Re: [petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2015-09-08
Satish, I've done all this and then made a new series of corrections to the branch that hopefully won't break too much more. Thanks Barry
On Sep 8, 2015, at 11:44 PM, Satish Balay <[email protected]> wrote:
Barry,
I amended this commit - and removed that section of code, and pushed my change. [to pr352/dmay/pctelescope/master and merged to next]
[I did this ammend - as this commit didn't propogage to next or master]
[Assuming you haven't added anything else to this branch] Can you do the following - to get this 'amended' commit cleanly - and discard the previous commit in your branch.
git checkout pr352/dmay/pctelescope/master git fetch git reset --hard origin/pr352/dmay/pctelescope/master
Thanks, Satish
On Tue, 8 Sep 2015, Barry Smith wrote:
Satish,
Likely it is wrong. I was forced by git to do some strange merge that produced that result. I can't explain why it happened.
Feel free to fix the branch and master
Barry
On Sep 8, 2015, at 11:25 PM, Satish Balay <[email protected]> wrote:
Barry,
I don't understand the commit https://bitbucket.org/petsc/petsc/commits/3dcc747d65aa2f2e79d189bef52568da19...
-PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscBool v) +PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscInt v) { PetscTryMethod(pc,"PCTelescopeSetIgnoreDM_C",(PC,PetscBool),(pc,v)); return(0); <<<<<<<<
This reverts the change I made earlier - which was required to compile code [otherwise (PetscBool)(PetscInt) is flaged as compiler error]
-PETSC_EXTERN PetscErrorCode PCTelescopeSetIgnoreDM(PC,PetscInt); +PETSC_EXTERN PetscErrorCode PCTelescopeSetIgnoreDM(PC,PetscBool);
-PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscInt v) +PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscBool v)
Satish
Done. But I may have messed up the history a little
On Sep 8, 2015, at 4:28 PM, Satish Balay <[email protected]> wrote:
Barry,
I see you made some changes to pr352/dmay/pctelescope/master and merged to next [and pushed]
However - you did not push pr352/dmay/pctelescope/master. Could you push this branch?
I have fix for the following warnings - and would like to push my changes..
[Just want to make sure all changes are in sync]
thanks, Satish --------
/home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetKSP': /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:654: warning: statement with no effect /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetReductionFactor': /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:675: warning: statement with no effect /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeSetReductionFactor': /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:696: warning: statement with no effect /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetIgnoreDM': /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:717: warning: statement with no effect /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeSetIgnoreDM': /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:738: warning: statement with no effect /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCTelescopeGetDM': /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:759: warning: statement with no effect /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c: In function 'PCSetUp_Telescope': /home/balay/petsc.test/src/ksp/pc/impls/telescope/telescope.c:352: warning: 'subcomm' may be used uninitialized in this function
On Tue, 8 Sep 2015, Satish Balay wrote:
Ok - pushed to pr352/dmay/pctelescope/master - and merged to next
https://bitbucket.org/petsc/petsc/commits/bfd6bcc6ac8e2f0022fa8b00b8cd29f3a3...
[please before further changes - or merge to master]
Satish
I haven't check the examples - but I have the following fix for the build. Will push now
Satish
diff --git a/include/petscpc.h b/include/petscpc.h index 7e583b8..0cddc86 100644 --- a/include/petscpc.h +++ b/include/petscpc.h @@ -324,7 +324,7 @@ PETSC_EXTERN PetscErrorCode PCMGResidualDefault(Mat,Vec,Vec,Vec); PETSC_EXTERN PetscErrorCode PCTelescopeGetReductionFactor(PC,PetscInt*); PETSC_EXTERN PetscErrorCode PCTelescopeSetReductionFactor(PC,PetscInt); PETSC_EXTERN PetscErrorCode PCTelescopeGetIgnoreDM(PC,PetscBool*); -PETSC_EXTERN PetscErrorCode PCTelescopeSetIgnoreDM(PC,PetscInt); +PETSC_EXTERN PetscErrorCode PCTelescopeSetIgnoreDM(PC,PetscBool); PETSC_EXTERN PetscErrorCode PCTelescopeGetDM(PC,DM*);
#endif /* __PETSCPC_H */ diff --git a/src/ksp/pc/impls/telescope/telescope.c b/src/ksp/pc/impls/telescope/telescope.c index 5e899de..fe75c46 100644 --- a/src/ksp/pc/impls/telescope/telescope.c +++ b/src/ksp/pc/impls/telescope/telescope.c @@ -207,7 +207,7 @@ PetscErrorCode PCTelescopeMatCreate_default(PC pc,PC_Telescope sred,MatReuse reu if (reuse != MAT_INITIAL_MATRIX) { Bred = *A; }
ierr = MatGetSize(Blocal,&mm,NULL);CHKERRQ(ierr); - //ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,PETSC_DECIDE,reuse,&Bred);CHKERRQ(ierr); + /* ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,PETSC_DECIDE,reuse,&Bred);CHKERRQ(ierr); */ ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,mm,reuse,&Bred);CHKERRQ(ierr); } *A = Bred; @@ -734,7 +734,7 @@ PetscErrorCode PCTelescopeGetIgnoreDM(PC pc,PetscBool *v)
.keywords: PC, telescoping solve @*/ -PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscInt v) +PetscErrorCode PCTelescopeSetIgnoreDM(PC pc,PetscBool v) { PetscTryMethod(pc,"PCTelescopeSetIgnoreDM_C",(PC,PetscBool),(pc,v)); return(0); diff --git a/src/ksp/pc/impls/telescope/telescope_dmda.c b/src/ksp/pc/impls/telescope/telescope_dmda.c index edd1708..98d0c7f 100644 --- a/src/ksp/pc/impls/telescope/telescope_dmda.c +++ b/src/ksp/pc/impls/telescope/telescope_dmda.c @@ -757,7 +757,7 @@ PetscErrorCode PCTelescopeMatCreate_dmda(PC pc,PC_Telescope sred,MatReuse reuse,
if (reuse != MAT_INITIAL_MATRIX) {Bred = *A;} ierr = MatGetSize(Blocal,&mm,NULL);CHKERRQ(ierr); - //ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,PETSC_DECIDE,reuse,&Bred);CHKERRQ(ierr); + /* ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,PETSC_DECIDE,reuse,&Bred);CHKERRQ(ierr); */ ierr = MatCreateMPIMatConcatenateSeqMat(subcomm,Blocal,mm,reuse,&Bred);CHKERRQ(ierr); } *A = Bred;
Dave,
I'll be fixing these.
Barry
On Sep 8, 2015, at 9:00 AM, PETSc checkBuilds <[email protected]> wrote:
Dear PETSc developer,
This email contains listings of contributions attributed to you by `git blame` that caused compiler errors or warnings in PETSc automated testing. Follow the links to see the full log files. Please attempt to fix the issues promptly or let us know at [email protected] if you are unable to resolve the issues.
Thanks, The PETSc development team
warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/6ab51f8 PCSemiRedundant:
src/ksp/pc/impls/telescope/telescope.c:116 [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope.c:116:3: warning: 'subdm' may be used uninitialized in this function [-Wmaybe-uninitialized]
src/ksp/pc/impls/telescope/telescope.c:210 [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope.c:210:5: error: expected expression before '/' token
src/ksp/pc/impls/telescope/telescope.c:380 [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope.c:380:12: warning: 'subcomm' may be used uninitialized in this function [-Wmaybe-uninitialized]
src/ksp/pc/impls/telescope/telescope_dmda.c:112 [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:112:18: warning: 'start_IJK' may be used uninitialized in this function [-Wmaybe-uninitialized] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:112:7: warning: 'start_IJK' may be used uninitialized in this function [-Wmaybe-uninitialized]
src/ksp/pc/impls/telescope/telescope_dmda.c:535 [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/balay/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /home/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/balay/petsc.clone-4/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/balay/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:535:54: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
src/ksp/pc/impls/telescope/telescope_dmda.c:609 [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/balay/petsc.clone-4/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/balay/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /home/balay/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone-3/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/balay/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:609:49: warning: variable 'natural_ijk' set but not used [-Wunused-but-set-variable]
src/ksp/pc/impls/telescope/telescope_dmda.c:760 [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/build_next_a...] /sandbox/petsc/petsc.clone-2/src/ksp/pc/impls/telescope/telescope_dmda.c:760:5: error: expected expression before '/' token
---- To opt-out from receiving these messages - send a request to [email protected].
participants (1)
Barry Smith
