Re: [petsc-dev] Install step broken
On 28 January 2016 at 15:40, Matthew Knepley <[email protected]> wrote:
On Wed, Jan 27, 2016 at 9:10 AM, Garth N. Wells <[email protected]> wrote:
The 'install' step for master is broken for me since Matt's change ddc4758 ( https://bitbucket.org/petsc/petsc/commits/ddc47588dc986180af4263ab160cc4a555...). I can build and install c502958 fine.
This change is only in an error branch, and should only be triggered by an unsuccessful configure. Can you send configure.log?
I had to unset my PYTHONPATH, which contained mpi4py and petsc4py. Could something have been imported from petsc4py and messed things up? I can send configure.log to petsc-maint later, if it would be helpful. Garth
Matt
Error at 'make install' is:
No cached configure in RDict at arch-linux2-c-opt/lib/petsc/conf/RDict.db Traceback (most recent call last): File "./config/install.py", line 380, in <module> Installer(sys.argv[1:]).run() File "./config/install.py", line 373, in run self.runsetup() File "./config/install.py", line 334, in runsetup self.setup() File "./config/install.py", line 60, in setup self.setupModules() File "./config/install.py", line 51, in setupModules self.setCompilers = self.framework.require('config.setCompilers', None) AttributeError: 'NoneType' object has no attribute 'require' makefile:261: recipe for target 'install' failed
Garth
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Garth N. Wells
