Re: [petsc-dev] does next model mess up our histories
On Wed, 1 Oct 2014, Barry Smith wrote:
Ok, if this can be documented and made as simple as possible? A tool to do it? If it requires remember several arcane git commands to do and remember the numbers of 5 merges you made, then forget it.
Perhaps Jed will reply with a simpler 'single' command to do the revert all the merges from the feature branch - and an easy way to verify.
Another option: [when the feature branch is ready for rebase/cleanup] delegate the revert of the messy-feature branch to git guru :)
And then not have it happen for how long? gurus unfortunately tend work work at their own schedule.
I think this is similar to a pull request workflow on which one of the integrators would act upon. BTW: the following URL has details of various scenarios wrt reverting. [yeah many different senarios - and the git commands to deal with each senario is slightly different] https://www.kernel.org/pub/software/scm/git/docs/howto/revert-a-faulty-merge... The relavent section for the currently discussed issue is listed in 'ADDENDUM' - and it says: 1. do: revert 2. do: rebase -i --no-ff 3. do: merge Note: the "--no-ff" is important when doing the branch cleanup for the subsequent merge to be successful. [As a practical matter - I prefer to rename this branch when its cleaned up]. I just tried this out.. [on a 'test' branch thats equivalent to 'next' - so I can discard it after my experiment]. And I'm doing this in a clean clone. *** get the list of merge commits in next [from barry/remove-sidl branch] balay@asterix /home/balay/petsc (test) $ git log --merges --oneline --grep="Merge branch 'barry/remove-sidl' into next" 8ad988d Merge branch 'barry/remove-sidl' into next 738aa80 Merge branch 'barry/remove-sidl' into next 4f34d5f Merge branch 'barry/remove-sidl' into next bcd5f70 Merge branch 'barry/remove-sidl' into next 6dc165f Merge branch 'barry/remove-sidl' into next 71fbb5e Merge branch 'barry/remove-sidl' into next 47c2055 Merge branch 'barry/remove-sidl' into next 7720b35 Merge branch 'barry/remove-sidl' into next **** Now revert these merges in the correct order git revert -m 1 8ad988d git revert -m 1 738aa80 git revert -m 1 4f34d5f git revert -m 1 bcd5f70 git revert -m 1 6dc165f git revert -m 1 71fbb5e git revert -m 1 47c2055 git revert -m 1 7720b35 *** Now rebase barry/remove-sidl [as barry/remove-sidl-test] git co barry/remove-sidl git co -b barry/remove-sidl-test git rebase -i --no-ff 0166772 Note: 0166772 is the parent of the first commit in barry/remove-sidl-test branch $ git log --parents --oneline master..barry/remove-sidl-test | tail -1 db23b12 0166772 remove a great deal of dead SIDL code from BuildSystem *** Now merge the rebased stuff to next [aka my 'test' branch] git co test git merge barry/remove-sidl-test *** Verify [in my case - 'next' and 'test' should be same - as my rebase didn't change anything] balay@asterix /home/balay/tmp/petsc (test>) $ git diff test origin/next balay@asterix /home/balay/tmp/petsc (test>) Satish
participants (1)
Satish Balay
