How to show the x window for cmd `make -f ./gmakefile test ...`?
Hi, everyone, I am trying to run some test cases with x window, but the x window never showed up with command `make -f ./gmakefile test ...`. It seems a default option `-nox` is set. How to disable this option for `make test`? An example is shown below: ``` z2yang@ws6:~/repos/petsc$ PETSC_ARCH=arch-main-debug make -f ./gmakefile test search="dm_impls_plex_tests-ex20_2d" TIMEOUT=5000 EXTRA_OPTIONS="-post_adapt_dm_view draw:x -draw_pause -1 -options_view -petsc_ci false" Using MAKEFLAGS: -- EXTRA_OPTIONS=-post_adapt_dm_view draw:x -draw_pause -1 -options_view -petsc_ci false TIMEOUT=5000 search=dm_impls_plex_tests-ex20_2d TEST arch-main-debug/tests/counts/dm_impls_plex_tests-ex20_2d.counts ok dm_impls_plex_tests-ex20_2d not ok diff-dm_impls_plex_tests-ex20_2d # Error code: 1 # 12,22c12,26 # < DM Object: Post Adaptation Mesh 1 MPI process # < type: plex # < Post Adaptation Mesh in 2 dimensions: # < Number of 0-cells per rank: 49 # < Number of 1-cells per rank: 120 # < Number of 2-cells per rank: 72 # < Labels: # < celltype: 3 strata with value/size (1 (120), 3 (72), 0 (49)) # < depth: 3 strata with value/size (0 (49), 1 (120), 2 (72)) # < marker: 1 strata with value/size (1 (48)) # < Face Sets: 1 strata with value/size (1 (36)) # --- # > #PETSc Option Table entries: # > -check_pointer_intensity 0 # > -dm_coord_space 0 # > -dm_plex_box_faces 3,3 # > -draw_pause -1 # > -error_output_stdout # > -malloc_dump # > -nox # > -nox_warning # > -options_view # > -petsc_ci false # > -post_adapt_dm_view draw:x # > -pre_adapt_dm_view ascii::ascii_info # > -use_gpu_aware_mpi 0 # > #End of PETSc Option Table entries # FAILED diff-dm_impls_plex_tests-ex20_2d # # To rerun failed tests: # /usr/bin/gmake -f gmakefile test test-fail=1 ``` Thanks, Zongze
On Thu, Oct 6, 2022 at 9:16 AM Zongze Yang <[email protected]> wrote:
Hi, everyone,
Yes, we disable it for tests by default in order to make the CI efficient. You can edit $PETSC_DIR/$PETSC_ARCH/lib/petsc/conf/petscvariables and remove it from PETSC_TEST_OPTIONS, which should be the last line. Thanks, Matt
Thanks, Zongze
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Thanks! Matthew Knepley <[email protected]> 于2022年10月6日周四 16:19写道:
Hi, everyone,
Matt
Thanks, Zongze
participants (2)
Matthew Knepley -
Zongze Yang
