DMSWARM particle coordinates per rank
Does setting up a PIC-type DMSWARM with an associated cell DM guarantee that each MPI rank will own the particles with coordinates inside the bounds of the portion of the grid it owns? --Matt ========================== Matthew Young, PhD (he/him) Research Scientist II Space Science Center University of New Hampshire [email protected] ==========================
There is a caveat that we are currently fixing. Swarm communication is setup to be nearest neighbor (since there is no coarse grid of bounding boxes). So if your particles are initially in the right place, and only move nearest neighbor, everything is fine. We are adding a hierarchy of bounding boxes so that we can communicate anywhere. Thanks, Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Got it. I'm specifically thinking about this in terms of the gather stage of my PIC code, where I loop over local particles to fill local density and flux arrays by linearly interpolating particle positions to the grid. The gather function currently assumes that the coordinates (i.e., the array representation of DMSwarmPICField_coor) of all particles on a given rank would correspond to only the global indices owned by that rank, via the relationship between indices and coordinates in the associated cell DM. Based on what you described, it sounds like I need to make sure that I initially lay down the particles so that their rank matches their coordinates. --Matt ========================== Matthew Young, PhD (he/him) Research Scientist II Space Science Center University of New Hampshire [email protected] ========================== On Fri, May 12, 2023 at 5:15 AM Matthew Knepley <[email protected]> wrote:
Matt
On Fri, May 12, 2023 at 9:40 AM Matthew Young < [email protected]> wrote:
Got it.
Right now, yes. I will fix that before August. Thanks, Matt
Matt
Okay, cool. Should I do that by explicitly setting each particle's DMSwarmField_rank when I assign its position? What role does DMSwarmMigrate play in all of this? --Matt ========================== Matthew Young, PhD (he/him) Research Scientist II Space Science Center University of New Hampshire [email protected] ========================== On Fri, May 12, 2023 at 10:05 AM Matthew Knepley <[email protected]> wrote:
Got it.
Matt
Matt
If you are using a DMDA or a DMPlex, then PETSc now how to do parallel point location (at least for neighbors). So if you add particles on the process which owns that part of the grid, and then call DMSwarmMigrate(), it will locate every particle, and set the 'rank' and 'cellid' correctly. Then if you move the particles (change the coordinates) and call DMSwarmMigrate(), it will move them to the correct process and reset those entries. Thanks, Matt
Got it.
Matt
Matt
participants (2)
Matthew Knepley -
Matthew Young
