Hi, My PETSc based application can work correctly, but after system updating when I use the same commands:
lamboot mpiexec -np 4 application
It seems only one processor works. Then I test it using the following code, ********** PetscErrorCode ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr); COUT << "This is processor : " << rank << ENDL; Use command: mpiexec -np 4 application, The output is: This is processor : 0 This is processor : 0 This is processor : 0 This is processor : 0 ********* Thanks for your help. Yixun
Did you recompile the MPI libraries? Did you re configure and compile ALL of PETSc after the change? You will need to do all this. Barry On Jun 25, 2009, at 1:30 PM, Yixun Liu wrote:
Yixun
Also make sure 'mpiexec' you are using corresponds to the MPI petsc is built with. Satish On Thu, 25 Jun 2009, Barry Smith wrote:
Barry
Yixun
I recompile PETSc using the following commands, petsc-3.0.0-p0>setenv PETSC_DIR $PWD
./config/configure.py
================================================================================= Configuring PETSc to compile on your system ================================================================================= /home/scratch/yixun/petsc-3.0.0-p3/config/BuildSystem/config/compilers.py:7: DeprecationWarning: the sets module is deprecated import sets /home/scratch/yixun/petsc-3.0.0-p3/config/PETSc/package.py:7: DeprecationWarning: the md5 module is deprecated; use hashlib instead import md5 /home/scratch/yixun/petsc-3.0.0-p3/config/BuildSystem/script.py:101: DeprecationWarning: The popen2 module is deprecated. Use the subprocess module. import popen2 TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:394) ********************************************************************************* UNABLE to EXECUTE BINARIES for config/configure.py --------------------------------------------------------------------------------------- Cannot run executables created with C. It is likely that you will need to configure using --with-batch which allows configuration without interactive sessions. ********************************************************************************* Satish Balay wrote:
Satish
Barry
Yixun
Send us the corresponding configure.log to [email protected] Satish On Thu, 25 Jun 2009, Yixun Liu wrote:
Satish
Barry
Yixun
Satish
Satish
Barry
Yixun
ERROR while running executable: Could not execute './conftest': ./conftest: error while loading shared libraries: libopen-rte.so.0: cannot open shared object file: No such file or directory
Your OpenMPI compilers are not configured properly and are currently broken. You'll need to setup LD_LIBRARY_PATH to the correct location of the OpenMPI shared libraries. Satish On Thu, 25 Jun 2009, Yixun Liu wrote:
Satish
Satish
Barry
Yixun
participants (3)
Barry Smith -
Satish Balay -
Yixun Liu
