Re: [petsc-dev] Master doesn't compile
On Sun, 2 Nov 2014, Pierre Jolivet wrote:
Hi, I don�t think it�s machine dependent, but I�m attaching my make.log just in case it is not reproducible on your end.
Thank you for looking, Pierre
Using configure Options: --download-hypre --download-mumps --download-scalapack --download-ptscotch --with-chtml=0 --with-sowing=0 --download-hwloc-shared=1 --with-shared-libraries=1
petsc/src/ksp/pc/impls/jacobi/ftn-auto/jacobif.c:61:11: warning: implicit declaration of function 'PCJacobiSetUseRowSum' is invalid in C99 [-Wimplicit-function-declaration] <<<<<<< I'm not sure what you are doing here - but if you need fortran petsc interface - then --with-sowing=0 is wrong. But if you don't need it - you would use --with-fc=0. But then you are using mumps - so need fortran. So perhaps you should cleanup old sowing stuff you have and use --with-sowing=1 [default] To clean up cruft in the git repo - you can do: rm -rf arch* git clean -f -d -x [and then rerun configure] Satish
participants (1)
Satish Balay
