Re: [petsc-dev] [petsc-maint #69143] petsc-dev performance issues
If anyone has started work on fixing this, please let me know. Otherwise I'll start shortly. Barry On Apr 18, 2011, at 8:24 AM, Barry Smith wrote:
Matt,
Yes, this is the problem. Since we cannot know if anyone has called a PetscSynchronizedPrintf() it has to call this flush to be safe and that, to be safe, has to have the extra message passing. Even if we handle 1,000 processes at a time, with 100,000 processes it will take 100 stages which is too long.
I think we have to do a major rearchitecturing. Maybe we want to have a flag (set to false by default) in each ASCII viewer indicating that it has synchronize prints. When the flag is false it skips the entire flush and if a synchronize print is done it generates an error. We'll that is easily done.
Barry
On Apr 18, 2011, at 8:10 AM, Matthew Knepley wrote:
On Mon, Apr 18, 2011 at 7:52 AM, Sebastian Steiger <[email protected]>wrote:
On 4/18/2011 7:25 AM, Matthew Knepley wrote:
On Sun, Apr 17, 2011 at 11:59 PM, Sebastian Steiger <[email protected]
17631 is in PetscSynchronizedFlush(), a routine which is not called from
KSPMonitorDefault() ---> PetscViewerASCIIMonitorPrintf()
I am looking over the code, and I think that change is going to be bad for everyone because we have
PetscViewerFlush_ASCII() --> PetscSynchronizedFlush() --> ping-pong between 0 and everyone
Anytime someone calls flush, the process cannot just send 0 and move on, it has to wait.
Matt
and thus would not change the performance. My guess is that you have another print statement using PetscSynchronizedPrintf/Flush() somewhere in the code.
Matt
In addition to the KSPMonitor, I've hooked up the petsc output with my own output system as it is written on the webpage:
PetscErrorCode my_double_petsc_vfprintf(FILE * fd, const char format[], va_list Argp) { PetscErrorCode ierr;
//PetscFunctionBegin; // <ss> gave problems in petsc-3.2 - not essential according to Barry and Matt if (fd != stdout && fd != stderr) { /* handle regular files */ ierr = PetscVFPrintfDefault(fd,format,Argp); PetscMatrixNemo<double>::check_petsc_error(ierr); } else { char buff[2000]; #if PETSC_VERSION_RELEASE == 1 int length; #else size_t length; #endif ierr = PetscVSNPrintf(buff, 2000, format, &length, Argp); PetscMatrixNemo<double>::check_petsc_error(ierr); /* now send buff to whatever stream or whatever you want */ msg << buff;
// flush buffer every 2nd time num_double_petsc_lines++; if (num_double_petsc_lines==2) { msg.flush(); num_double_petsc_lines = 0; } } //PetscFunctionReturn(0); return 0; }
Is that connected to the problem? Please note that the "flush buffer every 2nd time" does not cause the problems, as it is on my side.
Sebastian
Sebastian
On 4/17/2011 9:16 PM, Barry Smith wrote:
On Apr 17, 2011, at 8:11 PM, Matthew Knepley wrote:
On Sun, Apr 17, 2011 at 8:05 PM, Barry Smith <[email protected]
<mailto:[email protected]>> wrote:
I don't understand, what is different and why does it slow
everything down?
You introduced a ping-pong between 0 and every process for every
call to
PetscSynchronizedFlush() in order to "stop a flood of messages to 0". As process count increases, this is going to be horrible.
Oh yes, this will do it Is this being used by one of our monitor routines? If so we need to fix our monitors to not use synchronized printf. So what in the code is calling this.
This is just the kind of thing that MPI should be solving for us,
instead of us
putting in bullshit code like this to try and regulate message counts. Is there an MPI construct to manage this?
One could use some kind of all to one to get the messages down to process zero.
Barry
Matt
Barry
On Apr 17, 2011, at 6:50 PM, Sebastian Steiger wrote:
Barry, Matt, Satish,
Found it. r16730 is good, r16731 is bad. Matt was right: when I
turn off
the petsc messages generated by monitoring the iterations of the linear solver, then the revisions have comparable speed. When I turn it
on,
then 16731 is 2-3 times slower.
Please fix!
Best Sebastian
On 04/15/2011 07:31 AM, Matthew Knepley wrote:
On Thu, Apr 14, 2011 at 11:33 PM, Satish Balay <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>> wrote:
It would be good to complete the bisection to confirm - but could it be this?
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/10be2c80ec26
CHKMEMQ is disabled only with --with-errorchecking=0 - but the assumpton for this change was that it would be disabled for --with-debugging=0 ?
This is my bet for bad set:
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/ee1bdc170b4d
It introduces new messages, but only of length 1. Is your code printing anything at all during the run?
Matt
Satish
On Thu, 14 Apr 2011, Sebastian Steiger wrote:
I'm sorry, actually 16721 is good and 16733 is bad. So it's 12 revisions.
On 4/14/2011 9:12 PM, Sebastian Steiger wrote:
I've pinned it down to 16 revisions: 16721 is good, 16737 is bad. The next bisection step would be 16727, but from the log I see that 16727-16736 might have some problems. Should I continue or do you guys now have a clue what could cause the factor 2-3 slowdown?
Sebastian
steiger@jaguarpf-login6 :~/src/app-nemo/NEMO/libs/petsc-dev/petsc-dev$ hg
log -r16721:16737 changeset: 16721:b788c229de4d parent: 16720:9aafffdcf68b parent: 16715:e53f46924236 user: Jed Brown <[email protected]> date: Mon Aug 09 17:30:28 2010 -0800 summary: merge
changeset: 16722:4ca941c57754 user: [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> date: Tue Aug 10 11:57:11 2010 -0500 summary: add case of np=1 for MatGetMultiProcBlock_MPIAIJ()
changeset: 16723:4d6b54981472 user: [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> date: Tue Aug 10 12:00:14 2010 -0500 summary: fix memory leak in MatHeaderCopy() and MatHeaderReplace()
changeset: 16724:2680bde1c9b8 user: [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> date: Thu Aug 12 14:37:43 2010 -0500 summary: Started adding semismooth stuff.
changeset: 16725:50dceda7151c user: [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> date: Thu Aug 12 14:45:13 2010 -0500 summary: Defined Infinity and epsilon
changeset: 16726:c0f1b46d675f user: hzhang date: Fri Aug 13 11:10:37 2010 -0500 summary: update outputfiles for nightly tests
changeset: 16727:67df4fdba5bd user: [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> date: Fri Aug 13 13:25:56 2010 -0500 summary: add PetscSubcommType in PetscSubcommCreate(); add PetscSubcommCreate_contiguous().
changeset: 16728:10be2c80ec26 parent: 16723:4d6b54981472 user: Barry Smith [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> date: Tue Aug 10 18:15:10 2010 -0500 summary: merged CHKMEMQ; into PetscStackPush() and PetscStackPop()
changeset: 16729:ef8e7a4583e6 user: Barry Smith [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> date: Thu Aug 12 14:16:40 2010 -0500 summary: changed MatHeaderCopy() to MatHeaderMerge() and improved comment
changeset: 16730:50055ed8b725 parent: 16729:ef8e7a4583e6 parent: 16725:50dceda7151c user: Barry Smith [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> date: Thu Aug 12 16:24:48 2010 -0500 summary: commit after merge
changeset: 16731:ee1bdc170b4d user: Barry Smith [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> date: Fri Aug 13 13:50:30 2010 -0500 summary: minor formating of short lines
changeset: 16732:a49d9a4b41bc parent: 16731:ee1bdc170b4d parent: 16727:67df4fdba5bd user: Barry Smith [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> date: Fri Aug 13 13:50:43 2010 -0500 summary: commit after merge
changeset: 16733:804ce43d15c9 user: Jed Brown <[email protected]> date: Fri Aug 13 11:01:24 2010 -0800 summary: Update converged reason for Rosenbrock demo to be more portable
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
<bisection-conclusion.txt>
On Mon, Apr 18, 2011 at 7:52 AM, Sebastian Steiger <[email protected]> wrote:
On Sun, Apr 17, 2011 at 11:59 PM, Sebastian Steiger <[email protected] <mailto:[email protected]>> wrote:
On a side note, why did that PetscPrintf function not show up in the log summary? That could have spared me the whole bisection process.
I cannot make sense of the problem from your report. The only change in 17631 is in PetscSynchronizedFlush(), a routine which is not called from
Matt
Matt
Sebastian
Sebastian
everything down?
call to
instead of us
Barry
Matt
Barry
turn off
the petsc messages generated by monitoring the iterations of the linear solver, then the revisions have comparable speed. When I turn it on, then 16731 is 2-3 times slower.
Please fix!
Best Sebastian
Matt
Satish
Sebastian
steiger@jaguarpf-login6:~/src/app-nemo/NEMO/libs/petsc-dev/petsc-dev$ hg
participants (1)
Barry Smith
