Re: [petsc-dev] potential bug with MPI_Win_fence() in openmpi-1.8.4
Thanks for checking and getting a more appropriate fix in. I've just tried this out - and the PETSc test code runs fine with it. BTW: There is one inconsistancy in ompi/datatype/ompi_datatype_args.c [that I noticed] - that you might want to check. Perhaps the second line should be "(DC) * sizeof(MPI_Datatype)"?
int length = sizeof(ompi_datatype_args_t) + (IC) * sizeof(int) + \ (AC) * sizeof(OPAL_PTRDIFF_TYPE) + (DC) * sizeof(MPI_Datatype); \
pArgs->total_pack_size = (4 + (IC)) * sizeof(int) + \ (AC) * sizeof(OPAL_PTRDIFF_TYPE) + (DC) * sizeof(int); \ <<<<<<<<<<< Satish On Thu, 30 Apr 2015, Matthew Knepley wrote:
On Fri, May 1, 2015 at 4:55 AM, Jeff Squyres (jsquyres) <[email protected]> wrote:
Thank you!
George reviewed your patch and adjusted it a bit. We applied it to master and it's pending to the release series (v1.8.x).
Was this identified by IBM?
https://github.com/open-mpi/ompi/commit/015d3f56cf749ee5ad9ea4428d2f5da72f9b...
Matt
Would you mind testing a nightly master snapshot? It should be in tonight's build:
http://www.open-mpi.org/nightly/master/
On Apr 30, 2015, at 12:50 AM, Satish Balay <[email protected]> wrote:
OpenMPI developers,
We've had issues (memory errors) with OpenMPI - and code in PETSc library that uses MPI_Win_fence().
Vagrind shows memory corruption deep inside OpenMPI function stack.
I'm attaching a potential patch that appears to fix this issue for us. [the corresponding valgrind trace is listed in the patch header]
Perhaps there is a more appropriate fix for this memory corruption. Could you check on this?
[Sorry I don't have a pure MPI test code to demonstrate this error - but a PETSc test example code consistantly reproduces this issue]
Thanks, Satish<openmpi-1.8.4.patch>
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
participants (1)
Satish Balay
