Alternatively, we could run dos2unix over all the tests during configure stage and error if this makes a diff. https://linux.die.net/man/1/dos2unix Best regards, Jacob Faibussowitsch (Jacob Fai - booss - oh - vitch)
On Oct 28, 2021, at 08:22, Jacob Faibussowitsch <[email protected]> wrote:
Fix is trivial, we just need to replace ‘\n’ with os.linesep everywhere.
https://docs.python.org/3/library/os.html#os.linesep <https://docs.python.org/3/library/os.html#os.linesep>
Best regards,
On Oct 28, 2021, at 08:12, Matthew Knepley <[email protected] <mailto:[email protected]>> wrote:
I just found a loophole in the test parsing happening here:
https://gitlab.com/petsc/petsc/-/blob/main/config/testparse.py#L530 <https://gitlab.com/petsc/petsc/-/blob/main/config/testparse.py#L530>
If your file was produced on Windows (CRLF), then the parsing fails and tests are silently ignored. This took me some time to find and could be confusing for others. I think we should either:
a) Fix the parser to work with CRLF as well
or
b) Fail immediately for CRLF files
What do you think?
Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
