Re: [petsc-dev] help on Summit
OK, Stefano got this to build. I now get this error. We had this before and thought that you needed to run the GPU aware MPI off. The test failed in make without PETSC_OPTIONS='-use_gpu_aware_mpi 0'. After adding this I get a runtime error. So my PETSC_OPTIONS did seem to work. Treb, maybe this will work for you. This might be from our testing makefile. 17:14 stefanozampini/hypre-gpu> /gpfs/alpine/csc314/scratch/adams/petsc2$ *export PETSC_OPTIONS='-use_gpu_aware_mpi 0'* 17:15 stefanozampini/hypre-gpu> /gpfs/alpine/csc314/scratch/adams/petsc2$ make PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc2 PETSC_ARCH=arch-summit-hypre-cuda-dbg2 *-f gmakefile.test test search='ksp_ksp_tutorials-ex4_hypre_device'* Using MAKEFLAGS: -- search=ksp_ksp_tutorials-ex4_hypre_device PETSC_ARCH=arch-summit-hypre-cuda-dbg2 PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc2 TEST arch-summit-hypre-cuda-dbg2/tests/counts/ksp_ksp_tutorials-ex4_hypre_device.counts ok ksp_ksp_tutorials-ex4_hypre_device+nsize-1 ok diff-ksp_ksp_tutorials-ex4_hypre_device+nsize-1 not ok ksp_ksp_tutorials-ex4_hypre_device+nsize-2 # Error code: 1 # [1] (1117677) Warning: Could not find key lid0:0:2 in cache <========================= # [1] (1117677) Warning: Could not find key qpn0:0:0:2 in cache <========================= # Unable to connect queue-pairs # [g13n10:1117677] Error: common_pami.c:1094 - ompi_common_pami_init() 1: Unable to create 1 PAMI communication context(s) rc=1 # -------------------------------------------------------------------------- # No components were able to be opened in the pml framework. # # This typically means that either no components of this type were # installed, or none of the installed components can be loaded. # Sometimes this means that shared libraries required by these # components are unable to be found/loaded. # # Host: g13n10 # Framework: pml # -------------------------------------------------------------------------- # [g13n10:1117677] PML pami cannot be selected ok ksp_ksp_tutorials-ex4_hypre_device # SKIP Command failed so no diff # FAILED ksp_ksp_tutorials-ex4_hypre_device+nsize-2 # # To rerun failed tests: # /usr/bin/gmake -f gmakefile test test-fail=1 On Mon, Aug 30, 2021 at 3:35 PM Mark Adams <[email protected]> wrote:
I see you have an MR. Should I try these changes in my repo?
On Mon, Aug 30, 2021 at 3:32 PM Mark Adams <[email protected]> wrote:
I am in a branch of Stefano's and a user wants this for a milestone asap. Maybe you can send me the fix and I can add it manually. My branch is in a funny "main<>" state and I'm not sure how to pull, etc., without Stefano. Thanks, Mark
On Mon, Aug 30, 2021 at 3:28 PM Jacob Faibussowitsch <[email protected]> wrote:
That did not seem to work.
So gcc didn’t ignore the hand-coded definitions in src/sys/objects/device/interface/cupminterface.cxx
See https://gitlab.com/petsc/petsc/-/merge_requests/4271 where I swap constexpr for const and see if it works.
Best regards,
Jacob Faibussowitsch (Jacob Fai - booss - oh - vitch)
15:09 main<> /gpfs/alpine/csc314/scratch/adams/petsc2$ mpicc --version gcc (GCC) 9.1.0 Copyright (C) 2019 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
I have read "GCC 8.x (and later) fully supports all of C++17."
On Mon, Aug 30, 2021 at 3:07 PM Jacob Faibussowitsch < [email protected]> wrote:
Yeah I suppose so, all the values we alias are integral types so static const should have equivalent compile-time assurance as constexpr.
Best regards,
On Aug 30, 2021, at 13:44, Junchao Zhang <[email protected]> wrote:
Can you use less fancy 'static const int'? --Junchao Zhang
On Mon, Aug 30, 2021 at 1:02 PM Jacob Faibussowitsch < [email protected]> wrote:
No luck with C++14
TL;DR: you need to have host and device compiler either both using c++17 or neither using c++17.
Long version: C++17 among other things changed how static constexpr member variables for classes worked. Previously if I had a class with a static constexpr member variable I would have to not only declare it inline within the class, but also define it within an executable otherwise the variable would not actually have any physical memory address:
// foo.hpp class foo { static constexpr int bar = 5; };
// foo.cpp int foo::bar;
In c++17 however this changed because you can have static “inline” variables. All this does is force the compiler define the variable for you instead. The issue of course is that static constexpr implicitly makes that variable inline in c++17. So to sum it up:
1. The c++17 compiler (nvcc) sees the static constexpr variable, goes “hmm ok I will define this in some undefined location”. 2. The c++11/14 compiler comes along, sees your hand-coded definition of the variable and goes “ah but I think I’ve seen this before, I’ll ignore it”. This silent rejection is due to the hand-coded definition idiom being deprecated from c++17 onwards. Stupid, I know. 2. The linker (driven by the c++11/14 compiler since PETSc links using the host compiler) comes along and now suddenly cannot find the literal definition, because it doesn’t know what the c++17 did. Disaster!
Best regards,
On Aug 30, 2021, at 10:12, Mark Adams <[email protected]> wrote:
No luck with C++14
CUDAC arch-summit-hypre-cuda-dbg/obj/vec/is/sf/impls/basic/cuda/sfcuda.o CUDAC.dep arch-summit-hypre-cuda-dbg/obj/vec/is/sf/impls/basic/cuda/sfcuda.o CLINKER arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3 arch-summit-hypre-cuda-dbg/obj/sys/objects/device/impls/cupm/cuda/cupmcontext.o:(.rodata._ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE[_ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE]+0x0): multiple definition of `Petsc::CUPMInterface<(Petsc::CUPMDeviceKind)0>::cupmStreamNonBlocking' arch-summit-hypre-cuda-dbg/obj/sys/objects/device/interface/cupminterface.o:(.rodata+0x44): first defined here /usr/bin/ld: link errors found, deleting executable `arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3' collect2: error: ld returned 1 exit status gmake[3]: *** [gmakefile:113: arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3] Error 1 gmake[2]: *** [/gpfs/alpine/csc314/scratch/adams/petsc2/lib/petsc/conf/rules:50: libs] Error 2 **************************ERROR************************************* Error during compile, check arch-summit-hypre-cuda-dbg/lib/petsc/conf/make.log Send it and arch-summit-hypre-cuda-dbg/lib/petsc/conf/configure.log to [email protected] ******************************************************************** gmake[1]: *** [makefile:40: all] Error 1
On Mon, Aug 30, 2021 at 10:50 AM Mark Adams <[email protected]> wrote:
Stefano suggested C++14 in configure. I was using C++11.
On Mon, Aug 30, 2021 at 10:46 AM Junchao Zhang < [email protected]> wrote:
Petsc::CUPMInterface @Jacob Faibussowitsch <[email protected]> --Junchao Zhang
On Mon, Aug 30, 2021 at 9:35 AM Mark Adams <[email protected]> wrote:
I was running fine this AM and am bouncing between modules to help two apps (ECP milestone season) at the same time and something broke. I did update main and I get the same error in main and a hypre branch of Stefano's. I started with a clean build and checked my modules... Any ideas?
Thanks, Mark
CC arch-summit-hypre-cuda-dbg/obj/tao/interface/taosolver.o CC arch-summit-hypre-cuda-dbg/obj/ts/interface/ts.o CUDAC arch-summit-hypre-cuda-dbg/obj/mat/impls/dense/seq/cuda/densecuda.o CUDAC.dep arch-summit-hypre-cuda-dbg/obj/mat/impls/dense/seq/cuda/densecuda.o CUDAC arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparseband.o CUDAC.dep arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparseband.o CUDAC arch-summit-hypre-cuda-dbg/obj/ts/utils/dmplexlandau/cuda/landaucu.o CUDAC.dep arch-summit-hypre-cuda-dbg/obj/ts/utils/dmplexlandau/cuda/landaucu.o CUDAC arch-summit-hypre-cuda-dbg/obj/vec/vec/impls/seq/seqcuda/veccuda2.o CUDAC.dep arch-summit-hypre-cuda-dbg/obj/vec/vec/impls/seq/seqcuda/veccuda2.o CUDAC arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.o CUDAC.dep arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.o CUDAC arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparse.o CUDAC.dep arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparse.o CUDAC arch-summit-hypre-cuda-dbg/obj/vec/is/sf/impls/basic/cuda/sfcuda.o CUDAC.dep arch-summit-hypre-cuda-dbg/obj/vec/is/sf/impls/basic/cuda/sfcuda.o CLINKER arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3 arch-summit-hypre-cuda-dbg/obj/sys/objects/device/impls/cupm/cuda/cupmcontext.o:(.rodata._ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE[_ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE]+0x0): multiple definition of `Petsc::CUPMInterface<(Petsc::CUPMDeviceKind)0>::cupmStreamNonBlocking' arch-summit-hypre-cuda-dbg/obj/sys/objects/device/interface/cupminterface.o:(.rodata+0x44): first defined here /usr/bin/ld: link errors found, deleting executable `arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3' collect2: error: ld returned 1 exit status gmake[3]: *** [gmakefile:113: arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3] Error 1 gmake[2]: *** [/gpfs/alpine/csc314/scratch/adams/petsc2/lib/petsc/conf/rules:50: libs] Error 2 **************************ERROR************************************* Error during compile, check arch-summit-hypre-cuda-dbg/lib/petsc/conf/make.log Send it and arch-summit-hypre-cuda-dbg/lib/petsc/conf/configure.log to [email protected] ******************************************************************** gmake[1]: *** [makefile:40: all] Error 1 make: *** [GNUmakefile:9: all] Error 2
<make.log><configure.log>
participants (1)
Mark Adams
