you pull now - its ok [i.e you won't see the 2 heads with 'hg heads'] Satish
5591
Age (days ago)
5591
Last active (days ago)
0 comments
1 participants
participants (1)
Satish Balay
