Inquiry about PetscDS for discretization of second order system
Dear PETSc developer group, I'd like to inquire that if PetscDSSetResidual can be used for second order system? Are there a DS function that is related to solve a system that contains second order time derivative such as time dependent linear elasticity problem. I found there is tutorial for elastostatics problem using PetscDS but this doesn't involve time discretization. In TS, there is alpha method for solving second order system, but I haven't found a tutorial using DS yet. Is there a way to combine PetscDS with the alpha method in TS? Best Regards, Yujie
I did not include the second derivative in the interface. Instead what I do is rewrite it as a first order system using v = \dot u. I hope to augment the interface sometime to add the second derivative, but it really only applies to that alpha integrator. Thanks, Matt
Best Regards, Yujie
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCf... <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfs... >
participants (2)
Gong Yujie -
Matthew Knepley
