Parallel matrix assembly questions
Hello, I need to build a dense matrix in parallel and looking at examples in ksp/examples/tutorials it seems there are two approaches. In ex3.c MPI_Comm_rank and MPI_Comm_size are used to compute the index range for the current processor and ex5.c uses MatGetOwnershipRange to figure out the index range. 1- Is there any advantage using either of these methods or they will behave the same when it comes to performance and portability ? Based on comments in ex5.c, PETSc partitions the matrix by contiguous chunks of rows. 2- Is there a way of changing this scheme using PETSc routines ? 3- If not, can I partition my matrix in a different way, say 2D block cycling method, and still be able to use PETSc to solve it ? Since my matrix is dense I am going to start with direct solvers and I am concerned whether the partitioning scheme will affect the solver's performance. thanks in advance, Hamid
On Jan 12, 2011, at 4:53 PM, Hamid M. wrote:
Hello,
Use MatGetOwnershipRange because it works with any Mat layout.
No
No
It will affect performance, unless you hope/plan to use iterative solvers there is no good reason to use PETSc for dense matrices with direct solvers. That is another world with a different world of software. Barry
Thanks for the helpful response. Just from theoretical point of view, are iterative solvers suitable for a dense matrix or it doesn't really matter ? I know direct solvers would perform faster for problems with multiple RHS values and a fixed LHS matrix, but how what are the main factors one needs to consider when dealing with dense matrices and various solvers. Hamid
It depends on the conditioning of the matrix. For some matrices (for example from some boundary element methods) the system can be solved with a couple dozen GMES iterations which is much much faster than using a direct solver. For other problems GMRES would be slower than a direct solver. Barry
Hamid
participants (2)
Barry Smith -
Hamid M.
