Re: [petsc-dev] Problematic Merge of FieldSplit
I have a couple of questions about the usage DMGetSubDM() to define the splits: 1) Should this be DMGetFieldSubDM(), since I can imagine other types of subDMs (e.g., for a DD subdomain)? In fact, I would advocate something like DMGetFieldSplitSubDM(), because term "field" is getting abused and means both an elementary building block with a split defined by DMGetSubDM() composed of several such fields and the split itself. 2) Why not refer to the fields by string names? A DM could advertise its available fields via DMGetFieldNames() or similar, with default field names such as "0", "1", etc. DMGetFieldSplitSubDM() would take a list of string constants from the list returned by DMGetFieldNames(). This can be implemented independently of DMGetSubDM() to allow both designs to evolve to the point where they can be merged. Dmitry. On Tue, Jun 26, 2012 at 6:13 AM, Matthew Knepley <[email protected]> wrote:
It turns out that 'hg rollback' during an 'hg rebase' does not do what I thought it did. I think everything is cleaned up with this push, but if you made FS changes in the past month, please check that it is doing what you want with prefixes, etc.
Now, nested fieldsplits from the command line work, ala
-ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type additive -pc_fieldsplit_0_fields 0,1 -fieldsplit_0_pc_type fieldsplit -fieldsplit_0_pc_fieldsplit_type schur -fieldsplit_0_pc_fieldsplitschur_factorization_type full -fieldsplit_0_fieldsplit_velocity_ksp_type preonly -fieldsplit_0_fieldsplit_velocity_pc_type lu -fieldsplit_0_fieldsplit_pressure_ksp_rtol 1e-10 -fieldsplit_0_fieldsplit_pressure_pc_type jacobi -pc_fieldsplit_1_fields 2 -fieldsplit_temperature_ksp_type preonly -fieldsplit_temperature_pc_type lu
A split with only one field gets the field name, and otherwise a split number.
Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Dmitry Karpeev
