Re: Why did you removed PETSC_ARCH_NAME variable in makefiles?
Lisandro, That change will certainly NOT be reverted. PETSC_ARCH_NAME! what the heck kind of variable name is that? I need to understand the reason for PETSC_ARCH_NAME, then we can come up with some solution. What is the difference between PETSC_ARCH_NAME and PETSC_ARCH? Is it only needed when --prefix is used (so PETSC_ARCH does not exist), if so, exactly why is it needed, the whole idea behind --prefix is to eliminate PETSC_ARCH, so why is it needed? How is PETSC_ARCH_NAME used? Barry On Nov 25, 2009, at 10:14 AM, Lisandro Dalcin wrote:
Barry, an outcome of the two changesets below:
changeset: 14451:b289577caf8f user: [email protected] date: Mon Oct 19 16:31:16 2009 -0500 summary: update to install.py to ONLY use RDict.db (and not command line)
changeset: 14383:447d34bd2d4b user: [email protected] date: Thu Oct 08 16:33:59 2009 -0500 summary: finished cleaning up makefiles, moved charactoristic.h to include location standard place where it is easy to use
was that these two lines in config/PETSc/utilities/arch.py were removed:
# SLEPc configure need this info self.addMakeMacro('PETSC_ARCH_NAME',self.arch)
SLEPc and petsc4py/slepc4py/tao4py relies on this variable being defined in makefiles. There is now a new way to get the original name of the build-time $PETSC_ARCH? If not, any chance this change could be reverted?
-- Lisandro Dalcín --------------- Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC) Instituto de Desarrollo Tecnológico para la Industria Química (INTEC) Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET) PTLC - Güemes 3450, (3000) Santa Fe, Argentina Tel/Fax: +54-(0)342-451.1594
participants (1)
Barry Smith
