Re: [petsc-dev] [petsc-maint #80119] Re: make install broken on unix?
On 25 July 2011 13:15, Barry Smith <[email protected]> wrote:
On Jul 25, 2011, at 12:06 PM, Matthew Knepley wrote:
On Mon, Jul 25, 2011 at 4:56 PM, Sean Farley <[email protected]> wrote: I disagree with this completely. There's a tendency to think of everything python as a package -- this is NOT a package. It has no __init__.py, it has no __all__, it has no submodules, and it doesn't need any of that. It simply does a one-off task -- it's bits of code to be used in a script. Putting this sort of code in site-packages is what makes site-packages the nightmare of ignored dependencies and overlapping versions it is today.
If you want to make it into a package, you're welcome to do so. With that includes registration with the cheeseshop to make sure the namespace is unique, placing the single file within a folder that includes an __init__ (and then likely just gets imported within that __init__), writing a setup.py, etc etc. It's just complete overkill.
Then why put it in bin/python at all? Just drop the .py extension and put it in bin (with a 'correct' [whatever that may be] python hashbang)?
Because directories are a useful way to organize categories of software (for example the bin/matlab directory has all the Matlab scripts). Why not just not use subdirectories in PETSc and just stick all PETSc files directly into the PETSc root directory?
1) IMHO, using subdirectories in bin/ does not look good. I think we should have lib/matlab and lib/python. As long as the code in lib/python works with many different Python versions, that location looks fine for me. bin/ is not the right place to add new directories with stuff, you should put there just shebang scripts with execute permissions. 2) You simply cannot drop the .py extension from PetscBinaryRead.py . That code it is not a script intended to be run, but to be imported from other Python codes. If you remove the .py ext, Python import will not be able to locate PetscBinaryRead. -- Lisandro Dalcin --------------- CIMEC (INTEC/CONICET-UNL) Predio CONICET-Santa Fe Colectora RN 168 Km 472, Paraje El Pozo 3000 Santa Fe, Argentina Tel: +54-342-4511594 (ext 1011) Tel/Fax: +54-342-4511169
participants (1)
Lisandro Dalcin
