Newbie question: Strange failure when calling PetscIntView from slepc application
Dear All, I am getting a puzzling 'Segmentation Violation' error when I try to write out an integer array using PetscIntView in a Fortran code. I have written the small code below which reproduces the problem. All this code does is create a PetscInt array, initialise this array, then try to write it out to screen. Interestingly PetscIntView does seem to correctly write out all the values to the screen (which agree with a direct write), but then fails before it can return to the main program (see output pasted in below). I think I must be doing something quite silly, but just can't quite see what it is! Any suggestions will be very welcome. Many thanks, Dan Code: MODULE ALL_STAB_ROUTINES IMPLICIT NONE CONTAINS SUBROUTINE WRITE_ROWS_TO_PETSC_MATRIX( ISIZE, JALOC) #include <slepc/finclude/slepceps.h> use slepceps IMPLICIT NONE PetscInt, INTENT (IN) :: ISIZE PetscInt, INTENT(INOUT), DIMENSION(0:ISIZE-1) :: JALOC PetscErrorCode :: ierr write(*,*)'check 02: ',shape(jaloc),lbound(jaloc),ubound(jaloc) write(*,*)jaloc write(*,*)'now for PetscIntView ...' call PetscIntView(ISIZE,JALOC, PETSC_VIEWER_STDOUT_WORLD) CHKERRA(ierr) END SUBROUTINE WRITE_ROWS_TO_PETSC_MATRIX END MODULE ALL_STAB_ROUTINES program stabbo USE MPI #include <slepc/finclude/slepceps.h> use slepceps USE ALL_STAB_ROUTINES IMPLICIT NONE PetscInt, ALLOCATABLE, DIMENSION(:) :: JALOC PetscInt, PARAMETER :: ISIZE = 10 PetscInt, parameter :: FOUR=4 PetscErrorCode :: ierr_pets call SlepcInitialize(PETSC_NULL_CHARACTER,ierr_pets) ALLOCATE(JALOC(0:ISIZE-1)) JALOC = FOUR write(*,*)'check 01: ',shape(jaloc),lbound(jaloc),ubound(jaloc) CALL WRITE_ROWS_TO_PETSC_MATRIX(ISIZE, JALOC) CALL SlepcFinalize(ierr_pets) END PROGRAM STABBO Output: dan@super01 /data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3 $ mpiexec.hydra -n 1 ./trashy.exe check 01: 10 0 9 check 02: 10 0 9 4 4 4 4 4 4 4 4 4 4 now for PetscIntView ... 0: 4 4 4 4 4 4 4 4 4 4 [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger [0]PETSC ERROR: or see https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors [0]PETSC ERROR: likely location of problem given in stack below [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------ [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available, [0]PETSC ERROR: INSTEAD the line number of the start of the function [0]PETSC ERROR: is given. [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Signal received [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021 [0]PETSC ERROR: ./trashy.exe on a named super01 by darren Fri Apr 9 16:28:25 2021 [0]PETSC ERROR: Configure options --package-prefix-hash=/home/darren/petsc-hash-pkgs --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --with-mpiexec=mpiexec.hydra COPTFLAGS="-g -O" FOPTFLAGS="-g -O" CXXOPTFLAGS="-g -O" --with-64-bit-indices=1 --with-scalar-type=complex --with-precision=double --with-debugging=1 --with-blaslapack-dir=/opt/intel/compilers_and_libraries_2020.0.166/linux/mkl --with-mkl_pardiso-dir=/opt/intel/compilers_and_libraries_2020.0.166/linux/mkl --with-mkl_cpardiso-dir=/opt/intel/compilers_and_libraries_2020.0.166/linux/mkl --download-mumps --download-scalapack --download-cmake PETSC_ARCH=arch-ci-linux-intel-mkl-cmplx-ilp64-dbg-ftn-with-external [0]PETSC ERROR: #1 User provided function() line 0 in unknown file [0]PETSC ERROR: Checking the memory for corruption. Abort(50176059) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 50176059) - process 0
As the error message says, use valgrind https://www.valgrind.org/ <https://www.valgrind.org/> to catch these kind of issues
Code:
Output:
dan@super01 /data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3 $ mpiexec.hydra -n 1 ./trashy.exe check 01: 10 0 9 check 02: 10 0 9 4 4 4 4 4 4 4 4 4 4 now for PetscIntView ... 0: 4 4 4 4 4 4 4 4 4 4 [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger [0]PETSC ERROR: or see https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind <https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind> [0]PETSC ERROR: or try http://valgrind.org <http://valgrind.org/> on GNU/linux and Apple Mac OS X to find memory corruption errors [0]PETSC ERROR: likely location of problem given in stack below [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------ [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available, [0]PETSC ERROR: INSTEAD the line number of the start of the function [0]PETSC ERROR: is given. [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Signal received [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting. [0]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021 [0]PETSC ERROR: ./trashy.exe on a named super01 by darren Fri Apr 9 16:28:25 2021 [0]PETSC ERROR: Configure options --package-prefix-hash=/home/darren/petsc-hash-pkgs --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --with-mpiexec=mpiexec.hydra COPTFLAGS="-g -O" FOPTFLAGS="-g -O" CXXOPTFLAGS="-g -O" --with-64-bit-indices=1 --with-scalar-type=complex --with-precision=double --with-debugging=1 --with-blaslapack-dir=/opt/intel/compilers_and_libraries_2020.0.166/linux/mkl --with-mkl_pardiso-dir=/opt/intel/compilers_and_libraries_2020.0.166/linux/mkl --with-mkl_cpardiso-dir=/opt/intel/compilers_and_libraries_2020.0.166/linux/mkl --download-mumps --download-scalapack --download-cmake PETSC_ARCH=arch-ci-linux-intel-mkl-cmplx-ilp64-dbg-ftn-with-external [0]PETSC ERROR: #1 User provided function() line 0 in unknown file [0]PETSC ERROR: Checking the memory for corruption. Abort(50176059) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 50176059) - process 0
Dear Stefano, Many thanks for your response. I have just installed and run valgrind, and I get the output pasted in below. I can see it seems to be reporting some kind of error, but I don't valgrind well enough to know exactly where it is saying the problem is. Does this suggest the cause of the problem to you ? Many thanks once again, Dan. dan@super01 /data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3 $ valgrind --track-origins=yes --leak-check=full mpiexec.hydra -n 1 ./trashy.exe ==839704== Memcheck, a memory error detector ==839704== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al. ==839704== Using Valgrind-3.15.0 and LibVEX; rerun with -h for copyright info ==839704== Command: mpiexec.hydra -n 1 ./trashy.exe ==839704== ==839704== Conditional jump or move depends on uninitialised value(s) ==839704== at 0x437D9C: HYD_find_base_path (hydra_fs.c:203) ==839704== by 0x41B2D8: mpiexec_get_parameters (mpiexec_params.c:1226) ==839704== by 0x4049F4: main (mpiexec.c:1743) ==839704== ==839704== Conditional jump or move depends on uninitialised value(s) ==839704== at 0x437DAB: HYD_find_base_path (hydra_fs.c:203) ==839704== by 0x41B2D8: mpiexec_get_parameters (mpiexec_params.c:1226) ==839704== by 0x4049F4: main (mpiexec.c:1743) ==839704== ==839704== Conditional jump or move depends on uninitialised value(s) ==839704== at 0x437DB6: HYD_find_base_path (hydra_fs.c:204) ==839704== by 0x41B2D8: mpiexec_get_parameters (mpiexec_params.c:1226) ==839704== by 0x4049F4: main (mpiexec.c:1743) ==839704== ==839704== Syscall param write(buf) points to uninitialised byte(s) ==839704== at 0x488E297: write (write.c:26) ==839704== by 0x43A54D: HYD_sock_write (hydra_sock_intel.c:347) ==839704== by 0x4520AA: send_info_downstream (i_hydra_bstrap.c:618) ==839704== by 0x4520AA: HYD_bstrap_setup (i_hydra_bstrap.c:763) ==839704== by 0x4060A6: main (mpiexec.c:1913) ==839704== Address 0x4d93940 is 0 bytes inside a block of size 300 alloc'd ==839704== at 0x483B7F3: malloc (in /usr/lib/x86_64-linux-gnu/valgrind/vgpreload_memcheck-amd64-linux.so) ==839704== by 0x42F856: create_pg_node_list (i_mpiexec.c:677) ==839704== by 0x4056BD: main (mpiexec.c:1817) ==839704== Uninitialised value was created by a heap allocation ==839704== at 0x483B7F3: malloc (in /usr/lib/x86_64-linux-gnu/valgrind/vgpreload_memcheck-amd64-linux.so) ==839704== by 0x438066: HYD_node_list_append (hydra_node.c:19) ==839704== by 0x404D2F: get_node_list (mpiexec.c:276) ==839704== by 0x404D2F: main (mpiexec.c:1773) ==839704== ==839704== Syscall param write(buf) points to uninitialised byte(s) ==839704== at 0x488E297: write (write.c:26) ==839704== by 0x43A54D: HYD_sock_write (hydra_sock_intel.c:347) ==839704== by 0x4098E9: cmd_bcast_root (mpiexec.c:169) ==839704== by 0x40A60B: push_env_downstream (mpiexec.c:642) ==839704== by 0x407E65: main (mpiexec.c:1944) ==839704== Address 0x1ffeffb6a0 is on thread 1's stack ==839704== in frame #3, created by push_env_downstream (mpiexec.c:562) ==839704== Uninitialised value was created by a stack allocation ==839704== at 0x409CF0: push_env_downstream (mpiexec.c:562) ==839704== ==839704== Syscall param write(buf) points to uninitialised byte(s) ==839704== at 0x488E297: write (write.c:26) ==839704== by 0x43A54D: HYD_sock_write (hydra_sock_intel.c:347) ==839704== by 0x4098E9: cmd_bcast_root (mpiexec.c:169) ==839704== by 0x40A6DD: push_env_downstream (mpiexec.c:648) ==839704== by 0x407E65: main (mpiexec.c:1944) ==839704== Address 0x1ffeffb6a0 is on thread 1's stack ==839704== in frame #3, created by push_env_downstream (mpiexec.c:562) ==839704== Uninitialised value was created by a stack allocation ==839704== at 0x409CF0: push_env_downstream (mpiexec.c:562) ==839704== ==839704== Syscall param write(buf) points to uninitialised byte(s) ==839704== at 0x488E297: write (write.c:26) ==839704== by 0x43A54D: HYD_sock_write (hydra_sock_intel.c:347) ==839704== by 0x4098E9: cmd_bcast_root (mpiexec.c:169) ==839704== by 0x409C3F: push_cwd_downstream (mpiexec.c:682) ==839704== by 0x407F07: main (mpiexec.c:1948) ==839704== Address 0x1ffeffb738 is on thread 1's stack ==839704== in frame #3, created by push_cwd_downstream (mpiexec.c:668) ==839704== Uninitialised value was created by a stack allocation ==839704== at 0x409BC0: push_cwd_downstream (mpiexec.c:668) ==839704== ==839704== Syscall param write(buf) points to uninitialised byte(s) ==839704== at 0x488E297: write (write.c:26) ==839704== by 0x43A54D: HYD_sock_write (hydra_sock_intel.c:347) ==839704== by 0x4098E9: cmd_bcast_root (mpiexec.c:169) ==839704== by 0x4092FF: push_mapping_info_downstream (mpiexec.c:790) ==839704== by 0x40803D: main (mpiexec.c:1957) ==839704== Address 0x1ffeffb738 is on thread 1's stack ==839704== in frame #3, created by push_mapping_info_downstream (mpiexec.c:782) ==839704== Uninitialised value was created by a stack allocation ==839704== at 0x409290: push_mapping_info_downstream (mpiexec.c:782) ==839704== ==839704== Syscall param write(buf) points to uninitialised byte(s) ==839704== at 0x488E297: write (write.c:26) ==839704== by 0x43A54D: HYD_sock_write (hydra_sock_intel.c:347) ==839704== by 0x4098E9: cmd_bcast_root (mpiexec.c:169) ==839704== by 0x413670: initiate_process_launch (mpiexec.c:813) ==839704== by 0x4080D8: main (mpiexec.c:1960) ==839704== Address 0x1ffeffb728 is on thread 1's stack ==839704== in frame #3, created by initiate_process_launch (mpiexec.c:801) ==839704== Uninitialised value was created by a stack allocation ==839704== at 0x4135B0: initiate_process_launch (mpiexec.c:801) ==839704== ==839704== Syscall param write(buf) points to uninitialised byte(s) ==839704== at 0x488E297: write (write.c:26) ==839704== by 0x43A54D: HYD_sock_write (hydra_sock_intel.c:347) ==839704== by 0x4098E9: cmd_bcast_root (mpiexec.c:169) ==839704== by 0x413740: initiate_process_launch (mpiexec.c:819) ==839704== by 0x4080D8: main (mpiexec.c:1960) ==839704== Address 0x1ffeffb728 is on thread 1's stack ==839704== in frame #3, created by initiate_process_launch (mpiexec.c:801) ==839704== Uninitialised value was created by a stack allocation ==839704== at 0x4135B0: initiate_process_launch (mpiexec.c:801) ==839704== ==839704== Syscall param write(buf) points to uninitialised byte(s) ==839704== at 0x488E297: write (write.c:26) ==839704== by 0x43A54D: HYD_sock_write (hydra_sock_intel.c:347) ==839704== by 0x420A36: mpiexec_pmi_barrier (mpiexec_pmi.c:81) ==839704== by 0x40E6AA: control_cb (mpiexec.c:1280) ==839704== by 0x4339CF: HYDI_dmx_poll_wait_for_event (hydra_demux_poll.c:75) ==839704== by 0x4066B9: main (mpiexec.c:2006) ==839704== Address 0x1ffeffb68c is on thread 1's stack ==839704== in frame #2, created by mpiexec_pmi_barrier (mpiexec_pmi.c:13) ==839704== Uninitialised value was created by a stack allocation ==839704== at 0x420850: mpiexec_pmi_barrier (mpiexec_pmi.c:13) ==839704== ==839704== Syscall param write(buf) points to uninitialised byte(s) ==839704== at 0x488E297: write (write.c:26) ==839704== by 0x43A54D: HYD_sock_write (hydra_sock_intel.c:347) ==839704== by 0x420A97: mpiexec_pmi_barrier (mpiexec_pmi.c:48) ==839704== by 0x40E6AA: control_cb (mpiexec.c:1280) ==839704== by 0x4339CF: HYDI_dmx_poll_wait_for_event (hydra_demux_poll.c:75) ==839704== by 0x4066B9: main (mpiexec.c:2006) ==839704== Address 0x1ffeffb698 is on thread 1's stack ==839704== in frame #2, created by mpiexec_pmi_barrier (mpiexec_pmi.c:13) ==839704== Uninitialised value was created by a stack allocation ==839704== at 0x420850: mpiexec_pmi_barrier (mpiexec_pmi.c:13) ==839704== check 01: 10 0 9 check 02: 10 0 9 4 4 4 4 4 4 4 4 4 4 now for PetscIntView ... 0: 4 4 4 4 4 4 4 4 4 4 [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger [0]PETSC ERROR: or see https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors [0]PETSC ERROR: likely location of problem given in stack below [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------ [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available, [0]PETSC ERROR: INSTEAD the line number of the start of the function [0]PETSC ERROR: is given. [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Signal received [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021 [0]PETSC ERROR: ./trashy.exe on a named super01 by darren Fri Apr 9 18:02:16 2021 [0]PETSC ERROR: Configure options --package-prefix-hash=/home/darren/petsc-hash-pkgs --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --with-mpiexec=mpiexec.hydra COPTFLAGS="-g -O" FOPTFLAGS="-g -O" CXXOPTFLAGS="-g -O" --with-64-bit-indices=1 --with-scalar-type=complex --with-precision=double --with-debugging=1 --with-blaslapack-dir=/opt/intel/compilers_and_libraries_2020.0.166/linux/mkl --with-mkl_pardiso-dir=/opt/intel/compilers_and_libraries_2020.0.166/linux/mkl --with-mkl_cpardiso-dir=/opt/intel/compilers_and_libraries_2020.0.166/linux/mkl --download-mumps --download-scalapack --download-cmake PETSC_ARCH=arch-ci-linux-intel-mkl-cmplx-ilp64-dbg-ftn-with-external [0]PETSC ERROR: #1 User provided function() line 0 in unknown file [0]PETSC ERROR: Checking the memory for corruption. Abort(50176059) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 50176059) - process 0 ==839704== ==839704== HEAP SUMMARY: ==839704== in use at exit: 84 bytes in 8 blocks ==839704== total heap usage: 4,061 allocs, 4,053 frees, 1,651,554 bytes allocated ==839704== ==839704== 2 bytes in 1 blocks are definitely lost in loss record 1 of 8 ==839704== at 0x483B7F3: malloc (in /usr/lib/x86_64-linux-gnu/valgrind/vgpreload_memcheck-amd64-linux.so) ==839704== by 0x44EFAE: HYD_str_from_int_pad (hydra_str.c:129) ==839704== by 0x4632F2: i_gtool_proxy_args (i_gtool.c:307) ==839704== by 0x405D5F: main (mpiexec.c:1901) ==839704== ==839704== 30 bytes in 1 blocks are definitely lost in loss record 8 of 8 ==839704== at 0x483B7F3: malloc (in /usr/lib/x86_64-linux-gnu/valgrind/vgpreload_memcheck-amd64-linux.so) ==839704== by 0x4632B4: MPL_strdup (mpl_trmem.h:295) ==839704== by 0x4632B4: i_gtool_proxy_args (i_gtool.c:306) ==839704== by 0x405D5F: main (mpiexec.c:1901) ==839704== ==839704== LEAK SUMMARY: ==839704== definitely lost: 32 bytes in 2 blocks ==839704== indirectly lost: 0 bytes in 0 blocks ==839704== possibly lost: 0 bytes in 0 blocks ==839704== still reachable: 52 bytes in 6 blocks ==839704== suppressed: 0 bytes in 0 blocks ==839704== Reachable blocks (those to which a pointer was found) are not shown. ==839704== To see them, rerun with: --leak-check=full --show-leak-kinds=all ==839704== ==839704== For lists of detected and suppressed errors, rerun with: -s ==839704== ERROR SUMMARY: 15 errors from 14 contexts (suppressed: 0 from 0) ________________________________ From: Stefano Zampini <[email protected]> Sent: Friday, April 9, 2021 7:46 AM To: dazza simplythebest <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: [petsc-users] Newbie question: Strange failure when calling PetscIntView from slepc application As the error message says, use valgrind https://www.valgrind.org/ to catch these kind of issues On Apr 9, 2021, at 10:43 AM, dazza simplythebest <[email protected]<mailto:[email protected]>> wrote: Dear All, I am getting a puzzling 'Segmentation Violation' error when I try to write out an integer array using PetscIntView in a Fortran code. I have written the small code below which reproduces the problem. All this code does is create a PetscInt array, initialise this array, then try to write it out to screen. Interestingly PetscIntView does seem to correctly write out all the values to the screen (which agree with a direct write), but then fails before it can return to the main program (see output pasted in below). I think I must be doing something quite silly, but just can't quite see what it is! Any suggestions will be very welcome. Many thanks, Dan Code: MODULE ALL_STAB_ROUTINES IMPLICIT NONE CONTAINS SUBROUTINE WRITE_ROWS_TO_PETSC_MATRIX( ISIZE, JALOC) #include <slepc/finclude/slepceps.h> use slepceps IMPLICIT NONE PetscInt, INTENT (IN) :: ISIZE PetscInt, INTENT(INOUT), DIMENSION(0:ISIZE-1) :: JALOC PetscErrorCode :: ierr write(*,*)'check 02: ',shape(jaloc),lbound(jaloc),ubound(jaloc) write(*,*)jaloc write(*,*)'now for PetscIntView ...' call PetscIntView(ISIZE,JALOC, PETSC_VIEWER_STDOUT_WORLD) CHKERRA(ierr) END SUBROUTINE WRITE_ROWS_TO_PETSC_MATRIX END MODULE ALL_STAB_ROUTINES program stabbo USE MPI #include <slepc/finclude/slepceps.h> use slepceps USE ALL_STAB_ROUTINES IMPLICIT NONE PetscInt, ALLOCATABLE, DIMENSION(:) :: JALOC PetscInt, PARAMETER :: ISIZE = 10 PetscInt, parameter :: FOUR=4 PetscErrorCode :: ierr_pets call SlepcInitialize(PETSC_NULL_CHARACTER,ierr_pets) ALLOCATE(JALOC(0:ISIZE-1)) JALOC = FOUR write(*,*)'check 01: ',shape(jaloc),lbound(jaloc),ubound(jaloc) CALL WRITE_ROWS_TO_PETSC_MATRIX(ISIZE, JALOC) CALL SlepcFinalize(ierr_pets) END PROGRAM STABBO Output: dan@super01 /data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3 $ mpiexec.hydra -n 1 ./trashy.exe check 01: 10 0 9 check 02: 10 0 9 4 4 4 4 4 4 4 4 4 4 now for PetscIntView ... 0: 4 4 4 4 4 4 4 4 4 4 [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger [0]PETSC ERROR: or see https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind [0]PETSC ERROR: or try http://valgrind.org<http://valgrind.org/> on GNU/linux and Apple Mac OS X to find memory corruption errors [0]PETSC ERROR: likely location of problem given in stack below [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------ [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available, [0]PETSC ERROR: INSTEAD the line number of the start of the function [0]PETSC ERROR: is given. [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Signal received [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021 [0]PETSC ERROR: ./trashy.exe on a named super01 by darren Fri Apr 9 16:28:25 2021 [0]PETSC ERROR: Configure options --package-prefix-hash=/home/darren/petsc-hash-pkgs --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --with-mpiexec=mpiexec.hydra COPTFLAGS="-g -O" FOPTFLAGS="-g -O" CXXOPTFLAGS="-g -O" --with-64-bit-indices=1 --with-scalar-type=complex --with-precision=double --with-debugging=1 --with-blaslapack-dir=/opt/intel/compilers_and_libraries_2020.0.166/linux/mkl --with-mkl_pardiso-dir=/opt/intel/compilers_and_libraries_2020.0.166/linux/mkl --with-mkl_cpardiso-dir=/opt/intel/compilers_and_libraries_2020.0.166/linux/mkl --download-mumps --download-scalapack --download-cmake PETSC_ARCH=arch-ci-linux-intel-mkl-cmplx-ilp64-dbg-ftn-with-external [0]PETSC ERROR: #1 User provided function() line 0 in unknown file [0]PETSC ERROR: Checking the memory for corruption. Abort(50176059) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 50176059) - process 0
This way you are running mpiexec.hydra under valgrind. You want to run instead mpiexec.hydra -n 1 valgrind --track-origins=yes --leak-check=full --fullpath-after= ./trashy.exe
Dear Stefano, Thanks for your response. I have re-run the command as per your suggestion below, and I get the full output as attached to this email ( the output was quite long so I thought it better to attach it). However, I am wondering whether the following lines of this output, which occur just when the program fails, may be something to do with the problem ? Many thanks, Dan. . . . check 01: 10 0 9 check 02: 10 0 9 4 4 4 4 4 4 4 4 4 4 now for PetscIntView ... 0: 4 4 4 4 4 4 4 4 4 4 ==841883== Invalid write of size 4 ==841883== at 0x503E784: petscintview_ (/data/work/slepc/PETSC/petsc-3.14.5/src/sys/error/ftn-custom/zerrf.c:109) ==841883== by 0x40262C: all_stab_routines_mp_write_rows_to_petsc_matrix_ (/data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/tryme.F:17) ==841883== by 0x402465: MAIN__ (/data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/tryme.F:40) ==841883== by 0x402221: main (in /data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/trashy.exe) ==841883== Address 0x0 is not stack'd, malloc'd or (recently) free'd ==841883== [0]PETSC ERROR: ------------------------------------------------------------------------[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range . . . ________________________________ From: Stefano Zampini <[email protected]> Sent: Friday, April 9, 2021 9:17 AM To: dazza simplythebest <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: [petsc-users] Newbie question: Strange failure when calling PetscIntView from slepc application This way you are running mpiexec.hydra under valgrind. You want to run instead mpiexec.hydra -n 1 valgrind --track-origins=yes --leak-check=full --fullpath-after= ./trashy.exe On Apr 9, 2021, at 12:11 PM, dazza simplythebest <[email protected]<mailto:[email protected]>> wrote: valgrind --track-origins=yes --leak-check=full mpiexec.hydra -n 1 ./trashy.exe
==841883== Invalid write of size 4 ==841883== at 0x503E784: petscintview_ (/data/work/slepc/PETSC/petsc-3.14.5/src/sys/error/ftn-custom/zerrf.c:109) ==841883== by 0x40262C: all_stab_routines_mp_write_rows_to_petsc_matrix_ (/data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/tryme.F:17) ==841883== by 0x402465: MAIN__ (/data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/tryme.F:40) ==841883== by 0x402221: main (in /data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/trashy.exe) ==841883== Address 0x0 is not stack'd, malloc'd or (recently) free'd ==841883== This exactly points to the error and suggests you to take a look at /data/work/slepc/PETSC/petsc-3.14.5/src/sys/error/ftn-custom/zerrf.c, line 109 You are trying to write 4 bytes (most probably an int) where is not allowed.
Hello, I think you forgot to pass ierr as the last argument of PetscIntView. Pierre On 09/04/21 11:52, Stefano Zampini wrote:
On Apr 9, 2021, at 12:32 PM, dazza simplythebest <[email protected] <mailto:[email protected]>> wrote:
Dear Pierre and Stefano, Yes - that is it! I had just stumbled onto that point as your email arrived thanks to Stefano's guidance, which suggested the problem was that the routine was receiving an integer when it was expecting something else... then a lightbulb finally switched on and I finally remembered that I needed to add the error variable as a final argument. I thought it was something silly on my part, and I wasn't mistaken there at least! Many thanks to both of you, best wishes, Dan. ________________________________ From: Pierre Seize <[email protected]> Sent: Friday, April 9, 2021 10:14 AM To: Stefano Zampini <[email protected]>; dazza simplythebest <[email protected]> Cc: [email protected] <[email protected]> Subject: Re: [petsc-users] Newbie question: Strange failure when calling PetscIntView from slepc application Hello, I think you forgot to pass ierr as the last argument of PetscIntView. Pierre On 09/04/21 11:52, Stefano Zampini wrote: ==841883== Invalid write of size 4 ==841883== at 0x503E784: petscintview_ (/data/work/slepc/PETSC/petsc-3.14.5/src/sys/error/ftn-custom/zerrf.c:109) ==841883== by 0x40262C: all_stab_routines_mp_write_rows_to_petsc_matrix_ (/data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/tryme.F:17) ==841883== by 0x402465: MAIN__ (/data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/tryme.F:40) ==841883== by 0x402221: main (in /data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/trashy.exe) ==841883== Address 0x0 is not stack'd, malloc'd or (recently) free'd ==841883== This exactly points to the error and suggests you to take a look at /data/work/slepc/PETSC/petsc-3.14.5/src/sys/error/ftn-custom/zerrf.c, line 109 You are trying to write 4 bytes (most probably an int) where is not allowed. On Apr 9, 2021, at 12:32 PM, dazza simplythebest <[email protected]<mailto:[email protected]>> wrote: ==841883== Invalid write of size 4 ==841883== at 0x503E784: petscintview_ (/data/work/slepc/PETSC/petsc-3.14.5/src/sys/error/ftn-custom/zerrf.c:109) ==841883== by 0x40262C: all_stab_routines_mp_write_rows_to_petsc_matrix_ (/data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/tryme.F:17) ==841883== by 0x402465: MAIN__ (/data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/tryme.F:40) ==841883== by 0x402221: main (in /data/work/rotplane/omega_to_zero/stability/test/tmp10/tmp3/trashy.exe) ==841883== Address 0x0 is not stack'd, malloc'd or (recently) free'd ==841883==
I have submitted a MR that adds a Fortran interface for these functions so it will automatically error at compile time if you do not include the appropriate arguments. Barry
From: Pierre Seize <[email protected] <mailto:[email protected]>> Sent: Friday, April 9, 2021 10:14 AM To: Stefano Zampini <[email protected] <mailto:[email protected]>>; dazza simplythebest <[email protected] <mailto:[email protected]>> Cc: [email protected] <mailto:[email protected]> <[email protected] <mailto:[email protected]>> Subject: Re: [petsc-users] Newbie question: Strange failure when calling PetscIntView from slepc application
participants (4)
Barry Smith -
dazza simplythebest -
Pierre Seize -
Stefano Zampini
