Re: [petsc-dev] lots o' dead code in BuildSystem
Vulture is a static code analyzer, so it's going to miss anything that's dynamically instantiated. On Wed, Oct 1, 2014 at 6:31 AM, Matthew Knepley <[email protected]> wrote:
Lots of this is just unused code paths in that particular configure. However, we can probably eliminate the 'build' directory, BiudlSystem.sourceDatabase and PETSc.FEM
Matt
On Tue, Sep 30, 2014 at 11:11 PM, Barry Smith <[email protected]> wrote:
~/Src/petsc barry/remove-sidl $ Vulture config config/builder.py:605: Unused variable 'comparsion' config/builder.py:639: Unused function 'extractTests' config/builder.py:663: Unused attribute 'cmd' config/builder.py:684: Unused attribute 'ret' config/builder.py:684: Unused attribute 'store' config/builder.py:704: Unused function 'updateNode' config/builder.py:1093: Unused attribute 'memAlign' config/builder.py:1250: Unused attribute 'operationFailed' config/builder.py:1290: Unused function 'compileCUDA' config/builder.py:1293: Unused function 'compileCxx' config/builder.py:1296: Unused function 'compileFortran' config/builder.py:1342: Unused function 'compileCParallel' config/builder.py:1345: Unused function 'compileCxxParallel' config/builder.py:1348: Unused function 'compileFortranParallel' config/builder.py:1374: Unused function 'expandArchive' config/builder.py:1677: Unused function 'checkTestOutput' config/builder.py:1680: Unused function 'checkTestOutputSolver' config/builder.py:1777: Unused function 'buildEtags' config/BuildSystem/args.py:69: Unused attribute '_setCommandLine' config/BuildSystem/build/buildGraph.py:71: Unused function 'removeSubgraph' config/BuildSystem/build/compile/C.py:6: Unused attribute 'usingC' config/BuildSystem/build/compile/Cxx.py:6: Unused attribute 'usingCxx' config/BuildSystem/build/compile/F90.py:6: Unused attribute 'usingF90' config/BuildSystem/build/fileset.py:181: Unused class 'RootedExtensionFileSet' config/BuildSystem/build/fileState.py:61: Unused class 'GenericTag' config/BuildSystem/build/fileState.py:106: Unused class 'Update' config/BuildSystem/build/framework.py:27: Unused attribute 'directories' config/BuildSystem/build/framework.py:78: Unused function 'makeSourceDBPathsAbsolute' config/BuildSystem/build/framework.py:87: Unused function 'makeSourceDBPathsRelative' config/BuildSystem/build/framework.py:103: Unused variable 'newTmp' config/BuildSystem/build/framework.py:177: Unused function 't_activate' config/BuildSystem/build/framework.py:184: Unused function 't_deactivate' config/BuildSystem/build/framework.py:195: Unused function 't_configure' config/BuildSystem/build/framework.py:259: Unused function 't_compile' config/BuildSystem/build/framework.py:264: Unused function 't_compilePrograms' config/BuildSystem/build/framework.py:271: Unused function 't_install' config/BuildSystem/build/framework.py:290: Unused function 't_uninstall' config/BuildSystem/build/framework.py:306: Unused function 't_citool' config/BuildSystem/build/framework.py:312: Unused function 't_push' config/BuildSystem/build/framework.py:321: Unused function 't_pull' config/BuildSystem/build/framework.py:331: Unused function 't_makeStamp' config/BuildSystem/build/framework.py:339: Unused function 't_default' config/BuildSystem/build/framework.py:343: Unused function 't_printTargets' config/BuildSystem/build/framework.py:357: Unused function 't_purge' config/BuildSystem/build/framework.py:374: Unused function 't_update' config/BuildSystem/build/processor.py:341: Unused class 'DirectoryArchiver' config/BuildSystem/build/processor.py:386: Unused class 'Archiver' config/BuildSystem/build/processor.py:460: Unused class 'ImportSharedLinker' config/BuildSystem/build/processor.py:507: Unused class 'LibraryAdder' config/BuildSystem/build/transform.py:41: Unused class 'Filter' config/BuildSystem/build/transform.py:59: Unused class 'Remover' config/BuildSystem/build/transform.py:80: Unused class 'Consolidator' config/BuildSystem/config/base.py:189: Unused function 'addArgumentSubstitution' config/BuildSystem/config/base.py:279: Unused function 'getExecutables' config/BuildSystem/config/base.py:658: Unused function 'splitIncludes' config/BuildSystem/config/compile/processor.py:70: Unused function 'pushRequiredFlags' config/BuildSystem/config/compile/processor.py:73: Unused function 'popRequiredFlags' config/BuildSystem/config/compilers.py:21: Unused attribute 'cRestrict' config/BuildSystem/config/compilers.py:22: Unused attribute 'cxxRestrict' config/BuildSystem/config/framework.py:366: Unused function 'updatePackageDependencies' config/BuildSystem/config/framework.py:465: Unused function 'addSubstitutionFile' config/BuildSystem/config/framework.py:938: Unused attribute '_configured' config/BuildSystem/config/package.py:61: Unused attribute 'double' config/BuildSystem/config/package.py:62: Unused attribute 'complex' config/BuildSystem/config/package.py:63: Unused attribute 'requires32bitint' config/BuildSystem/config/package.py:94: Unused attribute 'openmpi' config/BuildSystem/config/package.py:542: Unused variable 'foundLibrary' config/BuildSystem/config/package.py:543: Unused variable 'foundHeader' config/BuildSystem/config/packages/cuda.py:24: Unused attribute 'ThrustVersionStr' config/BuildSystem/config/packages/cuda.py:25: Unused attribute 'CUSPVersionStr' config/BuildSystem/config/packages/MPI.py:46: Unused attribute 'shared' config/BuildSystem/config/packages/MPI.py:48: Unused attribute 'commf2c' config/BuildSystem/config/packages/MPI.py:49: Unused attribute 'commc2f' config/BuildSystem/config/packages/MPI.py:181: Unused attribute 'haveFinalized' config/BuildSystem/config/packages/MPI.py:184: Unused attribute 'haveInPlace' config/BuildSystem/config/packages/MPI.py:188: Unused attribute 'haveTypeCreateStruct' config/BuildSystem/config/packages/MPI.py:193: Unused attribute 'haveCommCreateErrhandler' config/BuildSystem/config/packages/MPI.py:198: Unused attribute 'haveCommSetErrhandler' config/BuildSystem/config/packages/MPI.py:410: Unused attribute 'havef90module' config/BuildSystem/config/packages/mpi4py.py:14: Unused attribute 'numpy' config/BuildSystem/config/packages/mpi4py.py:22: Unused variable 'pp' config/BuildSystem/config/packages/mpi4py.py:24: Unused variable 'apple' config/BuildSystem/config/packages/SuperLU_MT.py:12: Unused attribute 'worksonWindows' config/BuildSystem/config/packages/Triangle.py:28: Unused variable 'installmakeinc' config/BuildSystem/config/python.py:12: Unused attribute 'isShared' config/BuildSystem/config/regression/frameworkTest.py:10: Unused class 'FrameworkTest' config/BuildSystem/config/regression/frameworkTest.py:42: Unused function 'testEmptyConfigure' config/BuildSystem/config/regression/frameworkTest.py:47: Unused function 'testLogName' config/BuildSystem/config/regression/frameworkTest.py:54: Unused function 'testFullDefaultConfigure' config/BuildSystem/config/regression/shellTest.py:6: Unused class 'ShellTest' config/BuildSystem/config/regression/shellTest.py:14: Unused function 'testTimeout' config/BuildSystem/config/setCompilers.py:22: Unused attribute 'usedMPICompilers' config/BuildSystem/config/setCompilers.py:622: Unused attribute 'compilerVersionCUDA' config/BuildSystem/config/setCompilers.py:997: Unused attribute 'usePIC' config/BuildSystem/config/setCompilers.py:1020: Unused attribute 'isPIC' config/BuildSystem/config/setCompilers.py:1197: Unused attribute 'staticLinker' config/BuildSystem/config/setCompilers.py:1287: Unused function 'addLinkerFlag' config/BuildSystem/config/setCompilers.py:1373: Unused attribute 'staticLibrary' config/BuildSystem/config/setCompilers.py:1374: Unused attribute 'sharedLibrary' config/BuildSystem/config/setsBackport.py:454: Unused function 'union_update' config/BuildSystem/config/setsBackport.py:464: Unused function 'intersection_update' config/BuildSystem/config/setsBackport.py:541: Unused function 'discard' config/BuildSystem/config/setsOrdered.py:547: Unused function 'updateDuplicate' config/BuildSystem/config/setsOrdered.py:633: Unused class 'SetsTest' config/BuildSystem/config/setsOrdered.py:634: Unused function 'testOrdering' config/BuildSystem/config/setsOrdered.py:640: Unused function 'testUniqueness' config/BuildSystem/config/setsOrdered.py:646: Unused function 'testOrder' config/BuildSystem/config/sourceControl.py:31: Unused attribute 'gitversion' config/BuildSystem/config/sourceControl.py:42: Unused attribute 'hgversion' config/BuildSystem/config/sourceControl.py:51: Unused attribute 'cvxversion' config/BuildSystem/config/sourceControl.py:60: Unused attribute 'svnversion' config/BuildSystem/config/types.py:128: Unused function 'checkFortranStar' config/BuildSystem/maker.py:33: Unused function 'getMake' config/BuildSystem/maker.py:232: Unused class 'BasicMake' config/BuildSystem/nargs.py:5: Unused function 'getInteractive' config/BuildSystem/nargs.py:46: Unused function 'setTemporary' config/BuildSystem/nargs.py:144: Unused function 'getKey' config/BuildSystem/nargs.py:206: Unused class 'ArgFuzzyBool' config/BuildSystem/nargs.py:274: Unused class 'ArgReal' config/BuildSystem/nargs.py:390: Unused class 'ArgExecutable' config/BuildSystem/RDict.py:269: Unused function 'hasType' config/BuildSystem/RDict.py:541: Unused function 'handle' config/BuildSystem/retrieval.py:123: Unused function 'ftpRetrieve' config/BuildSystem/retrieval.py:127: Unused function 'httpRetrieve' config/BuildSystem/retrieval.py:131: Unused function 'fileRetrieve' config/BuildSystem/retrieval.py:135: Unused function 'svnRetrieve' config/BuildSystem/retrieval.py:147: Unused function 'bkUpdate' config/BuildSystem/retrieval.py:217: Unused function 'retrieve' config/BuildSystem/retrieval.py:239: Unused function 'removeRoot' config/BuildSystem/retrieval.py:261: Unused function 'bkfileRetrieve' config/BuildSystem/retrieval.py:266: Unused function 'sshRetrieve' config/BuildSystem/retrieval.py:271: Unused function 'oldRetrieve' config/BuildSystem/script.py:41: Unused attribute 'shell' config/BuildSystem/script.py:83: Unused attribute '_setup' config/BuildSystem/script.py:293: Unused attribute 'outputFiles' config/BuildSystem/script.py:414: Unused function 'setPreprocessorObject' config/BuildSystem/script.py:428: Unused function 'setCompilerObject' config/BuildSystem/script.py:444: Unused function 'setLinkerObject' config/BuildSystem/script.py:476: Unused function 'setDynamicLinkerObject' config/BuildSystem/sourceDatabase.py:185: Unused function 'clearSource' config/BuildSystem/sourceDatabase.py:194: Unused function 'getDependencies' config/BuildSystem/sourceDatabase.py:215: Unused function 'calculateDependencies' config/BuildSystem/sourceDatabase.py:281: Unused class 'DependencyAnalyzer' config/BuildSystem/urlMappingInstalled.py:14: Unused function 'setupUrlMapping' config/cmakeboot.py:22: Unused function 'quoteIfNeeded' config/cmakegen.py:64: Unused function 'unexpected' config/examples/arch-bgp-ibm-opt.py:63: Unused variable 'test_options' config/PETSc/Configure.py:58: Unused attribute 'atomics' config/PETSc/Configure.py:739: Unused variable 'langs' config/PETSc/FEM.py:877: Unused function 'createFaceQuadrature' config/PETSc/FEM.py:904: Unused attribute 'list' config/PETSc/FEM.py:907: Unused attribute 'type' config/PETSc/FEM.py:909: Unused attribute 'static' config/PETSc/FEM.py:910: Unused attribute 'initializer' config/PETSc/FEM.py:923: Unused attribute 'identifier' config/PETSc/FEM.py:924: Unused attribute 'replacementText' config/PETSc/FEM.py:1098: Unused function 'getReferenceTensor' config/PETSc/FEM.py:1357: Unused attribute 'typedef' config/PETSc/FEM.py:1386: Unused function 'getQuadratureSetup' config/PETSc/FEM.py:1394: Unused attribute 'branch' config/PETSc/FEM.py:1449: Unused function 'getIntegratorPoints' config/PETSc/FEM.py:1510: Unused attribute 'caseLabel' config/PETSc/FEM.py:1569: Unused function 'getIntegratorSetup' config/PETSc/FEM.py:1578: Unused function 'getSectionSetup' config/PETSc/FEM.py:1669: Unused function 'getElementIntegrals' config/PETSc/FEM.py:1696: Unused attribute 'parameters' config/PETSc/FEM.py:1758: Unused attribute 'comments' config/PETSc/FEM.py:1814: Unused attribute 'purpose' config/PETSc/FEM.py:1904: Unused function 'runTensorProduct' config/PETSc/utilities/arch.py:54: Unused attribute 'archBase' config/PETSc/utilities/cacheDetails.py:29: Unused attribute 'updated' config/PETSc/utilities/CHUD.py:39: Unused attribute 'haveCHUD' config/PETSc/utilities/libraryOptions.py:33: Unused attribute 'scalarTypes' config/PETSc/utilities/missing.py:86: Unused function 'configureMissingErrnos' config/PETSc/utilities/Regression.py:27: Unused attribute ‘elemental'
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Aron Ahmadia
