Finite difference Jacobian in TS context
Hello All, I hope someone can help :) I think I am doing something wrong, but cannot understand what. I have a huge time dependent system with 3d DMDA data structure and I am evolving it with explicit Runge-Kutta by using TS and basically only using "TSSetRHSFunction". Now I want to repeat it with implicit time stepper (for now Crank-Nicolson) and I am trying to provide finite difference Jacobian and I am failing miserably. I also cannot find appropriate example in PETSc tutorial (if you can point me to working example, it would be great). Here is my best attempt (what wrong with it?): DMDACreate3d(PETSC_COMM_WORLD, DM_BOUNDARY_PERIODIC, DM_BOUNDARY_PERIODIC, DM_BOUNDARY_PERIODIC, DMDA_STENCIL_STAR, NX, NY, NZ, PETSC_DECIDE, PETSC_DECIDE, PETSC_DECIDE, 2*3+NC*NS, 1, NULL, NULL, NULL, &da); DMSetUp(da); DMCreateGlobalVector(da,&x); TSCreate(PETSC_COMM_WORLD,&ts); TSSetProblemType(ts,TS_NONLINEAR); TSSetRHSFunction(ts,NULL,compute_RHS,NULL); TSSetMaxTime(ts,T_FINAL); TSSetExactFinalTime(ts,TS_EXACTFINALTIME_STEPOVER); TSSetDM(ts,da); TSSetType(ts,TSCN); //it works with: TSSetType(ts,TSRK); set_IC(da,x); TSSetTimeStep(ts,DT); TSSetSolution(ts,x); TSGetSNES(ts,&snes); SNESGetKSP(snes,&ksp); KSPGetPC(ksp,&pc); PCSetType(pc,PCNONE); DMSetMatType(da,MATAIJ); DMCreateMatrix(da,&J); ISColoring iscoloring; MatFDColoring matfdcoloring; DMCreateColoring(da,IS_COLORING_GLOBAL,&iscoloring); MatFDColoringCreate(J,iscoloring,&matfdcoloring); MatFDColoringSetType(matfdcoloring,MATMFFD_DS); // I think I do something wrong in the following 3 lines PetscErrorCode (*temp_f)(SNES,Vec,Vec,void*); SNESGetFunction(snes,NULL,&temp_f,NULL); MatFDColoringSetFunction(matfdcoloring,(PetscErrorCode (*)(void))temp_f,NULL); MatFDColoringSetUp(J,iscoloring,matfdcoloring); SNESSetJacobian(snes,J,J,SNESComputeJacobianDefaultColor,matfdcoloring); ISColoringDestroy(&iscoloring); TSSolve(ts,x); Thank you, Oleksandr Koshkarov.
~/Src/petsc/src/ts/examples/tutorials $ grep SNESComputeJacobianDefaultColor *.c ex10.c: ierr = SNESSetJacobian(snes,A,B,SNESComputeJacobianDefaultColor,0);CHKERRQ(ierr); ex15.c: ierr = SNESSetJacobian(snes,Jmf,J,SNESComputeJacobianDefaultColor,0);CHKERRQ(ierr); ex17.c: ierr = SNESSetJacobian(snes,J,J,SNESComputeJacobianDefaultColor,0);CHKERRQ(ierr); I don't think you need to explicitly create the MatFDColoring object. Please take a look at ex15.c and see if you can get it working like that example. If that doesn't work let us know and we can take a closer look at it. Barry
On Apr 28, 2018, at 8:05 PM, Oleksandr Koshkarov <[email protected]> wrote:
Hello All,
TSSolve(ts,x);
Thank you,
Hello all, Sorry for stupid question, but do "SNESComputeJacobianDefault" or "SNESComputeJacobianDefaultColor" make Jacobian matrix free? (I was thinking so from the start... but now it seems I am totally wrong) Best regards, Oleksandr. On 04/28/2018 07:20 PM, Smith, Barry F. wrote:
Barry
Hello All,
TSSolve(ts,x);
Thank you,
Dear All, sorry for spam because of my poor PETSc knowledge (I am just starting with this nice framework). I think, I figured part of it out. However, I want to point that src/ts/examples/tutorials/ex15.c is misleading. (or maybe it is a bug?) in this example we have TSGetSNES(ts,&snes); MatCreateSNESMF(snes,&Jmf); SNESSetJacobian(snes,Jmf,J,SNESComputeJacobianDefault,NULL); // or this: SNESSetJacobian(snes,Jmf,J,SNESComputeJacobianDefaultColor,0); which implies (I think) that Jacobian would be matrix free. And if one would use PCNONE for preconditioning the matrix would never be allocated. However, it seems in reality it allocates matrix. To avoid it, I used MatCreateSNESMF(snes,&J); SNESSetJacobian(snes,J,J,MatMFFDComputeJacobian,0); which seems to work fine. I am not sure I fully understand the difference and i have zero intuition and I also have no idea what happens with preconditioning in this case. If someone have some useful comets, please share :) (I read the relevant section in PETSc manual, but still not fully understanding what I should use when) Thank you and again sorry for the spam, Oleksandr. On 04/28/2018 07:20 PM, Smith, Barry F. wrote:
Barry
Hello All,
TSSolve(ts,x);
Thank you,
On Apr 29, 2018, at 5:40 PM, Oleksandr Koshkarov <[email protected]> wrote:
Dear All,
The above uses matrix-free to do matrix-vector products for linear system but constructs the preconditioner by building the Jacobian via differencing and then using that matrix to build the preconditioner.
To avoid it, I used
This does not build the Jacobian (only has matrix free matrix vector products) so requires much less memory but likely for large problem sizes the linear system solve will be slow (require many iterations) or won't converge at all. The conditioning of the linear system depends on the exact problem you are solving and the type of discretization you are using. There is no easy rules that always apply but for most discretizations of PDEs the number of iterations needed by the linear solver increases with the problem sizes. This means for most large problems matrix-free (without building any sort of jacobean and preconditioner) is impractical and one needs to pay the price of using more memory to get reasonable convergence. Barry
Barry
Hello All,
TSSolve(ts,x);
Thank you,
Thank you. A little clarification:
So SNESComputeJacobianDefaultColor will use memory (construct Jacobian) even if preconditioning is set to PCNONE and J=NULL? (that is what I saw in my example)
So the following command ignores precoditioning? Can I still use something like PCSHELL? SNESSetJacobian(snes,J,J,MatMFFDComputeJacobian,0); p.s. for my problems if probably be unrealistic to construct Jacobian (state size will start from N > 1000^4). Thank you, Oleksandr. On 04/29/2018 05:26 PM, Smith, Barry F. wrote:
Dear All,
which implies (I think) that Jacobian would be matrix free. And if one would use PCNONE for preconditioning the matrix would never be allocated. However, it seems in reality it allocates matrix. The above uses matrix-free to do matrix-vector products for linear system but constructs the preconditioner by building the Jacobian via differencing and then using that matrix to build the preconditioner.
To avoid it, I used
which seems to work fine. I am not sure I fully understand the difference and i have zero intuition and I also have no idea what happens with preconditioning in this case. If someone have some useful comets, please share :) (I read the relevant section in PETSc manual, but still not fully understanding what I should use when) This does not build the Jacobian (only has matrix free matrix vector products) so requires much less memory but likely for large problem sizes the linear system solve will be slow (require many iterations) or won't converge at all. The conditioning of the linear system depends on the exact problem you are solving and the type of discretization you are using. There is no easy rules that always apply but for most discretizations of PDEs the number of iterations needed by the linear solver increases with the problem sizes. This means for most large problems matrix-free (without building any sort of jacobean and preconditioner) is impractical and one needs to pay the price of using more memory to get reasonable convergence.
Barry
Barry
Hello All,
TSSolve(ts,x);
Thank you,
On Sun, Apr 29, 2018 at 7:44 PM, Oleksandr Koshkarov <[email protected]> wrote:
1) SNESComputeJacobianDefaultColor() creates the Jacobian, fullstop. 2) When you pass J=NULL, the Jacobian is created automatically by DMDA 3) The PC has no influence on the assembly process.
Ignore is the wrong word. How do you form a preconditioner from an object with no values in it?
What exactly would you do in your shell? If you are only using the action of an operator, it usually equivalent to some Krylov method.
The number of dofs does not tell us anything. You would need to know the sparsity. People regularly solve problems with billions of unknowns. Thanks, Matt
Thank you,
Oleksandr.
wrote:
Dear All,
// or this: SNESSetJacobian(snes,Jmf,J,SNESComputeJacobianDefaultColor, 0);
To avoid it, I used
Barry
Oleksandr.
~/Src/petsc/src/ts/examples/tutorials $ grep SNESComputeJacobianDefaultColor *.c ex10.c: ierr = SNESSetJacobian(snes,A,B,SNESC omputeJacobianDefaultColor,0);CHKERRQ(ierr); ex15.c: ierr = SNESSetJacobian(snes,Jmf,J,SNE SComputeJacobianDefaultColor,0);CHKERRQ(ierr); ex17.c: ierr = SNESSetJacobian(snes,J,J,SNESC omputeJacobianDefaultColor,0);CHKERRQ(ierr);
Barry
wrote:
Hello All,
SNESSetJacobian(snes,J,J,SNESComputeJacobianDefaultColor, matfdcoloring); ISColoringDestroy(&iscoloring);
TSSolve(ts,x);
Thank you,
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
Thank you, it clarifies a lot :)
Yes, I was thinking to use FD matrix free Jacobian and for preconditioning to use Krylov method to invert the linearized Jacobian which also would be FD matrix free. Sounds bad? Well, from your advices I convinced to try constructing actual Jacobian and use it as Jacobian and matrix from which petsc would construct preconditioner. p.s. Do I reply to emails correctly? or should I replay to [email protected] only? Thank you, Oleksandr. On 04/29/2018 06:03 PM, Matthew Knepley wrote:
On Sun, Apr 29, 2018 at 7:44 PM, Oleksandr Koshkarov <[email protected] <mailto:[email protected]>> wrote:
Matt
Thank you,
Oleksandr.
On Apr 29, 2018, at 5:40 PM, Oleksandr Koshkarov <[email protected] <mailto:[email protected]>> wrote:
Dear All,
To avoid it, I used
Barry
Barry
On Apr 28, 2018, at 8:05 PM, Oleksandr Koshkarov <[email protected] <mailto:[email protected]>> wrote:
Hello All,
TSSolve(ts,x);
Thank you,
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
On Sun, Apr 29, 2018 at 8:29 PM, Oleksandr Koshkarov <[email protected]> wrote:
It will not be scalable, unless you are using the Boundary Element Method. PDE operators have condition number that grows pretty rapidly with size.
Or the first option: Apply J matrix-free for the action in a Krylov method, but build a perhaps simplified operator for preconditioning. If there is no obvious simplification, then just build the whole thing. Thanks, Matt
Matt
Thank you,
Oleksandr.
wrote:
Dear All,
// or this: SNESSetJacobian(snes,Jmf,J,SNE SComputeJacobianDefaultColor,0);
To avoid it, I used
Barry
Oleksandr.
Barry
wrote:
Hello All,
SNESSetJacobian(snes,J,J,SNESComputeJacobianDefaultColor,mat fdcoloring); ISColoringDestroy(&iscoloring);
TSSolve(ts,x);
Thank you,
participants (3)
Matthew Knepley -
Oleksandr Koshkarov -
Smith, Barry F.
