Hello, I have the following error: PETSc Error --- Open MPI library version FUJITSU MPI Library 4.0.0 (4.0.1fj4.0.0) does not match what PETSc was compiled with 4.0, aborting I have to configure and compile petsc in a cross compilation environment and run it in a different one. I'm trying to run src/snes/examples/tutorials/ex19 to confirm things are working. It looks like this error could be down to some confusion with string comparison ("4.0.0" =/= "4.0"), or it could be some nightmare misalignment between the two environments I have to use, and/or my efforts to configure PETSc. I'm trying to determine which. Is there some way to turn off this version checking, to see if it is just a string comparison error and maybe the rest of the program will run fine? Or could someone point me to where in the source code/configuration scripts these numbers are harvested and this error is generated, so I can try to get a better idea about what is going on? Thanks, Daniel Stone
Hello Daniel, Which PETSc version are you using? I think this has been addressed there: https://gitlab.com/petsc/petsc/-/merge_requests/3671 <https://gitlab.com/petsc/petsc/-/merge_requests/3671> Thanks, Pierre
On 11 May 2021, at 11:22 AM, Daniel Stone <[email protected]> wrote:
Hello,
Daniel Stone
Hi Pierre, I'm using 3.12.2, which is a bit old, but needed for the Pflotran version I'm using. It certainly predates that merge. Many thanks for pointing me to that merge - if nothing else I could now study that and try manually implementing it to see if it helps my situation. Thanks, Daniel On Tue, May 11, 2021 at 10:28 AM Pierre Jolivet <[email protected]> wrote:
Thanks, Pierre
Hello,
Daniel Stone
On Tue, May 11, 2021 at 5:34 AM Daniel Stone <[email protected]> wrote:
Hi Pierre,
You might just be able to cd $PETSC_DIR git cherry-pick 16dc8964ca763700383c940ec0bdd667c5da14cf make Thanks, Matt
Daniel
Thanks, Pierre
Hello,
Daniel Stone
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Or disable this check.. i.e change #elif defined(OMPI_MAJOR_VERSION) to #elif defined(OMPI_MAJOR_VERSION_disable_check) Satish On Tue, 11 May 2021, Matthew Knepley wrote:
Hi Pierre,
Matt
Daniel
Thanks, Pierre
Hello,
Daniel Stone
participants (4)
Daniel Stone -
Matthew Knepley -
Pierre Jolivet -
Satish Balay
