For Fortran users of the PETSc development (git master branch) version I have updated and simplified the Fortran usage of PETSc in the past few weeks. I will put the branch barry/fortran-update into the master branch on Monday. The usage changes are A) for each Fortran function (and main) use the following subroutine mysubroutine(.....) #include <petsc/finclude/petscxxx.h> use petscxxx implicit none For example if you are using SNES in your code you would have #include <petsc/finclude/petscsnes.h> use petscsnes implicit none B) Instead of PETSC_NULL_OBJECT you must pass PETSC_NULL_XXX (for example PETSC_NULL_VEC) using the specific object type XXX that the function call is expecting. C) Objects can be declared either as XXX a or type(iXXX) a, for example Mat a or type(iMat) a. (Note that previously for those who used types it was type(Mat) but that can no longer be used. Notes: 1) There are no longer any .h90 files that may be included 2) Like C the include files are now nested so you no longer need to include for example #include <petsc/finclude/petscsys.h> #include <petsc/finclude/petscvec.h> #include <petsc/finclude/petscmat.h> #include <petsc/finclude/petscpc.h> #include <petsc/finclude/petscksp.h> you can just include #include <petsc/finclude/petscksp.h> 3) there is now type checking of most function calls. This will help eliminate bugs due to incorrect calling sequences. Note that Fortran distinguishes between a argument that is a scalar (zero dimensional array), a one dimensional array and a two dimensional array (etc). So you may get compile warnings because you are passing in an array when PETSc expects a scalar or vis-versa. If you get these simply fix your declaration of the variable to match what is expected. In some routines like MatSetValues() and friends you can pass either scalars, one dimensional arrays or two dimensional arrays, if you get errors here please send mail to [email protected] and include enough of your code so we can see the dimensions of all your variables so we can fix the problems. 4) You can continue to use either fixed (.F extension) or free format (.F90 extension) for your source 5) All the examples in PETSc have been updated so consult them for clarifications. Please report any problems to [email protected] Thanks Barry
Jed noticed a small mistake in my description. It is type(tXXX) not type(iXXX) if you chose to declare your variables that way. Note that declaring them via type(tXXX) or XXX is identical (XXX is just a macro for type(tXXX)). Barry
Notes:
Thanks
Barry
Hi Barry, I'm wondering if these changes will be a part of future 3.8.0 release or 4.0.0 release. And, do you have a tentative timeline when such a release tag would be made? -Gautam. On Sun, Dec 4, 2016 at 11:13 AM, Barry Smith <[email protected]> wrote:
Barry
Notes:
Thanks
Barry
On May 11, 2017, at 11:24 AM, Gautam Bisht <[email protected]> wrote:
Hi Barry,
This will be in 3.8.0 and we hope to make the release in early June. Barry
-Gautam.
Barry
Notes:
Thanks
Barry
participants (2)
Barry Smith -
Gautam Bisht
