Dear All, I am interfacing our CFD code (Fortran + OpenACC) to Petsc. Since we use OpenACC the natural choice for us is to use Nvidia´s nvhpc compiler. The Gnu compiler does not work well and we do not have access to the Cray compiler. I already know that the latest version of Petsc does not compile with nvhpc, I am therefore using version 3.21. I get good results on the CPU both in serial and parallel (MPI). However, the GPU implementation, that is what we are interested in, only work correctly for the serial version. In parallel, the results are different. Even for a CG solve. I would like to know, if you have experience with the Nvidia compiler. I am particularly interested if you have already observed issues with it. Your opinion on whether to put further effort into trying to find a bug I may have introduced during the interfacing is highly appreciated. Best, Herbert Owen Senior Researcher, Dpt. Computer Applications in Science and Engineering Barcelona Supercomputing Center (BSC-CNS) Tel: +34 93 413 4038 Skype: herbert.owen https://urldefense.us/v3/__https://scholar.google.es/citations?user=qe5O2IYA...
Hi, Herbert, I don't have much experience on OpenACC and PETSc CI doesn't have such tests. Could you avoid using nvfortran and instead use gfortran to compile your Fortran + OpenACC code? If you, then you can use the latest petsc code and make our debugging easier. Also, could you provide us with a test and instructions to reproduce the problem? Thanks! --Junchao Zhang On Thu, Oct 16, 2025 at 5:07 AM howen via petsc-users < [email protected]> wrote:
Dear All,
Best,
https://urldefense.us/v3/__https://scholar.google.es/citations?user=qe5O2IYA... <https://urldefense.us/v3/__https://scholar.google.es/citations?user=qe5O2IYAAAAJ&hl=en__;!!G_uCfscf7eWS!abuM7ozzUs7eISYBumHNxpvO2Tuy74KRM4-WWcunXHZVjQf1V032xQrCzTfC5vA_NM-35xMEZ9yJ8XK-3QFqjWBSWuUi$>
We recommend using PETSc 3.23.7 if you need to use the Nvidia Fortran compiler. Please try this version. If problems persist, could you send a reproducer as Junchao asked, and we will see if we can resolve the issue? Barry
On Thu, Oct 16, 2025 at 5:07 AM howen via petsc-users <[email protected] <mailto:[email protected]>> wrote:
Dear All,
Best,
Actually petsc-3.22 (i.e. 3.22.5) is the last version that works with nvfortran Satish On Thu, 16 Oct 2025, Barry Smith wrote:
Barry
Dear All,
Best,
Oh, yikes. Sorry for providing the wrong information, definitely work with 3.22.5 to use nvfortran. Barry
Satish
Barry
Dear All,
Best,
Dear Junchao, Thank you for response and sorry for taking so long to answer back. I cannot avoid using the nvidia tools. Gfortran is not mature for OpenACC and gives us problems when compiling our code. What I have done to enable using the latest petsc is to create my own C code to call petsc. I have little experience with c and it took me some time, but I can now use petsc 3.24.1 ;) The behaviour remains the same as in my original email . Parallel+GPU gives bad results. CPU(serial and parallel) and GPU serial all work ok and give the same result. I have gone a bit into petsc comparing the CPU and GPU version with 2 mpi. I see that the difference starts in src/ksp/ksp/impls/cg/cg.c L170 PetscCall(KSP_PCApply(ksp, R, Z)); /* z <- Br */ I have printed the vectors R and Z and the norm dp. R is identical on both CPU and GPU; but Z differs. The correct value of dp (for the first time it enters) is 14.3014, while running on the GPU with 2 mpis it gives 14.7493. If you wish I can send you prints I introduced in cg.c The folder with the input files to run the case can be downloaded from https://urldefense.us/v3/__https://b2drop.eudat.eu/s/wKRQ4LK7RTKz2iQ__;!!G_u... For submitting the gpu run I use mpirun -np 2 --map-by ppr:4:node:PE=20 --report-bindings ./mn5_bind.sh /gpfs/scratch/bsc21/bsc021257/git/140-add-petsc/sod2d_gitlab/build_gpu/src/app_sod2d/sod2d ChannelFlowSolverIncomp.json For the cpu run mpirun -np 2 /gpfs/scratch/bsc21/bsc021257/git/140-add-petsc/sod2d_gitlab/build_cpu/src/app_sod2d/sod2d ChannelFlowSolverIncomp.json Our code can be downloaded with : git clone --recursive https://urldefense.us/v3/__https://gitlab.com/bsc_sod2d/sod2d_gitlab.git__;!... -and the branch I am using with git checkout 140-add-petsc To use exactly the same commit I am using git checkout 09a923c9b57e46b14ae54b935845d50272691ace I am currently using: Currently Loaded Modules: 1) nvidia-hpc-sdk/25.1 2) hdf5/1.14.1-2-nvidia-nvhpcx 3) cmake/3.25.1 I guess/hope similar modules should be available in any supercomputer. To build the cpu version mkdir build_cpu cd build_cpu export PETSC_INSTALL=/gpfs/scratch/bsc21/bsc021257/git/petsc_oct25/3241_cpu/hhinstal export LD_LIBRARY_PATH=$PETSC_INSTALL/lib:$LD_LIBRARY_PATH export LIBRARY_PATH=$PETSC_INSTALL/lib:$LIBRARY_PATH export C_INCLUDE_PATH=$PETSC_INSTALL/include:$C_INCLUDE_PATH export CPLUS_INCLUDE_PATH=$PETSC_INSTALL/include:$CPLUS_INCLUDE_PATH export PKG_CONFIG_PATH=$PETSC_INSTALL/lib/pkgconfig:$PKG_CONFIG_PATH cmake -DUSE_RP=8 -DUSE_PORDER=3 -DUSE_PETSC=ON -DUSE_GPU=OFF -DDEBUG_MODE=OFF .. make -j 80 I have built petsc myself as follows git clone -b release https://urldefense.us/v3/__https://gitlab.com/petsc/petsc.git__;!!G_uCfscf7e... petsc cd petsc git checkout v3.24.1 module purge module load nvidia-hpc-sdk/25.1 hdf5/1.14.1-2-nvidia-nvhpcx cmake/3.25.1 ./configure --PETSC_DIR=/gpfs/scratch/bsc21/bsc021257/git/petsc_oct25/3241/petsc --prefix=/gpfs/scratch/bsc21/bsc021257/git/petsc_oct25/3241/hhinstal --with-fortran-bindings=0 --with-fc=0 --with-petsc-arch=linux-x86_64-opt --with-scalar-type=real --with-debugging=yes --with-64-bit-indices=1 --with-precision=single --download-hypre CFLAGS=-I/apps/ACC/HDF5/1.14.1-2/NVIDIA/NVHPCX/include CXXFLAGS= FCFLAGS= --with-shared-libraries=1 --with-mpi=1 --with-blacs-lib=/gpfs/apps/MN5/ACC/ONEAPI/2025.1/mkl/2025.1/lib/intel64/libmkl_blacs_openmpi_lp64.a --with-blacs-include=/gpfs/apps/MN5/ACC/ONEAPI/2025.1/mkl/2025.1/include --with-mpi-dir=/apps/ACC/NVIDIA-HPC-SDK/25.1/Linux_x86_64/25.1/comm_libs/12.6/hpcx/latest/ompi/ --download-ptscotch=yes --download-metis --download-parmetis make all check make install ------------------- For the GPU version when configuring petsc I add : --with-cuda I then change the export PETSC_INSTALL to export PETSC_INSTALL=/gpfs/scratch/bsc21/bsc021257/git/petsc_oct25/3241/hhinstal and repeat all other exports mkdir build_gpu cd build_gpu cmake -DUSE_RP=8 -DUSE_PORDER=3 -DUSE_PETSC=ON -DUSE_GPU=ON -DDEBUG_MODE=OFF .. make -j 80 As you can see from the submit instructions the executable is found in sod2d_gitlab/build_gpu/src/app_sod2d/sod2d I hope I have not forgotten anything and my instructions are 'easy' to follow. If you have any issue do not doubt to contact me. The wiki for our code can be found in https://urldefense.us/v3/__https://gitlab.com/bsc_sod2d/sod2d_gitlab/-/wikis... Best, Herbert Owen Herbert Owen Senior Researcher, Dpt. Computer Applications in Science and Engineering Barcelona Supercomputing Center (BSC-CNS) Tel: +34 93 413 4038 Skype: herbert.owen https://urldefense.us/v3/__https://scholar.google.es/citations?user=qe5O2IYA...
Dear All,
Best,
On Thu, Nov 13, 2025 at 12:11 PM howen via petsc-users < [email protected]> wrote:
Dear Junchao,
Thank you for all the detail in this report. However, since you see a problem in KSPCG, I believe we can reduce the complexity. You can use -ksp_view_mat binary:A.bin -ksp_view_rhs binary:b.bin and send us those files. Then we can run your system directly using KSP ex10 (and so can you). Thanks, Matt
The folder with the input files to run the case can be downloaded from https://urldefense.us/v3/__https://b2drop.eudat.eu/s/wKRQ4LK7RTKz2iQ__;!!G_u... <https://urldefense.us/v3/__https://b2drop.eudat.eu/s/wKRQ4LK7RTKz2iQ__;!!G_uCfscf7eWS!Y_YIXIdrN81gDKgNed6V4icL3nN9OG62-ZsdnB1Bkc7iiGAoJ2riwbTzxJMnIROon3mXgiFVLnbH0RTlsXrLEAh7n_UO$>
Our code can be downloaded with : git clone --recursive https://urldefense.us/v3/__https://gitlab.com/bsc_sod2d/sod2d_gitlab.git__;!... <https://urldefense.us/v3/__https://gitlab.com/bsc_sod2d/sod2d_gitlab.git__;!!G_uCfscf7eWS!Y_YIXIdrN81gDKgNed6V4icL3nN9OG62-ZsdnB1Bkc7iiGAoJ2riwbTzxJMnIROon3mXgiFVLnbH0RTlsXrLEFjsBTIo$>
git clone -b release https://urldefense.us/v3/__https://gitlab.com/petsc/petsc.git__;!!G_uCfscf7e... <https://urldefense.us/v3/__https://gitlab.com/petsc/petsc.git__;!!G_uCfscf7eWS!Y_YIXIdrN81gDKgNed6V4icL3nN9OG62-ZsdnB1Bkc7iiGAoJ2riwbTzxJMnIROon3mXgiFVLnbH0RTlsXrLELP8U6d0$> petsc cd petsc git checkout v3.24.1 module purge module load nvidia-hpc-sdk/25.1 hdf5/1.14.1-2-nvidia-nvhpcx cmake/3.25.1 ./configure --PETSC_DIR=/gpfs/scratch/bsc21/bsc021257/git/petsc_oct25/3241/petsc --prefix=/gpfs/scratch/bsc21/bsc021257/git/petsc_oct25/3241/hhinstal --with-fortran-bindings=0 --with-fc=0 --with-petsc-arch=linux-x86_64-opt --with-scalar-type=real --with-debugging=yes --with-64-bit-indices=1 --with-precision=single --download-hypre CFLAGS=-I/apps/ACC/HDF5/1.14.1-2/NVIDIA/NVHPCX/include CXXFLAGS= FCFLAGS= --with-shared-libraries=1 --with-mpi=1 --with-blacs-lib=/gpfs/apps/MN5/ACC/ONEAPI/2025.1/mkl/2025.1/lib/intel64/libmkl_blacs_openmpi_lp64.a --with-blacs-include=/gpfs/apps/MN5/ACC/ONEAPI/2025.1/mkl/2025.1/include --with-mpi-dir=/apps/ACC/NVIDIA-HPC-SDK/25.1/Linux_x86_64/25.1/comm_libs/12.6/hpcx/latest/ompi/ --download-ptscotch=yes --download-metis --download-parmetis make all check make install
I hope I have not forgotten anything and my instructions are 'easy' to follow. If you have any issue do not doubt to contact me. The wiki for our code can be found in https://urldefense.us/v3/__https://gitlab.com/bsc_sod2d/sod2d_gitlab/-/wikis... <https://urldefense.us/v3/__https://gitlab.com/bsc_sod2d/sod2d_gitlab/-/wikis/home__;!!G_uCfscf7eWS!Y_YIXIdrN81gDKgNed6V4icL3nN9OG62-ZsdnB1Bkc7iiGAoJ2riwbTzxJMnIROon3mXgiFVLnbH0RTlsXrLEA1vqPYk$>
Best,
Herbert Owen
https://urldefense.us/v3/__https://scholar.google.es/citations?user=qe5O2IYA... <https://urldefense.us/v3/__https://scholar.google.es/citations?user=qe5O2IYAAAAJ&hl=en__;!!G_uCfscf7eWS!Y_YIXIdrN81gDKgNed6V4icL3nN9OG62-ZsdnB1Bkc7iiGAoJ2riwbTzxJMnIROon3mXgiFVLnbH0RTlsXrLEAA5PwtO$>
Dear All,
Best,
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCf... <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfs... >
Thank you very much Matthew, I did what you suggested and I also added ierr = MatView(*amat, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr); Now that I can see the matrices I notice that some values differ. I will debug and simplify my code to try to understand where the difference comes from . As soon as I have a more clear picture I will contact you back. Best, Herbert Owen Senior Researcher, Dpt. Computer Applications in Science and Engineering Barcelona Supercomputing Center (BSC-CNS) Tel: +34 93 413 4038 Skype: herbert.owen https://urldefense.us/v3/__https://scholar.google.es/citations?user=qe5O2IYA...
On 13 Nov 2025, at 18:23, Matthew Knepley <[email protected]> wrote:
On Thu, Nov 13, 2025 at 12:11 PM howen via petsc-users <[email protected] <mailto:[email protected]>> wrote:
Dear Junchao,
Matt
Best,
Herbert Owen
On 16 Oct 2025, at 18:30, Junchao Zhang <[email protected] <mailto:[email protected]>> wrote:
Dear All,
Best,
Dear Matthew and Junchao, I finally found my error now everything works fine. I was a bit stuck at some moment and your small comments were very helpful. Thanks!!! Herbert Owen Senior Researcher, Dpt. Computer Applications in Science and Engineering Barcelona Supercomputing Center (BSC-CNS) Tel: +34 93 413 4038 Skype: herbert.owen https://urldefense.us/v3/__https://scholar.google.es/citations?user=qe5O2IYA...
Best,
Dear Junchao,
Matt
Best,
Herbert Owen
Dear All,
Best,
participants (5)
Barry Smith -
howen -
Junchao Zhang -
Matthew Knepley -
Satish Balay
