Re: [petsc-dev] Compiling C code with C compiler
4 Apr
4 Apr
'11
9:22 p.m.
On Mon, 4 Apr 2011, Sean Farley wrote:
But why would I do that? The whole point of invoking 'clang++' is to to compile the code as 'C++' - not as 'C'
Why not try to compile C code with a C compiler and C++ code with a C++ compiler? (Perhaps I missed a previous discussion?)
What did you expect when you used --with-clanguage=C++ for your buid? Or were you misunderstanding what this options means wrt PETSc build? Satish
Dmitry brought up an interesting question of which I don't know the answer off the top of my head.
Dmitry, is there a small code example that shows this?
Sean
5607
Age (days ago)
5607
Last active (days ago)
0 comments
1 participants
participants (1)
Satish Balay
