Re: [petsc-dev] Cannot locate file: share/petsc/datafiles/matrices/small
Have mpi.py turn off the use of MPI windows for these versions of OpenMPI. Note this is already standard practice, we have the comment "Skip buggy MPICH versions" and a variety of checks based on bad versions. Barry
On Sep 14, 2021, at 7:17 AM, Matthew Knepley <[email protected]> wrote:
Okay, we have to send this to OpenMPI. Volunteers?
Maybe we should note this in the FAQ, or installation, so we remember how to fix it if someone else asks?
Matt
On Tue, Sep 14, 2021 at 2:35 AM Stefano Zampini <[email protected] <mailto:[email protected]>> wrote: I can reproduce it even with OpenMPI 4.1.1 on a different machine (Ubuntu 18 + AMD milan + clang from AOCC) and it is definitely an OpenMPI bug in the vader BTL If I use tcp, everything runs smooth
zampins@kanary:~/Devel/petsc$ cat /home/zampins/local/etc/openmpi-mca-params.conf | grep btl btl = tcp,self zampins@kanary:~/Devel/petsc$ make -f gmakefile.test vec_is_sf_tutorials-ex1_4 Using MAKEFLAGS: TEST arch-debug/tests/counts/vec_is_sf_tutorials-ex1_4.counts ok vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-create ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-create ok vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-dynamic ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-dynamic ok vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-allocate ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-allocate ok vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-create ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-create ok vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-dynamic ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-dynamic ok vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-allocate ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-allocate ok vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-create ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-create ok vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-dynamic ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-dynamic ok vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-allocate ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-allocate
zampins@kanary:~/Devel/petsc$ cat /home/zampins/local/etc/openmpi-mca-params.conf | grep btl btl = vader,tcp,self zampins@kanary:~/Devel/petsc$ make -f gmakefile.test vec_is_sf_tutorials-ex1_4 Using MAKEFLAGS: TEST arch-debug/tests/counts/vec_is_sf_tutorials-ex1_4.counts ok vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-create not ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-create # Error code: 1 # 43,46c43,46 # < [0] 0: 4001 2000 2002 3002 4002 # < [1] 0: 1001 3000 # < [2] 0: 2001 4000 # < [3] 0: 3001 1000 # --- # > [0] 0: 2002 2146435072 2 2146435072 38736240 # > [1] 0: 3000 2146435072 # > [2] 0: 2001 2146435072 # > [3] 0: 3001 2146435072 ok vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-dynamic not ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-dynamic # Error code: 1 # 43,46c43,46 # < [0] 0: 4001 2000 2002 3002 4002 # < [1] 0: 1001 3000 # < [2] 0: 2001 4000 # < [3] 0: 3001 1000 # --- # > [0] 0: 2002 2146435072 2 2146435072 0 # > [1] 0: 3000 2146435072 # > [2] 0: 2001 2146435072 # > [3] 0: 3001 2146435072 ok vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-allocate ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-allocate # retrying vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-create not ok vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-create # Error code: 98 # [1]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- # [1]PETSC ERROR: General MPI error # [1]PETSC ERROR: MPI error 6 MPI_ERR_RANK: invalid rank # [1]PETSC ERROR: See https://petsc.org/release/faq/ <https://petsc.org/release/faq/> for trouble shooting. # [1]PETSC ERROR: Petsc Development GIT revision: v3.15.4-783-g168bb9f76b GIT Date: 2021-09-13 14:01:22 +0000 # [1]PETSC ERROR: ../ex1 on a arch-debug named kanary.kaust.edu.sa <http://kanary.kaust.edu.sa/> by zampins Tue Sep 14 09:31:42 2021 # [1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- # [2]PETSC ERROR: General MPI error # [2]PETSC ERROR: MPI error 6 MPI_ERR_RANK: invalid rank # [2]PETSC ERROR: See https://petsc.org/release/faq/ <https://petsc.org/release/faq/> for trouble shooting. # [2]PETSC ERROR: Petsc Development GIT revision: v3.15.4-783-g168bb9f76b GIT Date: 2021-09-13 14:01:22 +0000 # [2]PETSC ERROR: ../ex1 on a arch-debug named kanary.kaust.edu.sa <http://kanary.kaust.edu.sa/> by zampins Tue Sep 14 09:31:42 2021 # [2]PETSC ERROR: Configure options --with-cc=/home/zampins/local/bin/mpicc --with-cxx-dialect=c++14 --with-cxx=/home/zampins/local/bin/mpicxx --with-debugging=1 --with-fc=/home/zampins/local/bin/mpifort --with-fortran-bindings=0 --with-hip-dir=/opt/rocm --with-hip=1 --with-hypre-dir=/home/zampins/local-petsc --with-kokkos-dir=/home/zampins/local-petsc --with-kokkos-kernels-dir=/home/zampins/local-petsc --with-blaslapack-include=/home/zampins/local-aocl/aocc/3.0-6/include --with-blaslapack-lib="[/home/zampins/local-aocl/aocc/3.0-6/lib/liblapacke.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libflame.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libblis-mt.a]" HIPFLAGS=--amdgpu-target=gfx908 HIPPPFLAGS=-I/home/zampins/local-petsc/include PETSC_ARCH=arch-debug # [2]PETSC ERROR: #1 PetscSFGetGroups() at /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:1166 # [2]PETSC ERROR: #2 PetscSFSetUp_Window() at /home/zampins/Devel/petsc/src/vec/is/sf/impls/window/sfwindow.c:708 # [2]PETSC ERROR: #3 PetscSFSetUp() at /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:318 # [2]PETSC ERROR: #4 main() at /home/zampins/Devel/petsc/src/vec/is/sf/tutorials/ex1.c:172 # [2]PETSC ERROR: PETSc Option Table entries: # [2]PETSC ERROR: -sf_type window # [2]PETSC ERROR: -sf_window_flavor create # [2]PETSC ERROR: -sf_window_sync active # [2]PETSC ERROR: -test_gather # [2]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] # [3]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- # [3]PETSC ERROR: General MPI error # [3]PETSC ERROR: MPI error 6 MPI_ERR_RANK: invalid rank # [3]PETSC ERROR: See https://petsc.org/release/faq/ <https://petsc.org/release/faq/> for trouble shooting. # [3]PETSC ERROR: Petsc Development GIT revision: v3.15.4-783-g168bb9f76b GIT Date: 2021-09-13 14:01:22 +0000 # [3]PETSC ERROR: ../ex1 on a arch-debug named kanary.kaust.edu.sa <http://kanary.kaust.edu.sa/> by zampins Tue Sep 14 09:31:42 2021 # [3]PETSC ERROR: Configure options --with-cc=/home/zampins/local/bin/mpicc --with-cxx-dialect=c++14 --with-cxx=/home/zampins/local/bin/mpicxx --with-debugging=1 --with-fc=/home/zampins/local/bin/mpifort --with-fortran-bindings=0 --with-hip-dir=/opt/rocm --with-hip=1 --with-hypre-dir=/home/zampins/local-petsc --with-kokkos-dir=/home/zampins/local-petsc --with-kokkos-kernels-dir=/home/zampins/local-petsc --with-blaslapack-include=/home/zampins/local-aocl/aocc/3.0-6/include --with-blaslapack-lib="[/home/zampins/local-aocl/aocc/3.0-6/lib/liblapacke.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libflame.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libblis-mt.a]" HIPFLAGS=--amdgpu-target=gfx908 HIPPPFLAGS=-I/home/zampins/local-petsc/include PETSC_ARCH=arch-debug # [3]PETSC ERROR: #1 PetscSFGetGroups() at /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:1166 # [3]PETSC ERROR: #2 PetscSFSetUp_Window() at /home/zampins/Devel/petsc/src/vec/is/sf/impls/window/sfwindow.c:708 # [3]PETSC ERROR: #3 PetscSFSetUp() at /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:318 # [3]PETSC ERROR: #4 main() at /home/zampins/Devel/petsc/src/vec/is/sf/tutorials/ex1.c:172 # [3]PETSC ERROR: PETSc Option Table entries: # [3]PETSC ERROR: -sf_type window # [3]PETSC ERROR: -sf_window_flavor create # [3]PETSC ERROR: Configure options --with-cc=/home/zampins/local/bin/mpicc --with-cxx-dialect=c++14 --with-cxx=/home/zampins/local/bin/mpicxx --with-debugging=1 --with-fc=/home/zampins/local/bin/mpifort --with-fortran-bindings=0 --with-hip-dir=/opt/rocm --with-hip=1 --with-hypre-dir=/home/zampins/local-petsc --with-kokkos-dir=/home/zampins/local-petsc --with-kokkos-kernels-dir=/home/zampins/local-petsc --with-blaslapack-include=/home/zampins/local-aocl/aocc/3.0-6/include --with-blaslapack-lib="[/home/zampins/local-aocl/aocc/3.0-6/lib/liblapacke.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libflame.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libblis-mt.a]" HIPFLAGS=--amdgpu-target=gfx908 HIPPPFLAGS=-I/home/zampins/local-petsc/include PETSC_ARCH=arch-debug # [1]PETSC ERROR: #1 PetscSFGetGroups() at /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:1166 # [1]PETSC ERROR: #2 PetscSFSetUp_Window() at /home/zampins/Devel/petsc/src/vec/is/sf/impls/window/sfwindow.c:708 # [1]PETSC ERROR: #3 PetscSFSetUp() at /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:318 # [1]PETSC ERROR: #4 main() at /home/zampins/Devel/petsc/src/vec/is/sf/tutorials/ex1.c:172 # [1]PETSC ERROR: PETSc Option Table entries: # [1]PETSC ERROR: -sf_type window # [1]PETSC ERROR: -sf_window_flavor create # [1]PETSC ERROR: -sf_window_sync active # [1]PETSC ERROR: -test_gather # [1]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] # -sf_window_sync active # [3]PETSC ERROR: -test_gather # [3]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] # -------------------------------------------------------------------------- # MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD # with errorcode 98. # # NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. # You may or may not see output from other processes, depending on # exactly when Open MPI kills them. # -------------------------------------------------------------------------- # [kanary.kaust.edu.sa:115527 <http://kanary.kaust.edu.sa:115527>] 2 more processes have sent help message help-mpi-api.txt / mpi-abort # [kanary.kaust.edu.sa:115527 <http://kanary.kaust.edu.sa:115527>] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages ok vec_is_sf_tutorials-ex1_4 # SKIP Command failed so no diff # retrying vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-dynamic not ok vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-dynamic # Error code: 98 # [1]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- # [1]PETSC ERROR: General MPI error # [1]PETSC ERROR: MPI error 6 MPI_ERR_RANK: invalid rank # [1]PETSC ERROR: See https://petsc.org/release/faq/ <https://petsc.org/release/faq/> for trouble shooting. # [1]PETSC ERROR: Petsc Development GIT revision: v3.15.4-783-g168bb9f76b GIT Date: 2021-09-13 14:01:22 +0000 # [1]PETSC ERROR: ../ex1 on a arch-debug named kanary.kaust.edu.sa <http://kanary.kaust.edu.sa/> by zampins Tue Sep 14 09:31:45 2021 # [1]PETSC ERROR: Configure options --with-cc=/home/zampins/local/bin/mpicc --with-cxx-dialect=c++14 --with-cxx=/home/zampins/local/bin/mpicxx --with-debugging=1 --with-fc=/home/zampins/local/bin/mpifort --with-fortran-bindings=0 --with-hip-dir=/opt/rocm --with-hip=1 --with-hypre-dir=/home/zampins/local-petsc --with-kokkos-dir=/home/zampins/local-petsc --with-kokkos-kernels-dir=/home/zampins/local-petsc --with-blaslapack-include=/home/zampins/local-aocl/aocc/3.0-6/include --with-blaslapack-lib="[/home/zampins/local-aocl/aocc/3.0-6/lib/liblapacke.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libflame.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libblis-mt.a]" HIPFLAGS=--amdgpu-target=gfx908 HIPPPFLAGS=-I/home/zampins/local-petsc/include PETSC_ARCH=arch-debug # [1]PETSC ERROR: #1 PetscSFGetGroups() at /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:1166 # [1]PETSC ERROR: #2 PetscSFSetUp_Window() at /home/zampins/Devel/petsc/src/vec/is/sf/impls/window/sfwindow.c:708 # [1]PETSC ERROR: #3 PetscSFSetUp() at /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:318 # [1]PETSC ERROR: #4 main() at /home/zampins/Devel/petsc/src/vec/is/sf/tutorials/ex1.c:172 # [1]PETSC ERROR: PETSc Option Table entries: # [1]PETSC ERROR: -sf_type window # [1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- # [2]PETSC ERROR: General MPI error # [2]PETSC ERROR: MPI error 6 MPI_ERR_RANK: invalid rank # [2]PETSC ERROR: See https://petsc.org/release/faq/ <https://petsc.org/release/faq/> for trouble shooting. # [2]PETSC ERROR: Petsc Development GIT revision: v3.15.4-783-g168bb9f76b GIT Date: 2021-09-13 14:01:22 +0000 # [2]PETSC ERROR: ../ex1 on a arch-debug named kanary.kaust.edu.sa <http://kanary.kaust.edu.sa/> by zampins Tue Sep 14 09:31:45 2021 # [2]PETSC ERROR: Configure options --with-cc=/home/zampins/local/bin/mpicc --with-cxx-dialect=c++14 --with-cxx=/home/zampins/local/bin/mpicxx --with-debugging=1 --with-fc=/home/zampins/local/bin/mpifort --with-fortran-bindings=0 --with-hip-dir=/opt/rocm --with-hip=1 --with-hypre-dir=/home/zampins/local-petsc --with-kokkos-dir=/home/zampins/local-petsc --with-kokkos-kernels-dir=/home/zampins/local-petsc --with-blaslapack-include=/home/zampins/local-aocl/aocc/3.0-6/include --with-blaslapack-lib="[/home/zampins/local-aocl/aocc/3.0-6/lib/liblapacke.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libflame.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libblis-mt.a]" HIPFLAGS=--amdgpu-target=gfx908 HIPPPFLAGS=-I/home/zampins/local-petsc/include PETSC_ARCH=arch-debug # [2]PETSC ERROR: #1 PetscSFGetGroups() at /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:1166 # [2]PETSC ERROR: #2 PetscSFSetUp_Window() at /home/zampins/Devel/petsc/src/vec/is/sf/impls/window/sfwindow.c:708 # [2]PETSC ERROR: #3 PetscSFSetUp() at /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:318 # [2]PETSC ERROR: #4 main() at /home/zampins/Devel/petsc/src/vec/is/sf/tutorials/ex1.c:172 # [2]PETSC ERROR: PETSc Option Table entries: # [2]PETSC ERROR: -sf_type window # [2]PETSC ERROR: -sf_window_flavor dynamic # [2]PETSC ERROR: -sf_window_sync active # [2]PETSC ERROR: -test_gather # [2]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] # [3]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- # [3]PETSC ERROR: General MPI error # [3]PETSC ERROR: MPI error 6 MPI_ERR_RANK: invalid rank # [3]PETSC ERROR: See https://petsc.org/release/faq/ <https://petsc.org/release/faq/> for trouble shooting. # [3]PETSC ERROR: Petsc Development GIT revision: v3.15.4-783-g168bb9f76b GIT Date: 2021-09-13 14:01:22 +0000 # [3]PETSC ERROR: ../ex1 on a arch-debug named kanary.kaust.edu.sa <http://kanary.kaust.edu.sa/> by zampins Tue Sep 14 09:31:45 2021 # [3]PETSC ERROR: Configure options --with-cc=/home/zampins/local/bin/mpicc --with-cxx-dialect=c++14 --with-cxx=/home/zampins/local/bin/mpicxx --with-debugging=1 --with-fc=/home/zampins/local/bin/mpifort --with-fortran-bindings=0 --with-hip-dir=/opt/rocm --with-hip=1 --with-hypre-dir=/home/zampins/local-petsc --with-kokkos-dir=/home/zampins/local-petsc --with-kokkos-kernels-dir=/home/zampins/local-petsc --with-blaslapack-include=/home/zampins/local-aocl/aocc/3.0-6/include --with-blaslapack-lib="[/home/zampins/local-aocl/aocc/3.0-6/lib/liblapacke.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libflame.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libblis-mt.a]" HIPFLAGS=--amdgpu-target=gfx908 HIPPPFLAGS=-I/home/zampins/local-petsc/include PETSC_ARCH=arch-debug # [3]PETSC ERROR: #1 PetscSFGetGroups() at /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:1166 # [3]PETSC ERROR: #2 PetscSFSetUp_Window() at /home/zampins/Devel/petsc/src/vec/is/sf/impls/window/sfwindow.c:708 # [3]PETSC ERROR: #3 PetscSFSetUp() at /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:318 # [3]PETSC ERROR: #4 main() at /home/zampins/Devel/petsc/src/vec/is/sf/tutorials/ex1.c:172 # [3]PETSC ERROR: PETSc Option Table entries: # [3]PETSC ERROR: -sf_type window # [3]PETSC ERROR: -sf_window_flavor dynamic # [3]PETSC ERROR: -sf_window_sync active # [3]PETSC ERROR: -test_gather # [3]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] # -sf_window_flavor dynamic # [1]PETSC ERROR: -sf_window_sync active # [1]PETSC ERROR: -test_gather # [1]PETSC ERROR: ----------------End of Error Message -------send entire error message to [email protected] # -------------------------------------------------------------------------- # MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD # with errorcode 98. # # NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. # You may or may not see output from other processes, depending on # exactly when Open MPI kills them. # -------------------------------------------------------------------------- # [kanary.kaust.edu.sa:115572 <http://kanary.kaust.edu.sa:115572>] 2 more processes have sent help message help-mpi-api.txt / mpi-abort # [kanary.kaust.edu.sa:115572 <http://kanary.kaust.edu.sa:115572>] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages ok vec_is_sf_tutorials-ex1_4 # SKIP Command failed so no diff ok vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-allocate ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-allocate ok vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-create not ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-create # Error code: 1 # 43,46c43,46 # < [0] 0: 4001 2000 2002 3002 4002 # < [1] 0: 1001 3000 # < [2] 0: 2001 4000 # < [3] 0: 3001 1000 # --- # > [0] 0: 4002 2146435072 2 2146435072 34619728 # > [1] 0: 3000 2146435072 # > [2] 0: 4000 2146435072 # > [3] 0: 3001 2146435072 ok vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-dynamic not ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-dynamic # Error code: 1 # 43,46c43,46 # < [0] 0: 4001 2000 2002 3002 4002 # < [1] 0: 1001 3000 # < [2] 0: 2001 4000 # < [3] 0: 3001 1000 # --- # > [0] 0: 4002 2146435072 2 2146435072 0 # > [1] 0: 3000 2146435072 # > [2] 0: 4000 2146435072 # > [3] 0: 3001 2146435072 ok vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-allocate ok diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-allocate
Il giorno mar 14 set 2021 alle ore 07:44 Stefano Zampini <[email protected] <mailto:[email protected]>> ha scritto: I'll see if I can reproduce
Il Mar 14 Set 2021, 06:58 Junchao Zhang <[email protected] <mailto:[email protected]>> ha scritto: Hi, Stefano, Ping you again to see if you want to resolve this problem before petsc-3.16
--Junchao Zhang
On Sun, Sep 12, 2021 at 3:06 PM Antonio T. sagitter <[email protected] <mailto:[email protected]>> wrote: Unfortunately, it's not possible. I must use the OpenMPI provided by Fedora build-system (these rpm builds of PETSc are for Fedora's repositories), downloading external software is not permitted.
On 9/12/21 21:10, Pierre Jolivet wrote:
On 12 Sep 2021, at 8:56 PM, Matthew Knepley <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>> wrote:
On Sun, Sep 12, 2021 at 2:49 PM Antonio T. sagitter <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>> wrote:
Those attached are configure.log/make.log from a MPI build in Fedora 34 x86_64 where the error below occurred.
This is OpenMPI 4.1.0. Is that the only MPI you build? My first inclination is that this is an MPI implementation bug.
Junchao, do we have an OpenMPI build in the CI?
config/examples/arch-ci-linux-cuda-double-64idx.py: '--download-openmpi=1', config/examples/arch-ci-linux-pkgs-dbg-ftn-interfaces.py: '--download-openmpi=1', config/examples/arch-ci-linux-pkgs-opt.py: '--download-openmpi=1',
config/BuildSystem/config/packages/OpenMPI.py uses version 4.1.0 as well. I’m not sure PETSc is to blame here Antonio. You may want to try to ditch the OpenMPI shipped by your packet manager and try --download-openmpi as well, just for a quick sanity check.
Thanks, Pierre
-- --- Antonio Trande Fedora Project mailto: [email protected] <mailto:[email protected]> GPG key: 0x29FBC85D7A51CC2F GPG key server: https://keyserver1.pgp.com/ <https://keyserver1.pgp.com/>
-- Stefano
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Barry Smith
