Re: [petsc-dev] error reading binary file
On Wed, Jun 13, 2012 at 3:45 AM, Mark F. Adams <[email protected]>wrote:
I thought there would be a -vec_block_size option, but alas its missing.
Can you check in the debugger
when the block size is getting set? I cannot find it in VecSetFromOptions().
Its in the stack trace right?
That is the second time, I want the first. Matt
Thanks, mark
[0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: PetscLayoutSetBlockSize() line 460 in /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pmap.c [0]PETSC ERROR: VecSetBlockSize() line 1526 in /Users/markadams/Codes/petsc-dev/src/vec/vec/interface/vector.c [0]PETSC ERROR: VecLoad_Binary() line 104 in /Users/markadams/Codes/petsc-dev/src/vec/vec/utils/vecio.c [0]PETSC ERROR: VecLoad_Default() line 348 in /Users/markadams/Codes/petsc-dev/src/vec/vec/utils/vecio.c [0]PETSC ERROR: VecLoad() line 1111 in /Users/markadams/Codes/petsc-dev/src/vec/vec/interface/vector.c [0]PETSC ERROR: main() line 132 in src/ksp/ksp/examples/tutorials/ex10.c
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
