Re: [petsc-dev] Error during KSPDestroy
Barry, Are you able to reproduce the error? I've updated petsc-dev it is still there unfortunately. On 06.05.2012 20:00, Barry Smith wrote:
Alexander,
Sorry, never mind. I found the code in the earlier email.,
barry
On May 6, 2012, at 12:49 PM, Barry Smith wrote:
Alexander,
No attached test program. (only valgrind log).
Barry
On May 6, 2012, at 8:21 AM, Alexander Grayver wrote:
On 06.05.2012 15:07, Matthew Knepley wrote:
Hello,
I use KSP and random rhs to compute largest singular value:
1) Is this the whole program? If not, this can be caused by memory corruption somewhere else. This is what I suspect. Matt,
I can reproduce error using attached test programm and this matrix (7 mb): http://dl.dropbox.com/u/60982984/A.dat
I run it fine with the latest petsc-dev:
1.405802e+00
Can you valgrind it on your machine?
I did: valgrind --tool=memcheck -q --num-callers=20 --log-file=valgrind.log.%p /solveTest -ksp_monitor_true_residual -log_summary -mat_type aij -ksp_rtol 1.0e-10 -malloc off
The error is better constrained:
==20287== Invalid read of size 8 ==20287== at 0x7874B4C: opal_os_path (in /opt/mpi/intel/openmpi-1.4.2/lib/libopen-pal.so.0.0.0) ==20287== by 0x75F2E27: orte_session_dir_finalize (in /opt/mpi/intel/openmpi-1.4.2/lib/libopen-rte.so.0.0.0) ==20287== by 0x76012E8: orte_errmgr_base_error_abort (in /opt/mpi/intel/openmpi-1.4.2/lib/libopen-rte.so.0.0.0) ==20287== by 0x73396E9: ompi_mpi_abort (in /opt/mpi/intel/openmpi-1.4.2/lib/libmpi.so.0.0.2) ==20287== by 0x734F36E: PMPI_Abort (in /opt/mpi/intel/openmpi-1.4.2/lib/libmpi.so.0.0.2) ==20287== by 0x7499AB: PetscDefaultSignalHandler (signal.c:169) ==20287== by 0x749267: PetscSignalHandler_Private (signal.c:53) ==20287== by 0x924B9DF: ??? (in /lib64/libc-2.11.1.so) ==20287== by 0x535D9E: VecDestroyVecs (vector.c:653) ==20287== by 0x68B61D: KSPReset_GMRES (gmres.c:258) ==20287== by 0x6A9D39: KSPReset (itfunc.c:733) ==20287== by 0x6AA839: KSPDestroy (itfunc.c:780) ==20287== by 0x4509F8: main (solveTest.c:66) ==20287== Address 0xbde4860 is 0 bytes inside a block of size 2 alloc'd ==20287== at 0x4C26B9B: malloc (vg_replace_malloc.c:263) ==20287== by 0x92876DF: vasprintf (in /lib64/libc-2.11.1.so) ==20287== by 0x9266C67: asprintf (in /lib64/libc-2.11.1.so) ==20287== by 0x75F1701: orte_util_convert_vpid_to_string (in /opt/mpi/intel/openmpi-1.4.2/lib/libopen-rte.so.0.0.0) ==20287== by 0x75F2D4A: orte_session_dir_finalize (in /opt/mpi/intel/openmpi-1.4.2/lib/libopen-rte.so.0.0.0) ==20287== by 0x76012E8: orte_errmgr_base_error_abort (in /opt/mpi/intel/openmpi-1.4.2/lib/libopen-rte.so.0.0.0) ==20287== by 0x73396E9: ompi_mpi_abort (in /opt/mpi/intel/openmpi-1.4.2/lib/libmpi.so.0.0.2) ==20287== by 0x734F36E: PMPI_Abort (in /opt/mpi/intel/openmpi-1.4.2/lib/libmpi.so.0.0.2) ==20287== by 0x7499AB: PetscDefaultSignalHandler (signal.c:169) ==20287== by 0x749267: PetscSignalHandler_Private (signal.c:53) ==20287== by 0x924B9DF: ??? (in /lib64/libc-2.11.1.so) ==20287== by 0x535D9E: VecDestroyVecs (vector.c:653) ==20287== by 0x68B61D: KSPReset_GMRES (gmres.c:258) ==20287== by 0x6A9D39: KSPReset (itfunc.c:733) ==20287== by 0x6AA839: KSPDestroy (itfunc.c:780) ==20287== by 0x4509F8: main (solveTest.c:66)
Full log is attached.
Important. If I comment this line: KSPComputeExtremeSingularValues(ksp,&maxx,&minx);
It works.
-- Regards, Alexander
<valgrind.zip>
participants (1)
Alexander Grayver
