Re: [petsc-dev] Issues with DMComplexGetTransitiveClosure in Fortran
DMComplexGetTransitiveClosure (and Restore) work fine now. What are the new restrictions on numbering mentioned in src/dm/impls/complex/examples/tests/ex2f90.F? On Tue, Aug 28, 2012 at 8:16 PM, Matthew Knepley <[email protected]> wrote:
On Tue, Aug 28, 2012 at 5:01 PM, Chris Eldred <[email protected]> wrote:
On Tue, Aug 28, 2012 at 3:49 PM, Matthew Knepley <[email protected]> wrote:
On Tue, Aug 28, 2012 at 4:39 PM, Chris Eldred <[email protected]> wrote:
DMComplexGetTransitiveClosure does not appear to have the calling sequence (DM dm, PetscInt p, PetscBool useCone, PetscInt *numPoints, PetscInt *points[]) indicated in the documentation- instead it has DM dm, PetscInt p, PetscBool useCone, PetscInt *points[]. In addition, it does not appear to be returning the full closure- instead it just gives cone + the point.
1) I will turn this code into a running example
Awesome! I have been using the Doublet mesh to test DMComplex routines and my own functions, so that is great.
Okay, there was a bug in the array handling. The test is
Matt
2) I will fix the documentation. The interface change for Fortran comes because the size is embedded in the array pointer. If you think I should still return the size in Fortran, let me know.
I can get the size from the array pointer so just returning that works.
3) I will also check to make sure the documentation is clear that this thing returns each point AND its orientation.
Will write again when I have your thing running. It could be an error with the Fortran array processing I put in.
Matt
Sample code is below:
program main implicit none ! ! #echo '#include <finclude/petscsys.h>\n' #echo '#include <finclude/petsc.h90>' #echo '#include <finclude/petscdmcomplex.h>\n' #echo '#include <finclude/petscdmcomplex.h90>' ! #echo '#include <finclude/petscdm.h>\n' ! #echo '#include <finclude/petscdm.h90>\n'
! DM dm PetscInt, target, dimension(3) :: EC PetscInt, target, dimension(2) :: VE PetscInt, pointer :: pEC(:), pVE(:) PetscInt, pointer :: nClosure(:) PetscInt, pointer :: pClosure(:), pCone(:), pCone2(:) PetscErrorCode ierr
call PetscInitialize(PETSC_NULL_CHARACTER,ierr) CHKERRQ(ierr) call DMComplexCreate(PETSC_COMM_WORLD, dm, ierr) CHKERRQ(ierr)
!Make Doublet Mesh from Fig 2 of Flexible Representation of Computational Meshes (except indexing is from 0 instead of 1) call DMComplexSetChart(dm, 0, 11, ierr) CHKERRQ(ierr)
call DMComplexSetConeSize(dm, 9, 3,ierr) CHKERRQ(ierr) call DMComplexSetConeSize(dm, 10, 3,ierr) CHKERRQ(ierr) call DMComplexSetConeSize(dm, 4, 2,ierr) CHKERRQ(ierr) call DMComplexSetConeSize(dm, 5, 2,ierr) CHKERRQ(ierr) call DMComplexSetConeSize(dm, 6, 2,ierr) CHKERRQ(ierr) call DMComplexSetConeSize(dm, 7, 2,ierr) CHKERRQ(ierr) call DMComplexSetConeSize(dm, 8, 2,ierr) CHKERRQ(ierr)
call DMSetUp(dm, ierr) CHKERRQ(ierr)
EC(1) = 4 EC(2) = 5 EC(3) = 6 pEC => EC call DMComplexSetCone(dm, 9 , pEC, ierr) CHKERRQ(ierr) EC(1) = 6 EC(2) = 7 EC(3) = 8 pEC => EC call DMComplexSetCone(dm, 10 , pEC, ierr) CHKERRQ(ierr)
VE(1) = 0 VE(2) = 1 pVE => VE call DMComplexSetCone(dm, 4 , pVE, ierr) CHKERRQ(ierr) VE(1) = 0 VE(2) = 2 pVE => VE call DMComplexSetCone(dm, 5 , pVE, ierr) CHKERRQ(ierr) VE(1) = 1 VE(2) = 2 pVE => VE call DMComplexSetCone(dm, 6 , pVE, ierr) CHKERRQ(ierr) VE(1) = 2 VE(2) = 3 pVE => VE call DMComplexSetCone(dm, 7 , pVE, ierr) CHKERRQ(ierr) VE(1) = 1 VE(2) = 3 pVE => VE call DMComplexSetCone(dm, 8 , pVE, ierr) CHKERRQ(ierr)
call DMComplexSymmetrize(dm,ierr) CHKERRQ(ierr) call DMComplexStratify(dm,ierr) CHKERRQ(ierr)
!Test Stuff
call DMComplexGetTransitiveClosure(dm,10,PETSC_TRUE,nClosure,ierr) !pClosure,ierr) CHKERRQ(ierr) write(*,*) nClosure write(*,*) pClosure
call DMDestroy(dm,ierr) CHKERRQ(ierr) call PetscFinalize(ierr) CHKERRQ(ierr) end
The output is: 10 0 6 0 7 0 8
and then there is an error in DMDestroy
[0]PETSC ERROR: --------------------- Error Message ------------------------------------ [0]PETSC ERROR: Object is in wrong state! [0]PETSC ERROR: Work array still checked out! [0]PETSC ERROR:
------------------------------------------------------------------------ [0]PETSC ERROR: Petsc Development HG revision: b6fe82991deee4a0d3f9a20654bc7750a6b1fe0f HG Date: Mon Aug 27 13:17:10 2012 -0500 [0]PETSC ERROR: See docs/changes/index.html for recent updates. [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting. [0]PETSC ERROR: See docs/index.html for manual pages. [0]PETSC ERROR:
------------------------------------------------------------------------ [0]PETSC ERROR: ./test on a arch-linu named Puget-101334 by user Tue Aug 28 15:31:06 2012 [0]PETSC ERROR: Libraries linked from /home/user/Desktop/LIBRARIES/petsc-dev/arch-linux2-cxx-debug/lib [0]PETSC ERROR: Configure run at Mon Aug 27 12:55:14 2012 [0]PETSC ERROR: Configure options --download-boost --download-chaco --download-ctetgen --download-f-blas-lapack --download-fiat --download-generator --download-metis --download-ml --download-mpich --download-parmetis --download-scientificpython --download-triangle --with-clanguage=cxx --with-dynamic-loading --with-shared-libraries --with-sieve PETSC_ARCH=arch-linux2-cxx-debug [0]PETSC ERROR:
------------------------------------------------------------------------ [0]PETSC ERROR: DMDestroy() line 234 in /home/user/Desktop/LIBRARIES/petsc-dev/src/dm/interface/dm.c application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0 [unset]: aborting job: application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
Ideas?
-- Chris Eldred DOE Computational Science Graduate Fellow Graduate Student, Atmospheric Science, Colorado State University B.S. Applied Computational Physics, Carnegie Mellon University, 2009 [email protected]
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Chris Eldred
