DMLocalToLocal with DMPlex in Fortran
Hi, As a follow-up to this email thread, https://www.mail-archive.com/[email protected]/msg44070.html Are DMLocalToLocalBegin() and DMLocalToLocalEnd() really available for DMPlex with Fortran on the latest version of PETSc (3.17.99 from GitLab)? Matt commented that the Fortran bindings were updated so that those functions must be available in the latest version of PETSc, however, it seems still they are not working from my test with DMPlex in Fortran. Can anyone provide some comments? Probably I am missing some mandatory header file? Currently, I have headers; #include "petsc/finclude/petscvec.h" #include "petsc/finclude/petscdmplex.h" #include "petsc/finclude/petscdmlabel.h" #include "petsc/finclude/petscdm.h" Thanks, Mike
On Fri, Sep 30, 2022 at 4:14 PM Mike Michell <[email protected]> wrote:
The source for these functions is in src/dm/ftn-auto/dmf.c Is it there for you? If not, you can run make allfortranstubs Fortran functions are not declared, so the header should not matter for compilation, just the libraries for linking. Thanks, Matt
Thanks, Mike
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Thank you for the reply. There is that file in src/dm/interface/ftn-auto/ for me, instead of the path you mentioned. After "make allfortranstubs" was done and, PETSc reconfigured and reinstalled. However, I still have the same problem at the line in which DMLocalToLocalBegin() is used. What I am doing to setup halo exchange is as follows; - declare DMPlex - PetscSectionCreate() - PetscSectionSetNumFields() - PetscSectionSetFieldComponents() - PetscSectionSetChart() - do loop over dofs: PetscSectionSetDof() and PetscSectionSetFieldDof() - PetscSectionSetUp() - DMSetLocalSection() - PetscSectionDestroy() - DMGetSectionSF() - PetscSFSetUp() Then, the halo exchange is performed as follows; - DMGetLocalVector() - Fill the local vector - DMLocalToLocalBegin() --(*) - DMLocalToLocalEnd() - DMRestoreLocalVector() Then, the code crashes at (*). Previously(at the time PETSc did not support LocalToLocal for DMPlex in Fortran), the part above, "DMLocalToLocalBegin() and DMLocalToLocalEnd()", consisted of; - DMLocalToGlobalBegin() - DMLocalToGlobalEnd() - DMGlobalToLocalBegin() - DMGlobalToLocalEnd() and it worked okay. I am unclear which part is causing the problem. Shall I define the PetscSection and PetscSF in different ways in case of Local to Local Halo exchange? Any comment will be appreciated. Thanks, Mike
Matt
Thanks, Mike
Can you send something I can run? Then I will find the problem and fix it. Thanks, Matt
Thanks, Mike
Matt
Thanks, Mike
Thank you for the reply. Sure, a short example code is attached here with a square box mesh and a run script. Inside the source, you may find two versions of halo exchange; one is for local to global (Version-1) and another one is for local to local (Version-2), which is not working in my case. In the output.vtu, you will see the halo exchanged vector resolved to each vertex with (myrank + 1), so if the code is running with 2procs, at the parallel boundary, you will see 3. In this example, there is no ghost layer. Thanks, Mike
Matt
Thanks, Mike
Matt
Thanks, Mike
Hi, I was wondering if there is any comment on the example file that I can refer to. Thanks, Mike
Thanks, Mike
Matt
Thanks, Mike
Matt
Thanks, Mike
I see the problem. Local2Local is not implemented for Plex. I thought we had this automated, but it was only coded for DMDA. It is a fairly mechanical transformation of the Global2Local, just remapping indices, but it will take some time since there is a lot of backlog this semester. I have fixed the error message so now it is obvious what the problem is. Thanks, Matt
Thanks, Mike
Thanks, Mike
Matt
Thanks, Mike
Matt
Thanks, Mike
Thank you for the reply and checking. Indeed, it seems that local-to-local halo is still not implemented for DMPlex. But I believe this is a very required feature for large 3D simulations with DMPlex. Would you mind if I ask for any estimated timeline to fix this issue and put it on the official version of PETSc? If I remember correctly, we had a similar discussion a few months ago. Thanks, Mike On Mon, Oct 10, 2022 at 10:41 PM Mike Michell <[email protected]> wrote:
Matt
Thanks, Mike
Thanks, Mike
Matt
Thanks, Mike
Matt
Thanks, Mike
It is possible that it will make a difference. An explicit code, running completely from local vectors, which assembles its own residuals without mapping to global vectors, could probably realize some gain. It would be interesting to see the numbers.
I cannot do it until November since we have a big review coming up. Thanks, Matt
Thanks, Mike
Matt
Thanks, Mike
Thanks, Mike
Matt
Thanks, Mike
Matt
Thanks, Mike
Thanks a lot for the reply. It is possible that it will make a difference. An explicit code, running completely from local vectors, which assembles its own residuals without mapping to global vectors, could probably realize some gain. It would be interesting to see the numbers. => Agree with this. Even with an implicit scheme, I need the halo exchange of local-to-local while constructing the local matrix object (for example, summation over control volume components). Thus I expect some computational gain with this. In December, will try to remind you via this email chain. Thanks, Mike
Matt
Thanks, Mike
Matt
Thanks, Mike
Thanks, Mike
Matt
Thanks, Mike
Matt
Thanks, Mike
participants (2)
Matthew Knepley -
Mike Michell
