Re: [petsc-users] Starting point for Stokes fieldsplit
Matt, Thank you for your help.
On Mon, Feb 20, 2012 at 2:05 PM, Max Rudolph <rudolph at berkeley.edu> wrote:
Hi Dave, Thanks for your help.
Max
Hey Max,
Without knowing anything about the specific application related to your Stokes problem, or information about the mesh you are using, I have a couple of questions and suggestions which might help.
The test case that I am working with is isoviscous convection, benchmark case 1a from Blankenbach 1989.
1) If A, is your stokes operator A = ( K,B ; B^T, 0 ), what is your precondition operator? Specifically, what is in the (2,2) slot in the precondioner? - i.e. what matrix are you you applying -stokes_fieldsplit_1_pc_type jacobi -stokes_fieldsplit_1_ksp_type preonly to? Is it the identity as in the SpeedUp notes?
I think that this is the problem. The (2,2) slot in the LHS matrix is all zero (pressure does not appear in the continuity equation), so I think that the preconditioner is meaningless. I am still confused as to why this choice of preconditioner was suggested in the tutorial, and what is a better choice of preconditioner for this block? Should I be using one of the Schur complement methods instead of the additive or multiplicative field split?
Its not suggested, it is demonstrated. Its the first logical choice, since Jacobi gives the identity for a 0 block (see http://www.jstor.org/pss/2158202). Its not meaningless. All the better preconditioners involve either a Schur complement (also shown in the tutorial), or an auxiliary operator which is more difficult to setup and thus not shown.
Thank you for clarifying this.
2) This choice -stokes_fieldsplit_0_pc_type ml -stokes_fieldsplit_0_ksp_type preonly may simply not be a very effective and degrade the performance of the outer solver. I'd make the solver for the operator in the (1,1) slot much stronger, for example -stokes_fieldsplit_0_ksp_type gmres -stokes_fieldsplit_0_ksp_rtol 1.0e-4 -stokes_fieldsplit_0_mg_levels_ksp_type gmres -stokes_fieldsplit_0_mg_levels_pc_type bjacobi -stokes_fieldsplit_0_mg_levels_ksp_max_it 4
Add a monitor on this solver (-stokes_fieldsplit_0_ksp_XXX) to see how ML is doing.
3) Using -stokes_pc_fieldsplit_type MULTIPLICATIVE should reduce the number of outer iterations by a factor of two, but it will use more memory.
4) You should use a flexible Krylov method on the outer most solve (-stokes_ksp_XXX) as the preconditioner is varying between each outer iteration. Use -stokes_ksp_type fgmres or -stokes_ksp_type gcr
Thanks for pointing this out. I made that change.
5) Depending on how the physical problem is scaled (non-dimensionalised), the size of the residuals associated with the momentum and continuity equation make be quite different. You are currently use the entire residual from (u,p) to determine when to stop iterating. You might want to consider writing a monitor which examines the these residuals independently.
I think that I have scaled the problem correctly. I (slowly) obtain a sufficiently accurate solution using as options only: -stokes_ksp_atol 1e-5 -stokes_ksp_rtol 1e-5 -stokes_ksp_monitor_true_residual -stokes_ksp_norm_type UNPRECONDITIONED
How do you know the problem is scaled correctly? Have you looked at norms of the residuals for the two systems Thanks,
Matt
Cheers, Dave
Yes, here are the norms computed for the P, X, and Y components, following the last residual that ksp_monitor_true_residual returned: 383 KSP unpreconditioned resid norm 1.121628211019e-03 true resid norm 1.121628224178e-03 ||r(i)||/||b|| 9.626787321554e-10 P, X, Y residual norms 5.340336e-02, 4.463404e-02, 2.509621e-02
On Mon, Feb 20, 2012 at 4:36 PM, Max Rudolph <[email protected]> wrote:
Matt,
On Mon, Feb 20, 2012 at 2:05 PM, Max Rudolph <rudolph at berkeley.edu <https://lists.mcs.anl.gov/mailman/listinfo/petsc-users>> wrote:
* Hi Dave,*>* Thanks for your help.*>**>* Max*>**>* Hey Max,*>**>* Without knowing anything about the specific application related to*>* your Stokes problem, or information about the mesh you are using, I*>* have a couple of questions and suggestions which might help.*>**>**>* The test case that I am working with is isoviscous convection, benchmark*>* case 1a from Blankenbach 1989.*>**>* 1) If A, is your stokes operator A = ( K,B ; B^T, 0 ), what is your*>* precondition operator?*>* Specifically, what is in the (2,2) slot in the precondioner? - i.e.*>* what matrix are you you applying -stokes_fieldsplit_1_pc_type jacobi*>* -stokes_fieldsplit_1_ksp_type preonly to?*>* Is it the identity as in the SpeedUp notes?*>**>**>* I think that this is the problem. The (2,2) slot in the LHS matrix is all*>* zero (pressure does not appear in the continuity equation), so I think that*>* the preconditioner is meaningless. I am still confused as to why this*>* choice of preconditioner was suggested in the tutorial, and what is a*>* better choice of preconditioner for this block? Should I be using one of*>* the Schur complement methods instead of the additive or multiplicative*>* field split?*>** Its not suggested, it is demonstrated. Its the first logical choice, since Jacobi gives the identity for a 0 block (seehttp://www.jstor.org/pss/2158202). Its not meaningless. All the better preconditioners involve either a Schur complement (also shown in the tutorial), or an auxiliary operator which is more difficult to setup and thus not shown.
* 2) This choice*>* -stokes_fieldsplit_0_pc_type ml -stokes_fieldsplit_0_ksp_type preonly*>* may simply not be a very effective and degrade the performance of the*>* outer solver.*>* I'd make the solver for the operator in the (1,1) slot much stronger,*>* for example*>* -stokes_fieldsplit_0_ksp_type gmres*>* -stokes_fieldsplit_0_ksp_rtol 1.0e-4*>* -stokes_fieldsplit_0_mg_levels_ksp_type gmres*>* -stokes_fieldsplit_0_mg_levels_pc_type bjacobi*>* -stokes_fieldsplit_0_mg_levels_ksp_max_it 4*>**>* Add a monitor on this solver (-stokes_fieldsplit_0_ksp_XXX) to see how*>* ML is doing.*>**>* 3) Using -stokes_pc_fieldsplit_type MULTIPLICATIVE should reduce the*>* number of outer iterations by a factor of two, but it will use more*>* memory.*>**>* 4) You should use a flexible Krylov method on the outer most solve*>* (-stokes_ksp_XXX) as the preconditioner is varying between each outer*>* iteration. Use -stokes_ksp_type fgmres or -stokes_ksp_type gcr*>**>**>* Thanks for pointing this out. I made that change.*>**>* 5) Depending on how the physical problem is scaled*>* (non-dimensionalised), the size of the residuals associated with the*>* momentum and continuity equation make be quite different. You are*>* currently use the entire residual from (u,p) to determine when to stop*>* iterating. You might want to consider writing a monitor which examines*>* the these residuals independently.*>**>**>* I think that I have scaled the problem correctly. I (slowly) obtain a*>* sufficiently accurate solution using as options only:*>* -stokes_ksp_atol 1e-5 -stokes_ksp_rtol 1e-5*>* -stokes_ksp_monitor_true_residual -stokes_ksp_norm_type UNPRECONDITIONED*>** How do you know the problem is scaled correctly? Have you looked at norms of the residuals for the two systems
Matt
* Cheers,*>* Dave*
I am more interested in the initial residuals. Thanks Matt -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
Matt,
Matt
* Cheers,*>* Dave*
Is this the information that you're looking for? I ran with ksp_max_it -1. The Y-residual below is much larger than the X-or P-residuals, presumably because of the initial density perturbation and body force. Thanks again for helping me. Residual norms for stokes_ solve. 0 KSP unpreconditioned resid norm 1.165111661413e+06 true resid norm 1.165111661413e+06 ||r(i)||/||b|| 1.000000000000e+00 KSP Object:(stokes_) 2 MPI processes type: gmres GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement GMRES: happy breakdown tolerance 1e-30 maximum iterations=-1, initial guess is zero tolerances: relative=1e-09, absolute=1e-09, divergence=10000 right preconditioning using UNPRECONDITIONED norm type for convergence test PC Object:(stokes_) 2 MPI processes type: none linear system matrix = precond matrix: Matrix Object: CmechLHS 2 MPI processes type: mpiaij rows=2883, cols=2883 total: nonzeros=199809, allocated nonzeros=199809 total number of mallocs used during MatSetValues calls =0 Matrix Object: CmechLHS 2 MPI processes type: mpiaij rows=2883, cols=2883 total: nonzeros=199809, allocated nonzeros=199809 total number of mallocs used during MatSetValues calls =0 using I-node (on process 0) routines: found 496 nodes, limit used is 5 converged reason -3 stokes residual... converged reason -3 stokes residual... X, Y, P residual norms 0.000000e+00, 1.165112e+06, 0.000000e+00
Thanks
Matt
participants (3)
Matthew Knepley -
Max Rudolph -
Max Rudolph
