Hello all, Please answer the following, 1) What is the difference between static and dynamic versions of petsc? 2) How to check that which version (static or dynamic) is installed on a system? 3) Plz comment on if there is any effect of static/dynamic version while using/calling petsc from some external package? 4) how to update an already installed petsc version with newerer/latest version of petsc? Thanks to all.
On Wed, Feb 27, 2008 at 2:11 AM, amjad ali <[email protected]> wrote:
Hello all,
Start here: http://en.wikipedia.org/wiki/Library_(computer_science)#Static_libraries In PETSc the primary differences end up being the size and link-time. Statically-linked executables need all the possible code that they could contain in the actual file, so they can be up to several MB in size. Dynamically-linked executables are much leaner for the small price of a little extra load time. Now if you're talking about Dynamically-Loaded code, that's a bit hairier...
The fastest way is probably to look in $PETSC_DIR/$PETSC_ARCH/ If you see .a files, you've got static libraries, if you see .so or .dylib files you've got dynamic libraries.
I'm not sure what you're asking here. If you mean "Is there a difference between calling dynamically compiled PETSc from statically compiled PETSc" the answer is no. There are differences in how you compile and link the two version but your actual code would look the same. Again, if we're talking about dynamically loaded code (using something like dl_open), then your code will look different.
Doing this in place is more trouble than it's worth if you're not using a development copy . I just grab the latest copy of PETSc from their webpage, then re-build and re-install. ~A
Just a note on terminology. The difference between shared & dynamic is a bit confusing [esp across windows/linux/mac etc..]. I like to use 'shared-libraries' name instead of 'dynamic-libraries', as thats the primary feature of .so/.dylib/.dll etc. PETSc configure supports the following options --with-shared=0/1 --with-dynamic=0/1 The dynamic option refers to the using dlopen() to look for function in a sharedlibrary [instead of resolving these functions at link-time] If petsc is built with dynamic usage- then PETSC_USE_DYNAMIC_LIBRARIES flag is set in petscconf.h. Shared libs can be identified by looking at the library names. Satish On Wed, 27 Feb 2008, Aron Ahmadia wrote:
Hello all,
~A
Thanks Satish, That's definitely an easier way to think about it... ~A On Wed, Feb 27, 2008 at 3:40 PM, Satish Balay <[email protected]> wrote:
Satish
Hello all,
~A
participants (3)
amjad ali -
Aron Ahmadia -
Satish Balay
