Redefining MPI functions as macros can break C++ code
PETSc redefines MPI functions as macros when logging is enabled. This breaks some C++ code; see e.g. < https://github.com/AMReX-Codes/amrex/pull/3005> for an example. The reason is that macros get confused about commas in template arguments. It would be convenient if PETSc used a different way to log MPI function calls, but I can't think of a good way. Alternatively, logging could be disabled by default, or MPI logging could be disabled by default, or there could be a simple way to opt out (e.g. use `#define PETSC_LOG_MPI` after `#include <petsc.h>` to enable it for a source file). -erik -- Erik Schnetter <[email protected]> http://www.perimeterinstitute.ca/personal/eschnetter/
You can define 'PETSC_HAVE_BROKEN_RECURSIVE_MACRO' and then include petsc.h in your sources to avoid these macros in amrex/application codes. PETSc logging is one of the important features - its best to not disable it (globally for all) due to this issue. Satish On Wed, 2 Nov 2022, Erik Schnetter wrote:
-erik
And I see the issue got fixed differently [with braces] https://github.com/AMReX-Codes/amrex/pull/3011/files Satish On Wed, 2 Nov 2022, Satish Balay via petsc-users wrote:
Satish
-erik
participants (2)
Erik Schnetter -
Satish Balay
