matload and petsc4py
I'm writing a matrix to file from my fortran code (that uses petsc-3.19.4) with -mat_view binary. Then, I'm trying to load this mat into python (that uses petsc-3.21.0). This works fine using single or multiple procs when the marix was written using a single proc (attached file a_mat_np_1.dat). However, when the matrix was written using mulitple procs (attached file a_mat_n_2.dat) I get the error below. Is this supposed to work? If so, what I'm I doing wrong? $ cat test_matrixImport_binary.py import sys import petsc4py from petsc4py import PETSc from mpi4py import MPI # mat files #filename = "./a_mat_np_1.dat" # Works filename = "./a_mat_np_2.dat" # Doesn't work # Initialize PETSc petsc4py.init(sys.argv) # Create a viewer for reading the binary file viewer = PETSc.Viewer().createBinary(filename, mode='r', comm=PETSc.COMM_WORLD) # Create a matrix and load data from the binary file A = PETSc.Mat().create(comm=PETSc.COMM_WORLD) A.load(viewer) $ python test_matrixImport_binary.py Traceback (most recent call last): File "/projects/P35662.700/test_cklaij/test_matrixImport_binary.py", line 18, in <module> A.load(viewer) File "petsc4py/PETSc/Mat.pyx", line 2025, in petsc4py.PETSc.Mat.load petsc4py.PETSc.Error: error code 79 [0] MatLoad() at /home/cklaij/petsc-3.21.0/src/mat/interface/matrix.c:1344 [0] MatLoad_SeqAIJ() at /home/cklaij/petsc-3.21.0/src/mat/impls/aij/seq/aij.c:5091 [0] MatLoad_SeqAIJ_Binary() at /home/cklaij/petsc-3.21.0/src/mat/impls/aij/seq/aij.c:5142 [0] Unexpected data in file [0] Inconsistent matrix data in file: nonzeros = 460, sum-row-lengths = 761 $ mpirun -n 2 python test_matrixImport_binary.py Traceback (most recent call last): File "/projects/P35662.700/test_cklaij/test_matrixImport_binary.py", line 18, in <module> Traceback (most recent call last): File "/projects/P35662.700/test_cklaij/test_matrixImport_binary.py", line 18, in <module> A.load(viewer) File "petsc4py/PETSc/Mat.pyx", line 2025, in petsc4py.PETSc.Mat.load A.load(viewer) File "petsc4py/PETSc/Mat.pyx", line 2025, in petsc4py.PETSc.Mat.load petsc4py.PETSc.Error: error code 79 [0] MatLoad() at /home/cklaij/petsc-3.21.0/src/mat/interface/matrix.c:1344 [0] MatLoad_MPIAIJ() at /home/cklaij/petsc-3.21.0/src/mat/impls/aij/mpi/mpiaij.c:3035 [0] MatLoad_MPIAIJ_Binary() at /home/cklaij/petsc-3.21.0/src/mat/impls/aij/mpi/mpiaij.c:3087 [0] Unexpected data in file [0] Inconsistent matrix data in file: nonzeros = 460, sum-row-lengths = 761 petsc4py.PETSc.Error: error code 79 [1] MatLoad() at /home/cklaij/petsc-3.21.0/src/mat/interface/matrix.c:1344 [1] MatLoad_MPIAIJ() at /home/cklaij/petsc-3.21.0/src/mat/impls/aij/mpi/mpiaij.c:3035 [1] MatLoad_MPIAIJ_Binary() at /home/cklaij/petsc-3.21.0/src/mat/impls/aij/mpi/mpiaij.c:3087 [1] Unexpected data in file [1] Inconsistent matrix data in file: nonzeros = 460, sum-row-lengths = 761 dr. ir. Christiaan Klaij | Senior Researcher | Research & Development T +31 317 49 33 44 | [email protected] | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!YrcVeQ6V8OD3...
On Thu, Jun 6, 2024, 14:53 Klaij, Christiaan <[email protected]> wrote:
I'm writing a matrix to file from my fortran code (that uses petsc-3. 19. 4) with -mat_view binary. Then, I'm trying to load this mat into python (that uses petsc-3. 21. 0). This works fine using single or multiple procs when the marix ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd I'm writing a matrix to file from my fortran code (that uses petsc-3.19.4) with -mat_view binary. Then, I'm trying to load this mat into python (that uses petsc-3.21.0). This works fine using single or multiple procs when the marix was written using a single proc (attached file a_mat_np_1.dat). However, when the matrix was written using mulitple procs (attached file a_mat_n_2.dat) I get the error below. Is this supposed to work? If so, what I'm I doing wrong?
This should work. And your script seems ok too . How did you save the matrix in parallel? I suspect that file is corrupt
dr. ir. Christiaan Klaij | Senior Researcher | Research & Development T +31 317 49 33 44 <+31%20317%2049%2033%2044> | [email protected] | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!bo30rJrAzGhd... <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWBYeP9zg$> [image: Facebook] <https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWzqK6wKw$> [image: LinkedIn] <https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWIUyfXbM$> [image: YouTube] <https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWjtUkoeg$>
Try without this line CALL PetscViewerPushFormat(viewer, PETSC_VIEWER_DEFAULT, ier) it shouldn't matter but worth trying.
On Jun 6, 2024, at 9:50 AM, Klaij, Christiaan <[email protected]> wrote:
This Message Is From an External Sender This message came from outside your organization. The matrix was saved as with this code:
CALL PetscViewerBinaryOpen(PETSC_COMM_WORLD, filename, FILE_MODE_WRITE, viewer, ier) CALL PetscViewerPushFormat(viewer, PETSC_VIEWER_DEFAULT, ier) CALL MatView(A, viewer, ier) CALL PetscViewerDestroy(viewer, ier)
I will try again to check for file corruption
________________________________________ From: Stefano Zampini <[email protected] <mailto:[email protected]>> Sent: Thursday, June 6, 2024 3:01 PM To: Klaij, Christiaan Cc: PETSc users list Subject: Re: [petsc-users] matload and petsc4py
You don't often get email from [email protected] <mailto:[email protected]>. Learn why this is important<https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!dhd_vSPt_mzy9yVfgQZvw3KcZQwq--Wojmk9JdzuGmnjbC_54Z7IF0WH6qosvtdRyyjv94blDuN1lAlZepr0msg$>
On Thu, Jun 6, 2024, 14:53 Klaij, Christiaan <[email protected] <mailto:[email protected]><mailto:[email protected]>> wrote: I'm writing a matrix to file from my fortran code (that uses petsc-3. 19. 4) with -mat_view binary. Then, I'm trying to load this mat into python (that uses petsc-3. 21. 0). This works fine using single or multiple procs when the marix ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization.
[cid:ii_18feda229ee74859a161] dr. ir. Christiaan Klaij | Senior Researcher | Research & Development T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> | [email protected] <mailto:[email protected]><mailto:[email protected]> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!dhd_vSPt_mzy9yVfgQZvw3KcZQwq--Wojmk9JdzuGmnjbC_54Z7IF0WH6qosvtdRyyjv94blDuN1lAlZod9brMU$<https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWBYeP9zg$> [Facebook]<https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWzqK6wKw$> [LinkedIn]<https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWIUyfXbM$> [YouTube]<https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWjtUkoeg$> <image337700.png><image563921.png><image268336.png><image799923.png>
Well, after trying a second time, the binary file is fine and loads into python without issues. No idea how the first file got corrupted. I've also tried without the PetscViewerPushFormat call, and that works equally well. Thanks for your help! Chris ________________________________________ dr. ir. Christiaan Klaij | Senior Researcher | Research & Development T +31 317 49 33 44 | [email protected] | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!a9GfF_LhoavW... From: Barry Smith <[email protected]> Sent: Thursday, June 6, 2024 7:08 PM To: Klaij, Christiaan Cc: Stefano Zampini; PETSc users list Subject: Re: [petsc-users] matload and petsc4py You don't often get email from [email protected]. Learn why this is important<https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!... > Try without this line CALL PetscViewerPushFormat(viewer, PETSC_VIEWER_DEFAULT, ier) it shouldn't matter but worth trying. On Jun 6, 2024, at 9:50 AM, Klaij, Christiaan <[email protected]> wrote: This Message Is From an External Sender This message came from outside your organization. The matrix was saved as with this code: CALL PetscViewerBinaryOpen(PETSC_COMM_WORLD, filename, FILE_MODE_WRITE, viewer, ier) CALL PetscViewerPushFormat(viewer, PETSC_VIEWER_DEFAULT, ier) CALL MatView(A, viewer, ier) CALL PetscViewerDestroy(viewer, ier) I will try again to check for file corruption ________________________________________ From: Stefano Zampini <[email protected]<mailto:[email protected]>> Sent: Thursday, June 6, 2024 3:01 PM To: Klaij, Christiaan Cc: PETSc users list Subject: Re: [petsc-users] matload and petsc4py You don't often get email from [email protected]<mailto:[email protected]>. Learn why this is important<https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!dhd_vSPt_mzy9yVfgQZvw3KcZQwq--Wojmk9JdzuGmnjbC_54Z7IF0WH6qosvtdRyyjv94blDuN1lAlZepr0msg$> On Thu, Jun 6, 2024, 14:53 Klaij, Christiaan <[email protected]<mailto:[email protected]><mailto:[email protected]>> wrote: I'm writing a matrix to file from my fortran code (that uses petsc-3. 19. 4) with -mat_view binary. Then, I'm trying to load this mat into python (that uses petsc-3. 21. 0). This works fine using single or multiple procs when the marix ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd I'm writing a matrix to file from my fortran code (that uses petsc-3.19.4) with -mat_view binary. Then, I'm trying to load this mat into python (that uses petsc-3.21.0). This works fine using single or multiple procs when the marix was written using a single proc (attached file a_mat_np_1.dat). However, when the matrix was written using mulitple procs (attached file a_mat_n_2.dat) I get the error below. Is this supposed to work? If so, what I'm I doing wrong? This should work. And your script seems ok too . How did you save the matrix in parallel? I suspect that file is corrupt $ cat test_matrixImport_binary.py import sys import petsc4py from petsc4py import PETSc from mpi4py import MPI # mat files #filename = "./a_mat_np_1.dat" # Works filename = "./a_mat_np_2.dat" # Doesn't work # Initialize PETSc petsc4py.init(sys.argv) # Create a viewer for reading the binary file viewer = PETSc.Viewer().createBinary(filename, mode='r', comm=PETSc.COMM_WORLD) # Create a matrix and load data from the binary file A = PETSc.Mat().create(comm=PETSc.COMM_WORLD) A.load(viewer) $ python test_matrixImport_binary.py Traceback (most recent call last): File "/projects/P35662.700/test_cklaij/test_matrixImport_binary.py", line 18, in <module> A.load(viewer) File "petsc4py/PETSc/Mat.pyx", line 2025, in petsc4py.PETSc.Mat.load petsc4py.PETSc.Error: error code 79 [0] MatLoad() at /home/cklaij/petsc-3.21.0/src/mat/interface/matrix.c:1344 [0] MatLoad_SeqAIJ() at /home/cklaij/petsc-3.21.0/src/mat/impls/aij/seq/aij.c:5091 [0] MatLoad_SeqAIJ_Binary() at /home/cklaij/petsc-3.21.0/src/mat/impls/aij/seq/aij.c:5142 [0] Unexpected data in file [0] Inconsistent matrix data in file: nonzeros = 460, sum-row-lengths = 761 $ mpirun -n 2 python test_matrixImport_binary.py Traceback (most recent call last): File "/projects/P35662.700/test_cklaij/test_matrixImport_binary.py", line 18, in <module> Traceback (most recent call last): File "/projects/P35662.700/test_cklaij/test_matrixImport_binary.py", line 18, in <module> A.load(viewer) File "petsc4py/PETSc/Mat.pyx", line 2025, in petsc4py.PETSc.Mat.load A.load(viewer) File "petsc4py/PETSc/Mat.pyx", line 2025, in petsc4py.PETSc.Mat.load petsc4py.PETSc.Error: error code 79 [0] MatLoad() at /home/cklaij/petsc-3.21.0/src/mat/interface/matrix.c:1344 [0] MatLoad_MPIAIJ() at /home/cklaij/petsc-3.21.0/src/mat/impls/aij/mpi/mpiaij.c:3035 [0] MatLoad_MPIAIJ_Binary() at /home/cklaij/petsc-3.21.0/src/mat/impls/aij/mpi/mpiaij.c:3087 [0] Unexpected data in file [0] Inconsistent matrix data in file: nonzeros = 460, sum-row-lengths = 761 petsc4py.PETSc.Error: error code 79 [1] MatLoad() at /home/cklaij/petsc-3.21.0/src/mat/interface/matrix.c:1344 [1] MatLoad_MPIAIJ() at /home/cklaij/petsc-3.21.0/src/mat/impls/aij/mpi/mpiaij.c:3035 [1] MatLoad_MPIAIJ_Binary() at /home/cklaij/petsc-3.21.0/src/mat/impls/aij/mpi/mpiaij.c:3087 [1] Unexpected data in file [1] Inconsistent matrix data in file: nonzeros = 460, sum-row-lengths = 761 [cid:ii_18feda229ee74859a161] dr. ir. Christiaan Klaij | Senior Researcher | Research & Development T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> | [email protected]<mailto:[email protected]><mailto:[email protected]> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!dhd_vSPt_mzy9yVfgQZvw3KcZQwq--Wojmk9JdzuGmnjbC_54Z7IF0WH6qosvtdRyyjv94blDuN1lAlZod9brMU$<https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWBYeP9zg$> [Facebook]<https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWzqK6wKw$> [LinkedIn]<https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWIUyfXbM$> [YouTube]<https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWjtUkoeg$> <image337700.png><image563921.png><image268336.png><image799923.png>
When I attempt to read the "np_2" data into Matlab (the reading process doesn't use any PETSc code) I get the same failure. It does look like the file is corrupted. Barry
On Jun 6, 2024, at 8:52 AM, Klaij, Christiaan <[email protected]> wrote:
This Message Is From an External Sender This message came from outside your organization. I'm writing a matrix to file from my fortran code (that uses petsc-3.19.4) with -mat_view binary. Then, I'm trying to load this mat into python (that uses petsc-3.21.0). This works fine using single or multiple procs when the marix was written using a single proc (attached file a_mat_np_1.dat). However, when the matrix was written using mulitple procs (attached file a_mat_n_2.dat) I get the error below. Is this supposed to work? If so, what I'm I doing wrong?
<image337700.png> dr. ir. Christiaan Klaij | Senior Researcher | Research & Development T +31 317 49 33 44 <tel:+31%20317%2049%2033%2044> | [email protected] <mailto:[email protected]> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!a1xtGgs31Xt_... <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWBYeP9zg$> <image563921.png> <https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWzqK6wKw$> <image268336.png> <https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWIUyfXbM$> <image799923.png> <https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!YrcVeQ6V8OD3jKxSzzxpyuTgFdncWh4YcL1SgDT8NHqystMpzO1pkd17oNGni-ll5I8qH9_ueOtj3WYWjtUkoeg$><a_mat_np_1.dat><a_mat_np_1.dat.info><a_mat_np_2.dat><a_mat_np_2.dat.info>
participants (3)
Barry Smith -
Klaij, Christiaan -
Stefano Zampini
